Root Cause Analysis (RCA): Many Bucket Elevator Wrecks rob crew morale.
| Category: | Mechanical |
| Equipment Type: | Pipelines and Miscellaneous Problems |
The obvious root cause was Drive Sprocket Shaft extension mounted improvised and inadequate RRPs did not stop chain reverse rotation on intentional or failed power elevator stops.
The Author Root Cause Analysis identified the improvised RRP inadequacy’s below listed causes:
- The sprocket shaft dia is 250 mm; but the shop’s machine could make a RRP for a 100 mm shaft only
- Hence, both the shop made RRP and its shaft inserted in a square hole cut in the 250 dia sprocket shaft were inadequate; hence the shaft extension often bent attempting RR preventions
- Harsh plant environs contaminating the exposed lubricating grease accelerated the failures
Author Solution
He studied Gearbox (GB) makers’ catalogs and learnt of professionally designed and built GB inside fitted RRPs. They furnish retrofit RRPs too at slight extra cost. Formerly GB high-speed shafts fitted RRPs failed.
Without a Root Cause Analysis they discarded GB fitted RRPs. To satisfy their wishes, the author tried an GB intermediate speed shaft driven RRP.
Its success made the plant fit GB IS driven RRPs for all elevators.
Eliminate Elevator Chain Wrecks
Substituted RRPs excellent features
The below listed excellent features eliminate the elevator chain wrecks long shutdowns forever:
- By design and manufacture their torque ratings meet plant needs
- Dust and water tight enclosure protects the RRP from the plant’s corrosive and dusty environs
- Copious uncontaminated oil supply besides lubrication cools the RRP also
- The improvised grease lubricated RRP lacked this feature
Vanished elevator wrecks delighted all.
Author: S. Raghava Chari
- Plug Valves Leaks
- Rupture Discs bursts
- Repeat Safety Valve Popping
- Fan Bearing Change Times cut by 90%
- Boiler Feed Water Shell Flange Leaks
