Reading: Introducing PLC Programming using LogixPro Simulator Software
Inst Tools > Blog > PLC Tutorials > Introducing PLC Programming using LogixPro Simulator Software
Introducing PLC programming practices using LogixPro simulator software and downloading procedure in detail.
Last updated: November 21, 2022 4:07 pm
Hussien Ghareb
Introduction to LogixProPLC Software OverviewEditing and Downloading in LogixProTroubleshooting & Debugging the ProgramAvailable Data Types for LogixPro Software
Building a programming mindset is not that simple, practicing and executing many programming ideas will help you.
However, preparing ready-made Coding Structures into your programming mindset using different techniques will strengthen your PLC programming ability much more and make the programming easier for you.
Today and for the next posts, we will learn a group of sharp, precise, and smart programming techniques, by a commonly used programming software LogixPro.
The LogixPro simulator is an interactive educational tool, developed to assist students in the acquisition of the programming skills commonly used in the PLC control of process equipment and systems.
Download PLC Software: LogixPro Simulator
The significant advantage of this software is that it is widely available, you can download and install it without any restrictions.
Here as shown in Fig. (1) we can see the three major components of the software:
  • Programming window
  • Simulator
  • Edit menu
The Edit Panel provides easy access to all the RS Logix instructions and they may be simply dragged and dropped into your program.
Once your program is ready for testing, clicking on the “Toggle Button” of the Edit Panel as shown in Fig. (2) will bring the PLC Panel into view.
PLC Editing and Downloading in LogixPro
From the PLC Panel, you can download your program to the “PLC” and then place it into the “RUN” mode.
This will initiate the scanning of your program and the I/O of your chosen simulation.
If you take a look at the PLC Panel, you’ll notice an adjustable Speed Control shown in Fig. (3).
This is not a component of normal PLCs but is provided with LogixPro so that you may adjust the speed of the simulations to suit your particular computer.
PLC Troubleshooting & Debugging the Program
When the simulation is slowed, so is the PLC scanning. You can use this to good effect when trying to debug your program.
Set the scan slow enough and you can easily monitor how your program’s instructions are responding. This capability may not be typical of real PLCs, but for Training Purposes, you will find that it is an invaluable debugging tool.
One of the best advantages of this software is the “Drag & Drop” property.
As you can see in Fig. (4) by clicking on the data table button a new window will pop up with all the available addresses that you will need.
(Output, Input, Timers, Counters, Markers are signed with “B” …)
All you need to do is to choose the required data type then select the desired bit from the table then drag it and drop it to the specified location.
  • Function of Racks in PLC
  • Motor Classic Control Circuits
  • Control System Cyber Security
  • Features of Scada in IoT System
  • Conveyor Operation with a PLC
Types of Digital Outputs in PLC
Five Types of PLC Programming languages
Complete PLC Project: Traffic Light Auto and Manual Automation
PLC Program for Two Way Switch Logic
Converter Instruction in Siemens PLC Programming
PLC 1 Push Button to Turn ON or OFF 1 Output
TIA Portal MOVE Instruction
MOVE Instruction in PLC – What You Need to Know?
Preventive Maintenance of Variable Frequency Drive
Surge Protection Device
HMI Screen Design for Hazardous Applications
PLC Analog I/O Potential Problems
PLC Analog I/O Potential Problems – Troubleshooting & Issues
What is a Magnetic Field
Difference Between Electric Field and Magnetic Field
Fluorescent Screen of CRT
CRT Fluorescent Screen
DPDT switch
Switch Types and Common Terminology
Rotary Liquid Seal Ring Air Compressor
Rotary Compressors
Digital Control Systems
The Z-Transfer Function
capacitor-filter-ripples
Ripple Voltage in Rectifiers
Residual Current Circuit Breaker (RCCB)
