Reading: How to Install a Control Valve?
Inst Tools > Blog > Control Valves > How to Install a Control Valve?
Proper installation is as much important as selecting the right control valve for any process control. Learn how to install it.
Last updated: September 28, 2022 2:35 pm
R Jagan Mohan Rao
Control Valves
6 Min Read
Proper installation is as much important as selecting the right control valve for any process control. Because having properly selected a given control valve does not automatically ensure that it will do the right job.
Install a Control ValveControl Valve AccessibilityTipsValve Manual OperationValve Location
In addition to the right selection, also depend greatly on the experience of the person who designed the piping layout.
It means a piping designer has to consider valve physical parameters such as height, mounting practices, accessibility, and the proper location for mounting the valve.
Installation of a Control Valve
Inspection of the control valve for any shipment damages is necessary before installation.
Control valve accessibility, its installation location, consideration for manual operation are few steps to be taken care of.
This article concentrates to discuss in more detail “How to install a control valve”.
The control valves should be installed in such a way that they are readily accessible for maintenance purposes.
If a control valve is mounted at a certain height, a permanent platform or walkway with ample clearance for maintenance operations is required.
The control valve can be installed in any orientation, but the preferred installation is in a horizontal pipeline with an actuator in a vertical position.
It is recommended to install pressure gauges before and after the control valve to check the line pressure status as shown in the figure below.
How to install a Control valve?
Tips
Also, check the following points below.
Sufficient workspace to remove the actuator when a repair is necessary.
Sufficient clearances should be provided above and below the control valve so that the bottom flange and plug or the top works and the plug, may be removed with the valve body in place.
Can the flange bolts or the tie rods be removed?
Can the positioner gauges or valve travel indicator be seen?
Can the positioner be adjusted?
If a handwheel is provided, it in a position so that it can be rotated?
Can the pipe leading to the valve be de-pressurized or drained for purpose of valve removal?
Convenient for manual operation?
In many critical applications, it is necessary to consider a manually operated throttling valve in a bypass around the valve.
With appropriate block and drain valves on either side of the control valve that allows for the repair or replacement without shutting down the process.
A by-pass should be installed if continuous operation is required during maintenance and inspection.
Valve Location
The location of the valve chosen must be sufficient to permit repair.
Correct location to help prevent cavitation.
Place a steam trap close to the valve inlet if the valve is on the bottom of a steam header.
Straight run pipe of six pipe diameters downstream of the valve, do not place an elbow or pipe tee less than six pipe diameters downstream of a valve to avoid interference with the valve’s flow capacity.
In the case of high-pressure gas or steam pressure-reducing applications, try to have only straight pipes downstream of the valve or use the long sweeping elbow to avoid additional pipe noise. Allow for drainage through the valve. This is particularly important for sanitary valves and for valves handling dangerous fluids.
Study the possibility of corrosion caused by leaky flange gaskets or valve stem packing on the equipment located below the valve.
Control valve should not be located near a source of extreme heat. Control valves that handle combustible fluids should be kept away from the hot pumps, lines, or equipment.
Study the chances where the accessories might freeze up in winter.
Check and consider the ambient temperature rating of the actuator or positioner or heat trace the valve or airlines. In order to prevent premature failure of diaphragms and electric or electronic components.
Control valves should be located such that the top works are not adjacent to hotlines or equipment.
Electrical accessories must meet safety standards as applicable for installation in hazardous and other locations.
Reference: Control valve Primer A user’s guide by Hans D Bauman 2008.
  • Advantages of Shutdown Valve
  • Control Valve Commissioning
  • Maintenance of Control Valves
  • Basics of Control Valve Sizing
  • Valve Relation between Cv and Kv
Valve Materials Comparison Notes
Types of Check Valves
Valve Terminology Glossary
What happens when Fluid Flow Reversed through Control Valve?
Air Pressure Regulator Questions
Control Valves Mechanical Friction Problems
Difference between Quick Opening, Linear & Equal Percentage Control Valve characteristics
What is a Electric Motor Actuator ?
What is Poppet Valve? When we Use a Poppet Valve?
Solenoid Valve’s Energized or De-energized State ?
Direct Acting Control Valves & Reverse Acting Control Valves
Why we Measure Control Valve flow coefficient (Cv)?
Basics of Butterfly Valves
Electrical Actuators
Control Valves Pre-Commissioning Checklist
Valve Sequencing
Complementary Control Valve Sequence
Valves Legend P&ID
Comparison of Gate Valves and Globe Valves
Difference between BDV and PSV
shape of the trim determines the valve characteristic
Control Valve Characteristics
Facts of Control Valves
Facts About Control Valves
3-port-2-position-direct-acting-solenoid-valve
3 Port 2 Position Direct Acting Solenoid Valve Working Principle
Valve Seat leakage Test
Valve Seat Leakage Test
Essential Dorm Room Items Every Student Should Get
The Dorm Room Essentials And Why You Need Them
Modbus Simulator Softwares
Thermal Differential Level Measurement
What is Thermal Differential Level Measurement?
Catalytic Gas Sensor Working
Catalytic Type Gas Sensor Principle
State Models for Linear Continuous Time Systems
Falling Positive and Falling Negative Instructions in PLC
Positive and Negative Edges using Statement List Language
PLC Program for fan control unit system
PLC Programming for Fan Control Unit System for Industry
positive displacement flow meter pictures
What is a Positive Displacement Flow Meter?
