Reading: Electrical Ladder Diagram Control using Timers Example
Inst Tools > Blog > PLC Tutorials > Electrical Ladder Diagram Control using Timers Example
In this example program, you will learn the electrical ladder diagram control using timers and toggle switches.
Last updated: April 8, 2024 2:28 pm
Electrical Ladder Diagram ControlPro PLC LearningInputsOutputsLadder Diagram using Timers ExampleProgram DescriptionPLC Program Analysis
Note: The ladder diagram example is prepared to understand the basic programming for electrical engineers.
Problem Statement:
We are using one toggle switch to control three motors.
When switch 1 is turned ON,
After 5 seconds, Motor 1 will be ON
After 10 seconds, Motor 2 will be ON
After 15 seconds, Motor 3 will be ON
After 20 seconds, all the motors will be OFF.
Pro PLC Learning
Our PLC learning videos help engineering graduates understand these programs from the basics.
PLC Timer Ladder Diagram - Example Program using Switch and Motors
Inputs
The inputs are listed below.
Switch 1: I0.0
Outputs
The outputs are listed below.
Motor 1: Q0.0
Motor 2: Q0.0
Motor 3: Q0.0
Program Description
In the PLC program, we have used Normally Open Contact for Switch 1
Two Timer Function Blocks Type TON and TP are used for Motor 1, Motor 2, and Motor 3.
In Rung0:
Normally Open Contact is used for Switch 1.
Timer Function Block type TON is used for Motor 1 to turn it ON after a delay of 5 seconds.
Timer Function Block type TON is also used for Motor 2 to turn it ON after 10 seconds.
Timer Function Block type TP is used to keep Motor 1 ON for 20 seconds.
Timer Function Block type TP is also used for Motor 2 to keep it ON for 20 seconds.
In Rung1:
1) Normally Open Contact is used for Switch 1.
2) Timer Function Block type TON is used for Motor 3 to turn it ON after a delay of 15 seconds.
3) Timer Function Block type TP is also used for Motor 3 to keep it ON for 20 seconds.
Automation Forum PLC Programming
When Switch 1 is turned ON, the Timer functional block type TON (TM0) will allow the signal to flow after a delay of 5 seconds.
After 5 seconds, the signal will flow and the Timer functional block type TP (TM1) will allow the signal to flow for 20 seconds only, and in that duration of time, Motor 1 will be ON.
After 20 seconds, the signal will not flow. As a result, Motor 1 will turn OFF.
Ladder Logic Timer Application
When Switch 1 is turned ON,  after a delay of 10 seconds the Timer functional block type TON (TM2) will allow the signal to flow.
The Timer functional block type TP (TM3) will allow the signal to flow after 10 seconds for 20 seconds only and Motor 2 will be ON for that duration of time only. The signal will not flow after 20 seconds, t. As a result, Motor 2 will turn OFF.
DipsLab PLC
When Switch 1 is turned ON, the Timer Functional Block type TON (TM4) will make it wait for 15 seconds and after that, it will allow the signal to flow.
Then, another Timer Functional Block type TP (TM5) will allow signal only for 20 seconds and Motor 3 will be ON only for that duration of time.
After that, the signal will be blocked and Motor 3 will turn OFF.
So, When Switch 1 is turned ON, Motor 1 will turn ON after 5 seconds and for 20 seconds, Motor 2 will turn ON after 10 seconds and for 20 seconds and Motor 3 will turn ON after 15 seconds and for 20 seconds.
  • From Boolean Algebra to PLC Logic
  • PLC Program for Solenoid & Pilot Lamp
  • PLC Programming Example with Motor
  • PLC to Start or Stop using 1 Switch Program
  • PLC Code to Start & Stop Motor and Pump
Down Counter PLC Program
Function Blocks in PLC (FBs) – What You Need To Know?
Components of SCADA
What is a Annunciator Panel?
Edge Detection in PLC Programming
PLC Valve Control Ladder Logic Programming
What is Resources Tab in the Siemens PLC?
STAR DELTA Programming using PLC Controller
Architecture of Allen Bradley PLC
200+ Quiz on Electrical Meters, Measurement, and Troubleshooting
PLC Program for Valves
PLC Pump Permissive Interlocks
Glass Cutting and Polishing Machine PLC Automation Solution
Glass Cutting and Polishing Machine: PLC Automation Solution
PLC-Complete-Training-Package
Free PLC Training Software Download
Scan cycle of a Siemens PLC
OB1 – Main Cyclic Organization Block in TIA Portal
PLC Programming Limit Switch
TIA Portal Options
How to Troubleshoot Siemens PLC Programs?
ControlLogix Architecture - Rockwell Automation
ControlLogix Architecture – Rockwell Automation
4-20mA Loop Power Supply Questions
Difference Between Static and Temp Memory in Siemens TIA Portal
Networking Interview Questions
Top 100 Networking Interview Questions & Answers
AC Voltage Controllers Multiple Choice Questions
Mitsubishi PLC Programming Tutorials
Reed Switch Principle
Reed switch Working Principle
Difference Between Open Circuit and Close Circuit
Introduction to PLC
Introduction to PLC – Advantages of PLC
Quiz on Manual Motor Starters
100 Electromagnetic Motor Starters Multiple Choice Questions
