Reading: Contact and Non-Contact Level Sensors
Inst Tools > Blog > Level Measurement > Contact and Non-Contact Level Sensors
Last updated: August 13, 2018 10:04 pm
Level Measurement
2 Comments
14 Min Read
A good way to reduce the number of level measurement options is to categorize them into two broad categories: contact and non-contact. Then you can filter choices by the type of material they can measure.
The characteristics of the process material being measured, such as tank size and shape, the pressure and temperature that the process requires, amount of material agitation, available power, etc., must be taken into account when determining if a contact or non-contact approach is the right option.
One must consider whether the material is corrosive or tacky and could possibly cause damage to the measuring device, whether it is volatile and a contact sensor might create a safety hazard, whether the agitation, temperature, or pressure of the process material could affect the reading of or damage the contact sensor, and any other troublesome possibility.
On the other hand, non-contact solutions may be outside of the budgetary constraints of the project or not provide the necessary level of precision.
Level Sight Gauge
The first type of level measurement device to be considered here is also the simplest. A level sight gauge typically consists of a tube connected at openings near the top and bottom of the tank. The tube has a transparent face so an operator can see the level of the process material. This is technically a non-contact measurement because there is no sensor making contact with the process material.
However, many of the same concerns about contact sensors should be taken into account, such as agitation, corrosiveness, tackiness, temperature, pressure, etc., which could damage or obscure the viewing area. Though this method of level measurement may be considered the most trustworthy because the material level can actually be seen by the operator, pressure or temperature differentials between the tank and the viewing area can have an effect on measurement accuracy.
When measuring an interface, the top opening of the gauge must be submerged at the level of the top liquid and the bottom opening must be at the level of the denser liquid or else the level measurement will be incorrect. Level sight gauges can only be used when measuring liquids, as granules and slurries cannot move fluidly through the gauge. There is also no way to incorporate any type of automation into the process using this type of measurement device.
RF Capacitance
RF Capacitance level sensors use the same operating principle as an electronic capacitor in order to gauge level. An electronic capacitor consists of two conductive metal plates separated by some kind of insulating material. Capacitance is the measurement of the amount of energy a capacitor can store.
Using a method that is very similar to that of an electronic capacitor, the capacitance of a process material can also be measured and then correlated to the level. If measuring a non-conductive material, that material is used as the insulator part of the capacitor and the tank wall acts as the second conductive plate; if measuring a conductive material, the probe body is shielded with an insulator and the material acts as the other conductive plate.
In either case, a rise in the level will correlate with an increase in the measured capacitance (over that of air). This technology can be used for either point-measurement level switches or continuous level measurement. Variations of this technique can be used to measure liquids, granular solids, slurries, and interface levels.
Float
Other devices, such as floats anddisplacers, rely on the material’s specificgravity (density) to measure level. They often use a gauge similar to the sight level (a tube connected to the side of the tank towards the top and bottom).
Magnetic floats, a specific type of float level sensor, typically rely on reed relays placed lengthwise within the tube. When the float passes these relays the magnetic field trips them. Therefore, the accuracy of such a sensor is limited by the number of reed relays placed in the gauge.
Other float sensor types rely on the measurement of the extension and retraction of a connected cable. This type of sensor, in principle, requires no power to operate but is susceptible to failure from float jamming or clinging.
Resistance Tape
The mechanical force of a process liquid can be used to measure level using what is known as resistance tape. Two wires, one attached to a voltage source and the other to a precision resistor, are contained within a shielded, flexible probe.
Hydrostatic pressure pushes on the probe body and shorts out the submerged length of wire. The change in resistance is correlated with the level of the process liquid. These types of contact probes tend to be very delicate and changes in density can have a minor effect. They are typically used to measure liquids and slurries.
Displacer
Displacers are dissimilar from float devices in that they are denser than the process fluid and suspended by a spring. They rely on Archimedes’ Principle to detect changes in buoyancy force, which is equal to the weight of the displaced fluid, caused by a rise or fall in level.
A sensor at the top of the gauge measures the change in apparent weight of the displacer body. The level measurement is therefore a product of the length of the displacer body covered by the process material and the specific gravity of the material. Both displacers and floats require much of the same considerations as mentioned previously with level sight gauges and special considerations for interface measurement.
Contacting Ultrasonic
Vibrating or ultrasonic level switches work under the principle that the sensor will vibrate at its resonant frequency when not submerged in process material. If the frequency is dampened, the material has reached the level of the switch. This technique works with liquids, slurries, and granules, although consideration should be made for coating or corrosive materials.
Vibrating level switches will typically only be used for point level measurement, as opposed to continuous level measurement, and trigger high and/or low alarms. The sensors themselves tend to be fragile because of the level of precision necessary.
Bubble Tube
Bubble tube level measurement relies on the specific gravity of the process material as well. With this type of contact sensor, a tube is submerged into the process fluid and air or nitrogen is pumped through the opening, near the bottom of the tank. The resulting back pressure is proportional to the liquid level and density.
In instances where submerging a tube into the process liquid is impractical, air can be pumped in through an entry at the side of the tank. This type of sensor can only be used to measure the level of liquids. If the process liquid in which the tube is submerged remains at a constant level, any change in back-pressure is due to a change in density or interface level, thus allowing for measurement of these variables.
Radar
Radar is a technology which was first extensively developed and deployed during the second World War as a means of detecting aircraft, ships, and other large objects. Since the technology was introduced to the civilian sector, many peacetime usages of the technology have been established, including level measurement.
Radar typically works by emitting electromagnetic pulses in the direction of an object, waiting for that pulse to reflect off the object and return to the source, and measuring its time-of-flight. The distance between the pulse source and the object can be calculated as the product of one-half the time-of-flight and the speed of light. For use in level measurement, a radar transceiver is suspended from the top of the tank and measures the distance to the top of the process material.
The overall length of the tank body can then be used to calculate the level. As a non-contact sensor, radar has the distinct advantage of not being affected by the process material’s state, such as agitation, corrosiveness, tackiness, temperature, pressure, etc. Radar can be used to measure liquids, slurries, and granular solids.
However, materials with high conductivity tend to be better candidate for radar level measurement because they reflect more of the emitted radio signal. As such, conductive materials other than the process material within the tank, such as agitators, can cause interference with the radar signal.
Non-Contacting Ultrasonic
Non-contact ultrasonic level sensors use a very similar method as radar sensors to measure level. However, instead of using radio waves they use sound waves and the distance is calculated as the product of one-half the flight time and the speed of sound. Unlike the speed of light, the speed of sound is temperature dependent, so the temperature of the tank must also be measured and taken into account.
Like radar, they can also be used to measure liquids, slurries, and granular solids. Process materials that produce a stronger sonic reflection are more applicable to this type of measurement. Condensation, dust buildup, and presence of additional objects within the tank can all cause measurement inaccuracies.
Load Cells
Load cells, sensors normally used to measure weight, can be used to gauge tank level. These sensors are attached to the support columns of a tank and measure the downward force applied on them by the mass of the container above. B
y taking into account the weight of the tank when empty and assuming that the tank has straight sides, any change in the weight measured by the load cell can be correlated with a change in level. Load cells can be used to detect the level of liquids, slurries, and granular solids, but require the process material to be of constant density. Load cells typically are not used to measure interface level.
Nuclear
Nuclear type level sensors use radioactive isotopes, typically either cobolt-60 or caesium-137, to emit gamma radiation into a storage container and sensors on the opposite side to measure the attenuation, or change in frequency modulation, of that radiation. Isotopes are atoms that have the same chemical behavior as one another but a different number of neutrons.
Radioactive isotopes are those isotope variations which are unstable under normal conditions and decay into other elements. When these atoms decay, they emit three different kinds of radiation (alpha, beta, and gamma) which can be picked up and measured by special sensors. Gamma radiation is used for the purposes of level measurement because, of all three kinds, it is the best at penetrating materials.
This technology can be used in both single-point and continuous level applications. In single-point measurement, such as high and low alarms, a sensor is typically installed parallel to the source of radiation on the opposite side of the tank and any change in frequency modulation over a certain threshold triggers an alarm. Since radiation is released from all directions from a radioactive element, continuous level measurement involves using sensors along the length of the tank on the opposite side.
Using the attenuation detected through an empty tank as a baseline, any change detected by a sensor is attributed to the level being at or above that sensor. Though this technique is affected little by the physical state and properties of the material, it is typically only used when all other options have been exhausted due to the dangers and expense of using radioactive material and the stigma associated with it.
What is Dip Tape Level Measurement?
Optical Level Switch Working Principle
Remote Seal Differential Pressure Transmitters Principle
Displacer Level Transmitter Calibration using Water & Process Liquid
Differential Pressure (DP) Level transmitter Installed Below Tapping Point
FMCW Radar Level Transmitter Working Principle
2 Comments
  • kingsley says:
    August 18, 2016 at 10:01 am
    pleas sir can you help to explain how to calibrate GUIDED WAVE RADAR level transmitter in the field.
    Thanks
  • Henry Thomas Nelson says:
    August 24, 2016 at 1:17 pm
    how vibration effects affect the overall performance on standby generator
Basics of Hydrostatic Level Measurement
Types of Level Gauges
Hydrostatic Tank Gauging (HTG)
Magnetostrictive Tank Gauging (MTG)
Level Transmitter and Level Gauge Design Tips
Boiler Drum Level Transmitter Calibration
Open and Closed Tank Level Calculations
Bubble Tube Level Measurement Principle
Wet Leg Level Transmitter
Basics of DP Level Measurement
Interface Level Measurement Selection Guide
ultrasonic-level-measurement
Ultrasonic Level Transmitter Working Principle
displacer level transmitter cylindrical weighs
Displacer Level Transmitter 5-point Calibration
Closed Tank Remote Seal Level Transmitter calculation
Remote Seal Transmitters Ranging Calculation
Radiation Level Measurement
Electrical Machines MCQ Series 14
Seebeck Effect
Seebeck Effect Theory
Measuring Instruments MCQ
Automation in Agriculture
Automation in Farming & Agriculture
Control Systems Questions & Answers
Control Systems Objective Questions & Answers – Set 5
Questions and Answers on Valves
Valve Quiz
Earthing Calculations
Electrical Earthing Calculations
A Question on Density Gauge
