Reading: PTFE lined 6” 300# butt weld end Plug Valves Leaks Stopped Forever
Inst Tools > Blog > Root Cause Analysis (RCA) > PTFE lined 6” 300# butt weld end Plug Valves Leaks Stopped Forever
Root Cause Analysis (RCA): Urea Plant tight shut off impossible PTFE liner 6” 300# butt weld end Plug Valves leaks stopped.
Last updated: September 28, 2022 3:15 pm
S Raghava Chari
2 Min Read
Root Cause Analysis (RCA): Urea Plant tight shut off impossible PTFE liner 6” 300# butt weld end Plug Valves.
Author ObservationAuthor Solution
Article Type:Root Cause Analysis (RCA)
Category:Mechanical
Equipment Type:Pipelines and Miscellaneous Problems
Author:S. Raghava Chari
Author Observation
He disassembled the heaviest passing valve. A steel scale showed dented taper – the cause of the leak.
Obviously, the 6 mm wall thickness hollow plug caves in under closed condition line condensate pressure; hence the leaks
Author Solution
On his insistence, the vendor after few futile repair attempts furnished solid taper plugs. Passing Problems vanished forever.
Author: S. Raghava Chari
  • Leaking Plug Valves
  • Flange Joint Problems
  • Pipe Elbow Sudden Burst
  • Fan Motor Journal Bearing Failures
  • Fired Boiler Induced Draft Fan Failures
RCA – Compressor Did Not Trip on Suction Pressure Low Low
Heat Exchanger Root Cause Analysis (RCA)
Discharge Head 3‑monthly leaks of Steam Turbine Driven Centrifugal Compressors
An Indian Plants all turbines’ low Vacuum & Saudi Plant turbo-compressor only
Inability to Test Repaired HT Motors in Workshop Posed Problems
Less than 40% available Plant Air Compressors made available 100% for Operations
Fan Motor Frequent Journal Bearing Failures Posed Plant Outages
Industrial Light Fittings and Street Light Poles Corrosion Problems
30 Electrical Engineering Problems – Root Cause Analysis
Control Valves Leak Tightness Restoration Pose Difficulties
Pump 3-monthly Seal Leaks threaten entire Plant Shut down Indefinitely
Thermocouple Wires and Extension Lead Issues
Poorly Engineered, built & often Failing Plant Air Compressor Drives
Cooling Tower Fans Frequently Failing
Centrifugal Compressor outage reduced
Centrifugal Compressor Outage Reduced – Root Cause Analysis
Compressor IP Case Discharge Temperature Gradually Increases
Reformer Tube Stress Relief Reusable Furnace
Miscellaneous Electrical Tasks – Repaired Reformer Tubes Weld Stress Relief
Wrongly terminated Thermocouple (TC) wires
Too Low-Temperature Readings after a Failed Thermocouple Change
Chemical Reactor Vessel P and ID
Wrong Operation Internals Destroyed Demineralization Mixed Bed Vessel
Innovative Segment Orifice
Stuck Segment Orifice Dimensions Calculations
repairs of welding cast refractory lined box over the hot spots
Primary Reformer RFG main Hot Spots threaten Indefinite Outage
Mechanical Engineering Plant Problems Solved
Mechanical Engineering Plant Problems Solved – Root Cause Analysis
PLC Analog I/O Potential Problems
PLC Analog I/O Potential Problems – Troubleshooting & Issues
Fire-Triangle-in-Gas-Detection-System
Basics of Fire Detection System
Loop Powered Pressure Transmitter
Electro Magnetic Flow Meter Animation
Digital Control Systems
Difference Equations
Basic Principles of Solar Technology
Air Lock Relay Working Principle
Control Valve Air Lock Relay Working Principle
pid-guidelines-for-pig-receivers
P&ID Guidelines for Pig Receivers
