Reading: Auto Tiffin Box Filling Station
Inst Tools > Blog > PLC Tutorials > Auto Tiffin Box Filling Station
Last updated: March 4, 2021 12:50 pm
3 Min Read
Hello Friend, today we will see how the food processing factory is packing the Tiffin box with the simple logic and timer-based process. These pack meals we enjoy in our day to day life.
Auto Tiffin Box Filling StationSetup
Figure (a) shows the HMI screen for the operator from where the operator can start and stop the process.
Here the system has 3 sensors which act when the box come below them and as per the screen shown the box will get filled with
HMI screen for operator
Figure(a) HMI screen for the operator
  1. The Cream at the bottom of the box
  2. The rice
  3. The paneer pieces on top
The cream gets fills when the Tiffin box moves on the conveyor towards left in progress with the filling of cream, rice and paneer pieces on top.
Here the conveyor belt is moving continuously. When we start the process. As we can see, there is a timer connected to the initial stage which means the filling of the Tiffin box should be done by the system in 60Sec. if the system fails to or any disturbance arises the system will display fault or jam in process parameter.
Setup
The proximity sensor near each SOV facing downward sense the Tiffin box as it comes under the sensor, according to individual sensing the SOV for 1 to 3 gets acts. The SOV (Solenoid coil ) acts on 24V DC.
As we give DO from the DCS, the Relay acts and SOV gets open.
  • SOV-1 to 3 DO’s initially in OFF state
  • Sensor 1 to 3 DI’s initially in ON stage
The below figure(b) & (c) shows the implementation and IO’s count assigned for the Program.
Auto Tiffin Box Filling Station Logic
Figure(b) Logic
DO assigned for the Logic
Figure (c) DO’s assigned for the Logic
DI assigned for the Logic
Figure (d) DI assigned for Logic
Author: Jadhav Amit R
  • Water Level Control Logic
  • Bottle Filling System
  • Troubleshoot PLC Logic
  • Lamp Control using PLC
  • Mixing using PLC Example
Scaling with Parameters (SCP) Instruction in PLC
CX Programmer Example: Perfume Mixing and Filling System
Omron PLC Timer Example Explained
Product Painting PLC Program using Omron CX-Programmer
PLC Programming Examples on Industrial Automation
Best Practices of PLC Wiring – Programmable Logic Controller
Simulation of Studio 5000 and FactoryTalk View Studio
Communication between InTouch Scada and Allen Bradley PLC
PLC based Gas Detection System using Ladder Logic Project
S7-1200 Hardware Configuration – Siemens PLC Tutorials
PLC Program to Control a Water Pump
Rewire Tool
What is Rewire Tool in Simatic Manager?
Sequencer Output in PLC
PLC Sequencer Instruction with Example
21 CFR in SCADA and HMI Systems
What is 21 CFR in SCADA and HMI Systems?
Two Hand Press PLC
Two Hand Press Safety Control Circuit
How CPU Execute Program in Siemens PLC?
Download Free HMI software – CODESYS
Preventa XPS MC, XPS MP - Safety controllers
High-end Programmable Logic Controller – Schneider PLC
Turbine Meter in Gas Metering System
Read Gas Composition from Gas Metering System using RS485 Protocol
Helix Bimetallic Thermometer Principle
Temperature Controller
What is a Temperature Controller? – How to Choose?
Top 100 Power Electronics Questions & Answers
hipps
What is High Integrity Pressure Protection System?
Normally closed input actuator as stop button.
Normally-Closed Contacts for Stop Buttons
Read Only Memory (ROM) Objective Questions – Part 3
Digital Logic Gates TruthTables
Logic Gates
