Reading: A Plant Bucket Elevators chains too short chain lives problem eliminated
Inst Tools > Blog > Root Cause Analysis (RCA) > A Plant Bucket Elevators chains too short chain lives problem eliminated
Root Cause Analysis (RCA) related to a Plant Bucket Elevators chains too short chain lives problem eliminated.
Last updated: September 28, 2022 3:15 pm
S Raghava Chari
2 Min Read
Bucket Elevators ProblemAuthor RCAAuthor found solutionRCA solution Benefits
Article Type:Root Cause Analysis (RCA)
Category:Mechanical
Equipment Type:Pipelines and Miscellaneous Problems
Author:S. Raghava Chari
For no immediately seen reasons Bucket Elevators chain lives were poor.
Author RCA
After few thinking days the author concluded, since all else are OK excessive chain overload could be a cause. Buckets running ¾ full against the thumb rule of max ½ full supported this surmise.
The author got 30 mts of elevator delivery collected and weighed. Indeed, the conveying rate was 2½ times design rate
Since all else are OK excessive chain overload could be a cause. Buckets running ¾ full against the thumb rule of max ½ full supported this surmise.
Proper process adjustments reduced the fill to 40% and thus the conveying rate was 80% of design production loss. Chain lives exceeded four years.
Author: S. Raghava Chari
  • Gas Cooler Re-tubing
  • Finned Tube Steam Leaks
  • Problems with Demister Pads
  • Bucket elevators teeth wear Problems
  • Centrifugal Compressor Shaft Vibration
Welding Machine Fail in Dusty and Corrosive Areas
Mechanical Engineering Plant Problems Solved – Root Cause Analysis
Control Valves – Repeat Actuator Diaphragm Bursts
Too often done riskily repaired Roof Hot Spots eliminated forever
Captive Power Plant Trip Root Cause Analysis
Urea Reactor Top Bolted Plug developed Leaks
Boiler Feed Water Heater Shell Flange Leaks
Control Panel Instruments Problem Threatened Plant Shutdown
Root Cause Analysis – Burst Transformers and 11 kV Input Breakers
Root Cause Analysis of Differential Pressure Level Transmitter
High-pressure Service Level Transmitters Misunderstood Zero Drifts
Repeat Safety Valve Popping caused Urea Plant Shutdown
Target Flow Transmitters Failed the Very Midnight
Centrifugal Compressor Shaft Vibrations Problem
Alternate 110 KV Connection to Feeder A
Innovative Segment Orifice
Pitot-tube Replaced with Innovative Segment Orifice Plate
On Off Valve Root Cause Analysis
Root Cause Analysis for FRP Line Damaged due to On-Off Valve
Induced Draft Cooling Tower
Cooling Tower fan FRP fan blades saves and saves
Unstable & Drifting Values of Differential Pressure Transmitter
Unstable & Drifting Values of Differential Pressure Transmitter Problem
Totally Enclosed Fan Cooled (TEFC) Motor
Totally Enclosed Fan Cooled (TEFC) Motors Rampant Winding Burnouts
11 KV Bus A to Bus B Phase Check Problem
Time Response Analysis
State Variable Analysis – Part II
Advantages and Disadvantages of Slip Ring Induction Motor
Overhead Product Pressure Control Loop
Typical Switchyard Layout
Electrical Substation – Busbar Arrangements and Layouts
OPC Protocol
History of OPC Protocol
Circular Chart Recorder
How to Read Circular Chart Recorder for Flow Measurement?
Solenoid Valve Troubleshooting
Solenoid Valve Troubleshooting Tips
Thyristor Family Quiz
