Reading: Why Calibration is Important?
Inst Tools > Blog > Calibration > Why Calibration is Important?
Calibration plays an important role in quality control. If an instrument is not calibrated we may suffer loss of our health, money or safety.
Last updated: September 28, 2022 3:26 pm
Saurabh Vaidya
Calibration
3 Min Read
Imagine, one day you go to a doctor for checking your blood pressure and after checking your blood pressure with a digital blood pressure monitor or sphygmomanometer, it is found that your blood pressure is high.
So the doctor prescribes medicine for high blood pressure. After a few days, it was observed that the machine itself was not displaying its reading properly. It means all given prescriptions given to patients could be wrong.
Imagine you went to the gold shop for buying gold. And ask for 10 grams of gold. He weighs using a Digital weighing balance and sold it to you. Some customers observed that the weighing balance is displaying the wrong readings.
Imagine the pressure gauge of the boiler is showing the wrong reading and you are standing beside it. It may burst due to high pressure and you never know because of the wrong display on the pressure gauge.
Imagine the temperature monitoring system of the Incubation chamber of babies is showing the wrong temperature. It will cost the lives of babies.
During the Ganesh festival, police uses the instrument sound level meter for measuring noise pollution. If the sound level meter is not calibrated it will show wrong readings and correspondingly wrong measures would be taken.
Calibration plays an important role in quality control of any product.
From the above examples, we can conclude that calibration plays a vital role in the day to day activities.
If instruments are properly calibrated, we can avoid all the circumstances mentioned above.
Hence, the calibration of instruments plays a important role in our lives.
So next time whenever you go to the market or use any instrument check for its calibration.
The above picture shows two different markings on the same length scales, if we use wrong scale then it would lead to measurement errors.
  • History of Measurement
  • Selection of Master Instrument
  • Importance of Unit Measurement
  • Reliability Centered Maintenance
  • What Every Instrument Engineer Should Know?
Practical Calibration Standards
Oxidation-Reduction Potential (ORP) Sensor Calibration Procedure
Calibration MCQ – Terminology and Glossary Questions
Control Valve Stroke Test Procedure
Calibration of Temperature Sensor with Indicator
Level Transmitter Calibration Procedure
Smart Transmitter Calibration Tutorial Part 3
Displacer (buoyancy) Level Transmitter Principle, Limitations, Design, Installation & Calibration
Solenoid Valve Functional Testing
Stroke Checking Procedure for GCV, SRV, IGV, and LFBV
RTD Testing Methods
RTD Testing Methods in Calibration Laboratory
process chemical analyzer calibration
Automated Calibration
Pressure Safety Valve Leak Test Procedure
Pressure Safety Valve Leak Test Procedure (PSV Testing)
Calibration of Measuring Instruments
Calibration of Measuring Instruments – Significance, Costs & Risks
H & B Gas Analyzer Principle and Calibration Procedure
Closed-tank-DP-Level-Transmitter-with-wet-leg-Zero-elevation-Calibration
Closed tank DP Level Transmitter with wet leg Zero elevation Calibration
Sample Raw DataSheet for Pressure Calibration
Instrumentation Project Documents
List of Instrumentation Project Engineering Documents
High Voltage and Power System Stability Interview Questions
Card Failures in Automation Panels
Automation Panel Electronic Cards Failure investigation
Parallel RLC Circuit
Impedance in RLC Circuits
Common Valve Abbreviations
Common Valve Abbreviations in US Engineering Drawings
Industrial Instruments Questions and Answers
Applications of Digital Control Valves
Digital Control Valves – Introduction, Principle, Setup, Applications
HART Communication Tutorial 2
