Reading: What is an RTU? – Remote Terminal Unit
Inst Tools > Blog > PLC Tutorials > What is an RTU? – Remote Terminal Unit
An RTU is another form of a PLC. RTU stands for Remote Terminal Unit. It is also called a remote telemetry unit.
Last updated: September 28, 2022 4:10 pm
In this article, we will understand the concept of RTU.
What is an RTU?Application of Remote Terminal UnitAdvantages of Remote Terminal Unit
The RTU name is derived from two purposes
  • RTU is used in remote plant locations (remote) and
  • RTU transfers data with wider telemetry through wireless communication.
It is for this reason that RTU is generally used to interface the system with SCADA or other graphic control systems. Also, RTU can also use wired communication protocols as per the application requirement.
What is an RTU?
What is an RTU - Remote Terminal Unit
RTU connects field devices similar to a PLC like sensors, motors, actuators, and other instruments. It has a software setup that needs to be run in it to configure the IO’s and control the data flow accordingly.
But, some RTU’s have similar programming languages like ladder logic, structured text, etc., and also other computer languages like C++, Visual Basic, etc.
As the name denotes, RTU is used for remote setup locations. Consider an oil rig area or pipelines where human presence is very less or even negligible sometimes.
The central control room is located miles away from it and it needs data from the controller to monitor and control.
RTU is used in this case as its physical locations are tough, rugged, and specifically designed for such an environment. Also, due to distance criteria, wireless communication serves as the best mode of data transport.
RTU consumes less power as compared to a PLC. Also, they work on different voltage potentials; not just limited to 24V DC or 230V AC. One of the main reasons for such a design is its location.
There are cases when the power supply is very less and is not enough to drive a controller. In such cases, RTU serves as a good option, and also, they work on batteries for power consumption. Mostly, solar power is used as a main power source for the RTU systems.
RTU works on event-triggered cycles. That is, when a request is received from the client (SCADA or other graphical control in this case), then it sends data to it.
Also, it is possible that many times, due to its location, communication may be weak. So, an RTU has automatic data and history storage facility
RTU stores the data from IO devices in it as historical time and date stamp format, which makes it possible to transmit any requested data to the client.
RTUs can be customized for adding any communication module, IO module, extra data storage, batteries, and backup power.
There are select brands in the market that manufactures an RTU and run successfully. Some of the most used ones are
  • ABB,
  • Schneider,
  • GE Grid Solutions,
  • Honeywell,
  • Siemens Energy
  • Yokogawa, etc.
  • PLC versus SCADA
  • Compare PLC and RTU
  • Electrical Wiring Diagram
  • What is 21 CFR in SCADA?
  • Safety Barrier in PLC System
Schneider PLC Example: Control Lamps Sequences
What is a Line Choke or Reactor in a VFD?
OFF Delay Timer using PLC
PLC Structured Text Program for Output Generation via Equations
PLC Programming Example on Bottle Line Control
How to Create New Project in Studio 5000?
PLC Motor Operation based on Time Cycle Sequence – Program
Oil and Water Separation Process using PLC Programming
Run 4 Motors Sequentially from Same Push button PLC Program
Automatic Coffee Vending Machine – PLC Logic Programming
PLC Counters Program
PLC Sequence Programming Ladder Logic
Industrial PLC Communication Network
Basics of Industrial Communication Networks
TP Timer in CodeSys
Timers in Codesys – Timer ON, Timer OFF, Pulse Timer
PLC Stop - Start Circuit
Introduction to PLC Ladder Diagrams
PLC Circuit with Switches
PLC Example with Switches
Studio 5000 Define Program or Operator Control in Functional Block Diagram
Studio 5000: Define Program or Operator Control in Functional Block Diagram
Faceplate in WinCC
Siemens HMI Training – Using UDTs with Faceplates
Anti-static Wrist Straps
Random Access Memory Objective Questions – Part 4
PLC Math instructions
Gas-chromatograph-Working-Principle
Gas chromatograph Working Animation
Poppet vs Spool Valves
Why Valve Type Matters ? Poppet vs Spool Valves
Quadrupole Mass Spectrometer
Hammer Handwheel
Valve Handwheel Types : Fixed, Hammer, Gear
PID control block located in fieldbus transmitter
Foundation Fieldbus Device addressing
Left-Hand Rule for Generators
Starting of DC Motors
