Reading: What is a Turbine Flow Meter?
Inst Tools > Blog > Flow Measurement > What is a Turbine Flow Meter?
Turbine flow meter use a free-spinning turbine wheel to measure fluid velocity, much like a miniature windmill installed in the flow stream.
Last updated: November 2, 2023 6:21 am
Flow Measurement
9 Min Read
Turbine flow meters use a free-spinning turbine wheel to measure fluid velocity, much like a miniature windmill installed in the flow stream.
Turbine Flow MeterConstruction of Turbine Flow MeterDisadvantagesAdvantagesFormula
Turbine Flow Meter
The fundamental design goal of a turbine flow meter is to make the turbine element as free-spinning as possible, so no torque will be required to sustain the turbine’s rotation.
If this goal is achieved, the turbine blades will achieve a rotating (tip) velocity directly proportional to the linear velocity of the fluid, whether that fluid is a gas or a liquid:
Turbine Flow meter Principle
The mathematical relationship between fluid velocity and turbine tip velocity – assuming frictionless conditions – is a ratio defined by the tangent of the turbine blade angle:
Turbine Flow meter Equation
For a 45 deg blade angle, the relationship is 1:1, with tip velocity equaling fluid velocity. Smaller blade angles (each blade closer to parallel with the fluid velocity vector) result in the tip velocity being a fractional proportion of fluid velocity.
Turbine tip velocity is quite easy to sense using a magnetic sensor, generating a voltage pulse each time one of the ferromagnetic turbine blades passes by. Traditionally, this sensor is nothing more than a coil of wire in proximity to a stationary magnet, called a pickup coil or pick-off coil because it “picks” (senses) the passing of the turbine blades.
Also See: Turbine Flow meter Animation
Magnetic flux through the coil’s center increases and decreases as the passing of the steel turbine blades presents a varying reluctance (“resistance” to magnetic flux), causing voltage pulses equal in frequency to the number of blades passing by each second. It is the frequency of this signal that represents fluid velocity, and therefore volumetric flow rate.
A cut-away demonstration model of a turbine flow meter is shown in the following photograph.
The blade sensor may be seen protruding from the top of the flow tube, just above the turbine wheel:
Turbine Flow Meter Construction
Note the sets of “flow conditioner” vanes immediately before and after the turbine wheel in the photograph. As one might expect, turbine flow meters are very sensitive to swirl in the process fluid flow stream.
In order to achieve high accuracy, the flow profile must not be swirling in the vicinity of the turbine, lest the turbine wheel spin faster or slower than it should to represent the velocity of a straight-flowing fluid.
A minimum straight-pipe length of 20 pipe diameters upstream and 5 pipe diameters downstream is typical for turbine flow meters in order to dissipate swirl from piping disturbances.
Disadvantages
Mechanical gears and rotating cables have also been historically used to link a turbine flow meter’s turbine wheel to indicators. These designs suffer from greater friction than electronic (“pickup coil”) designs, potentially resulting in more measurement error (less flow indicated than there actually is, because the turbine wheel is slowed by friction).
Advantages
One advantage of mechanical turbine flow meters, though, is the ability to maintain a running total of gas usage by turning a simple odometer-style totalizer. This design is often used when the purpose of the flow meter is to track total fuel gas consumption (e.g. natural gas used by a commercial or industrial facility) for billing.
Formula
In an electronic turbine flow meter, volumetric flow is directly and linearly proportional to pickup coil output frequency. We may express this relationship in the form of an equation:
Turbine Flowmeter Formula - 1
Where,
f = Frequency of output signal (Hz, equivalent to pulses per second)
Q = Volumetric flow rate (e.g. gallons per second)
k = “K” factor of the turbine element (e.g. pulses per gallon)
Dimensional analysis confirms the validity of this equation. Using units of GPS (gallons per second) and pulses per gallon, we see that the product of these two quantities is indeed pulses per second (equivalent to cycles per second, or Hz):
Turbine Flowmeter Formula - 2
Using algebra to solve for flow (Q), we see that it is the quotient of frequency and k factor that yields a volumetric flow rate for a turbine flow meter:
Turbine Flowmeter Formula - 3
The inherent linearity of a turbine flow meter is a tremendous advantage over nonlinear flow elements such as venturi tubes and orifice plates because this linearity results in a much greater turndown ratio for accurate flow measurement.
Contrasted against common orifice-type meters which are usually limited to turndown ratios of 4:1 at best, turbine meters commonly exceed turndown ratios of 10:1.
If pickup signal frequency directly represents volumetric flow rate, then the total number of pulses accumulated in any given time span will represent the amount of fluid volume (V ) passed through the turbine meter over that same time span.
We may express this algebraically as the product of average flow rate (Q), average frequency (f), k factor, and time:
Turbine Flowmeter Formula - 4
A more sophisticated way of calculating total volume passed through a turbine meter requires calculus, representing change in volume as the time-integral of instantaneous signal frequency and k factor over a period of time from t = 0 to t = T:
Turbine Flowmeter Formula - 5
We may achieve approximately the same result simply by using a digital counter circuit to totalize pulses output by the pickup coil and a microprocessor to calculate volume in whatever unit of measurement we deem appropriate.
As with the orifice plate flow element, standards have been drafted for the use of turbine flowmeters as precision measuring instruments in gas flow applications, particularly the custody transfer of natural gas.
The American Gas Association has published a standard called the Report #7 specifying the installation of turbine flow meters for high-accuracy gas flow measurement, along with the associated mathematics for precisely calculating flow rate based on turbine speed, gas pressure, and gas temperature.
Pressure and temperature compensation is relevant to turbine flow meters in gas flow applications because the density of the gas is a strong function of both pressure and temperature. The turbine wheel itself only senses gas velocity, and so these other factors must be taken into consideration to accurately calculate mass flow (or standard volumetric flow; e.g. SCFM).
In high-accuracy applications, it is important to individually determine the k factor for a turbine flow meter’s calibration. Manufacturing variations from flow meter to flow meter make precise duplication of k factor challenging, and so a flow meter destined for high-accuracy measurement should be tested against a “flow prover” in a calibration laboratory to empirically determine its k factor.
If possible, the best way to test the flow meter’s k factor is to connect the prover to the meter on site where it will be used. This way, the any effects due to the piping before and after the flowmeter will be incorporated in the measured k factor.
  • Types of Flow Meters
  • V Cone Flow Meter
  • Target Flow meter
  • MCQ on Flow Sensors
  • Orifice Plate Tapping
Turbine Flow Meter Coefficient and Scaling Factor
Square-root characteristics of Differential Pressure Flow Meters
Turbine Flow Meter Installation Procedure
Microwave Flow Sensor – Working Principle and Applications
Lobed Impeller Flow Meters Working Principle
What is a Weigh Feeder?
  • SureshBabu J says:
    October 31, 2018 at 2:29 pm
    Sir
    My name is SureshBabu from india. I have small doubt based on turbine flowmeter.
    Whether turbine flowmeter for liquid service requires temperature compensation (or) not?
Difference between Different Types of Flow Meters
Basics of Restriction Orifice (RO) – Types, Applications, Standards
Phase Watcher Multiphase Flow Meter (MPFM) Procedure
Principle of Flow Switch
Pressure Temperature Compensation Flow Measurement
All About Turbine Meters
Flow Meter K-factor and Calculations
Orifice Flange Rating
Why Orifice Flow Meter Flange is Not Recommended 150# Rating?
What is an Orifice Flange ?
What is an Orifice Flange? – Purpose and Applications
Vortex Flow Meter Animation
Magnetic Flow Meter Corrosion Effects
Open Channel Flow Measurement Animation
Open Channel Flow Measurement Principle
Insertion flow meters
What is an Insertion Flow Meter? – Types, Principle, Advantages
Flow Switch Working
Flow Switch : What is it? – Applications
Integral Orifice Parts
What is Integral Flow Orifice Assembly?
Root Locus in Control Systems
Ionization chamber Working
Ionization chamber Principle
Valve Software
Free Control Valve Software Download
Stop Check valve
What is Stop Check valve ?
Components of Electrical Motor
What is Electrical Slip Ring? Principle, Types, Advantages, Applications
The Best HVAC System for Home
Which HVAC System is Best for Home?
Single Phase Preventer Relay
Working Principle of Single Phase Preventer Relay
How to Create Faceplate in FactoryTalk View Studio
How to Create Faceplate in FactoryTalk View Studio?
