Reading: Conversion of Transmitter Output in Percentage to Process Variable
Inst Tools > Blog > Instrumentation Tools > Conversion of Transmitter Output in Percentage to Process Variable
Last updated: November 12, 2019 3:48 pm
2 Comments
1 Min Read
Convert Transmitter Output in Percentage to Process Variable:
This tool is used to calculate the Process variable using transmitter output in percentage, URV & LRV of transmitter.
This calculation tool is used to find out the equivalent Process Variable using Tx output in %,URV & LRV.
Where,
PV = Process Variable
URV = Upper Range Value (Transmitter Max scale value)
LRV = Lower Range Value (Transmitter Min scale value)
Note:
1.For calculating the equivalent PV, we have to enter Transmitter output in %, URV & LRV details.
2.The above calculation tool designed for a standard 0-100% signal conversion.
3.You can convert out of range signal also with the above tool.
(Example: URV = 100, LRV = 0 and PV = 110)
Interface Level Measurement using DP Transmitter
Calculate Current (4-20ma) from Process variable PV
Convert Linear Percentage to Square root Percentage
Level Measurement with Dry leg and Installed Below Tapping Point
Differential Pressure (DP) Level transmitter Installed Above Tapping Point
Level Measurement with Wet leg and Installed Below Tapping Point
2 Comments
  • John Finklea says:
    May 2, 2017 at 8:19 pm
    Its not working?
    • S Bharadwaj Reddy says:
      May 3, 2017 at 3:33 am
      Hi, Its Working. Note : Press Enter button after typing the input values.
RTD Calculator : Calculate Resistance from Temperature
4-20 mA to Measurement Converter Tool
Convert current (4-20mA) to Percentage (0-100%)
Convert Percentage (0-100%) to current (4-20mA)
Density Measurement for Open Tank with Constant Level Application
Measurement Value to 4-20mA Signal Converter
DP Level Transmitter Calibration for Diaphragm Seal with Capillary
Convert Process Variable to Percentage
Density-Measurement-using-DP-Transmitter-for-Closed-Tank-Dry-Leg
Closed tank Density Measurement using DP Transmitter with dry leg & constant level application
Density-Measurement-using-DP-Transmitter-for-Closed-Tank-Wet-leg
Density Measurement using DP Transmitter for closed tank with wet leg
instrumentation-calculator
Instrumentation Calculator
Convert Linear mA to Square root mA
0-20 mA Analog Signal to Measurement Converter Tool
RTD Calculator : Calculate Temperature from Resistance
DP-Level-Measurement-Calculation-Below-Tapping-Point-Open-Tank
Differential Pressure (DP) Level transmitter Installed Below Tapping Point
mA-Conversion-Tool
Transmitter Current Conversion Tool
Manual Call Point Testing Procedure
P&ID
Over Pressure Protection Devices
Analog Electronics Objective Questions – Set 3
The Hardware Structure of DCS
DCS Applications and Hardware Structure of Plant Automation
Electrical Symbols
Electrical Symbols
Digital Electronics Objective Questions – Set 9
Fieldbus Transmitter Calibration
7 OSI Layers of Communications
