Reading: How to Test TRIAC with Multimeter
Inst Tools > Blog > Power Electronics > How to Test TRIAC with Multimeter
Last updated: September 19, 2016 4:10 am
Power Electronics
7 Comments
2 Min Read
How to test TRIAC with Digital Multimeter OR using Ohmmeter?
In this short post we will discuss about how to test the Triac.
triac
Introduction about Triac:
  1. TRIAC = TRIode for Alternating Current.
  2. The TRIAC is 5 layer, 3 terminal Power semiconductor device.
  3. It has a pair of phase controlled SCRs connected in inverse parallel manner on the same chip.
  4. It is a bidirectional device, means it can conduct current in both the directions.
Procedure to test the TRIAC
Step by step Procedure to test the triac:
  1. Keep the digital multimeter into Ohmmeter mode.
  2. Using a junction diode determine which ohmmeter lead is positive and which is negative. The ohmmeter will indicate continuity only when the positive lead is connected to the anode and the negative lead is connected to the cathode.
  3. Connect the positive lead of Ohmmeter to MT2 and the negative lead to MT1. The ohmmeter should indicate no continuity through the triac.
  4. Using a jumper lead connect the Gate of the Triac to MT2. The multimeter should indicate a forward diode junction.
  5. Reconnect the Triac so that MT1 is connected to the positive lead of ohmmeter and MT2 is connected to the negative lead. The multimeter should indicate no continuity through a Triac.
  6. Using a jumper lead, again connect the gate to MT2. The ohmmeter should indicate a forward diode junction.
Top 100 Power Electronics Projects for Engineering Students
Thyristors – Working, VI Characteristics, Turn ON Methods
Types of IGBT
Basics of Thyristor
SCR Triggering Methods
IGBT – Symbol, Construction, Working, Characteristics, Advantages
7 Comments
  • Jesse says:
    March 9, 2020 at 10:26 pm
    I am currently testing a triac, I’m getting readings in megaohms across M1 and M2 , is that close enough to no reading or open?
    • Andres says:
      June 30, 2021 at 3:55 am
      I am getting readings around 50 ohm with floating gate pin. Mine obviously is damaged.
      You should test it with the diode option not the ohms.
      • Joe says:
        August 11, 2021 at 8:03 am
        hai andres.. What is the actual reading (ohm) for the triac after test. If still inbgood condition. Tq
  • Himynameis says:
    October 11, 2022 at 1:10 am
    I observed that one of the pins should conduct with the tab. If none conducts, you have a broken triac.
  • André Giguère says:
    April 15, 2023 at 4:49 am
    Very interesting article on how to test a TRIAC
  • S. X. says:
    September 19, 2023 at 4:51 am
    I have some new Triacs. Pin1, 2, 3 are A1,A2,G.
    50 Ohm is between A1 and G.
  • jose protacio says:
    May 9, 2024 at 8:02 am
    hi S.X.
    mine reads about 60 ohms forward and reverse A1 to G and its good
Thyristor Triggering Circuits – Types, Explanation, Waveforms (SCR)
Thyristor Protection Circuits (SCR) – Types, Principle, Explanation
Power Transistor – Structure, Biasing, Characteristics, Advantages
Introduction to Thyristor – History, Types, Principle, Advantages
How to test SCR using Multimeter
R R-C Firing Circuits Disadvantages
Phase Controlled Rectifier – Half Controlled Rectifier with R Load
Thyristors – Switching, Two Transistor Model, Advantage, Applications
SCR Class B Resonant-Pulse Commutation
Thyristor Commutation Techniques – Types, Working Principles
Phase Controlled Half Wave Rectifier RL Load
Power Electronics – Phase Controlled Half Wave Rectifier RL Load
Crowbar fault protection circuit
triac
Turning Off SCR – Commutation
RC snubber circuits
How Snubber Circuit works ?
Symbol of MOS Controlled Thyristor
MCT (MOS Controlled Thyristor) – Symbol, Working, Characteristics, Advantages
Single Phase Half-controlled Rectifier RL Load With FD
Phase-Controlled Half-Wave Rectifier With Freewheeling Diode
Free Download PLC Simulator using Excel
PLC Programming Sequence Logic
PLC Programming to Control Lights in a Sequence
reverse-biased varactor diode
Varactor Diode Operation
Uncertainty Calculations of Pressure Calibration
Fieldbus and Profibus
Difference between Fieldbus and Profibus
Difference Between Static and Temp Memory in Siemens TIA Portal
How to Convert Cable Size from AWG to Inches
PID Controller Tunning Manually
PID Controller Parameters Tuning Manually
