Reading: Steps in PLC System Design
Inst Tools > Blog > PLC Tutorials > Steps in PLC System Design
In this post, we will learn the most common steps in PLC system design to complete the project efficiently and properly.
Last updated: March 12, 2023 10:22 am
8 Min Read
PLC System DesignEnvironmental SpecificationsGrounding and EarthingSafety ConcernsNetworkingField Devices and IO CountProper Grouping of Devices according to Voltage Level in the PLC PanelField Wiring Voltage LevelsPLC Program Complexity and Redundancy
PLC is a very important component in industrial automation. PLC comes under the L1 level of industrial automation where it will process the field IOs and work according to the logic written in it. It is thus a very important component because without PLC, you cannot even work in higher levels like cloud networks or IoT; because they cannot work with field devices and get data from them.
So, you have to take care in designing a PLC system properly. There are many procedures, considerations and factors to be considered before choosing the best PLC system.
Try our PLC and SCADA Courses: Register Now
PLC System Design
Some of the most common steps which are important in the design of programmable logic controllers are mentioned below.
  1. Environmental Specifications
  2. Grounding and Earthing
  3. Safety Concerns
  4. Networking
  5. Field Devices and IO Count
  6. Proper Grouping of Devices
  7. Field Wiring Voltage Levels
  8. Program Complexity and Redundancy
As PLC is an electronic device, it has its share of environmental design constraints. Electronic components are sensitive to environmental effects and utmost care should be taken to see that it does not get damaged due to any abnormal surrounding effect. It must be able to perform to the specifications mentioned in its catalog.
Basic parameters include ambient temperature (operating and storage), relative humidity, operating altitude, and mechanical stress like vibrations majorly. Make sure to see that if you are installing a PLC in a particular area, then it must meet the nearby environment specifications.
If the climate is extremely hot or cold (which means outside the operating range), then choose a hard-rugged PLC which will meet those specifications.
Also, it is not necessary that only a PLC is required in such conditions. You can use additional supporting equipment near it like a fan, air conditioner, heater, or pneumatic cooler; to support it for such conditions.
Earthing and Grounding are very important criteria in designing a PLC system. It must be noted that improper grounding can result in physical hazards, electrical equipment damage, and worst case, even death.
A PLC has grounding points in its power supply and input and output terminals. When you are installing a PLC in a panel, ensure that the ground is connected at each and every point available.
As there are two types of earthing in a panel – instrument and power, PLC points must be connected to instrument earthing. It must not be connected to power earthing. The voltage between earthing and neutral must be less than 0.5V.
Safety Concerns
PLC is a device that deals with many critical field devices. In terms of safety, there are two types – one which PLC provides and one which PLC must be provided.
A PLC programmer must assign digital outputs for a hooter, fault lamp, tower lamp, and buzzer so that the operator will be alarmed whenever there is a fault. This can help save any untoward incident.
When you are using a PLC, a safety review must be performed at the actual site to see if the PLC will not be impacted by any mechanical, environmental, thermal, electrical, or chemical hazard.
If you go ahead, there is one more advanced device called safety PLC. It has SIL level functionalities that deal with various types of IO safety and programming safety. Safety PLC can detect any permutations and combinations of failures to safely shutdown a system.
Networking
Almost all the PLCs deal with external communications with third-party or same-party devices. As communication provides more flexibility in dealing with data, many protocols are used for communication with field devices, SCADA, etc.
Because communication is sensitive to noise and other electrical disturbances, care must be taken to properly choose its cable with shielding. Also, in such cases, earthing must be very strong to prevent any unwanted noise near it.
Additionally, if you are using Ethernet protocol, it is recommended to provide an Ethernet hub switch in the panel, managed or unmanaged, so that many people can use data from it.
When you are choosing a PLC, you must be knowing the number of IOs and field instrument types. It is important to have proper knowledge of the voltage and current required for working with field devices.
Depending on that, you have to choose the required PLC and also the cabling length. Also, consider 20% spare in the IO counts, which will give you flexibility in case of end-time additions in IOs.
If the distance between PLC and the field device is more or if the PLC will be installed in a hazardous area, then install barriers and isolators in the panel. Also, for analog IOs, use proper shielded cables as they are more prone to noise.
Building a PLC Panel from Scratch - Industrial Control Panel
This factor is concerned with panel designing. Make sure to group AC and DC devices like circuit breakers, relays, terminal boards, power supplies, and transformers.
Avoid mixing them in the PLC panel; this means it is not advisable to place a circuit breaker near the PLC. Better keep isolation between devices of the same voltage level. This will also help in troubleshooting and avoiding unwanted performance and noise in the panel.
If AC and DC devices are separated and kept in groups, then the panel also will look more attractive and you can easily identify each and every device properly.
In your PLC panel, you are using both AC and DC voltages. If a particular field device is powered by a separate power source, make sure to use its common point for working with it.
Avoid mixing up unwanted common signals with field devices; otherwise, it will either damage the PLC point or will damage the field device.
If you know the complexity of the PLC program to be developed or if redundancy is required, then choose the PLC accordingly. It must be able to perform in the required scan time, memory and redundancy.
In this way, we understand some general steps in properly designing a PLC system.
  • How to Choose a PLC?
  • How to Choose a SCADA?
  • Compare PLC and SCADA
  • PLC and DCS System Checks
  • DCS System Maintenance
Job Skills Required for Industrial Electrical Maintenance
Yokogawa DCS Tutorials – Configuration of Analog Input (Transmitter)
How to Create New Project Using Simatic Manager
Ladder Logic Example of Two Motors Interlinked with another Motor
Allen Bradley PLC Subroutines
Introduction to Functional Block Diagram in Studio 5000
Siemens Drum block for Sequencer Operation
1oo2 Evaluation Safety Instruction in Safety PLC
Lamp Control using PLC Logic Condition
Redundant system communication cable
What is Interface Module in Siemens PLC?
How to export in Vijeo Designer
Vijeo Designer software – Import and Export
relay-safety-in-plc
How to Reduce Relay Noise in PLC Systems?
SCADA System Vulnerabilities
Pneumatic Circuit Design Using PLC - 2
PLC Pneumatic Circuit Control
Flip-Flop PLC Program for Lamps Application
Example of Flip-Flop PLC Program for Lamps Application
Types of PLC Memory
Types of PLC Memory
PLC Programming in Hindi - Siemens Tia Portal Full Course
Emergency ShutDown Valve Working Principle
ESDV : How it Works ?
Flow Switch Principle
In-Line Flow Switch Working Principle and Animation
Thermowell Wake Frequency Calculation
Telemetry Systems Objective Questions
3-15 psi to 4-20mA Conversion
Example of 3-15 psi to 4-20mA Conversion
Frequency Response MCQ
Experimentation of Transfer Function
Functional Safety Terms in Industrial Automation
Functional Safety Terminology in Industrial Automation
Ultrasonic Level Switch Principle
