Reading: SIS System Testing – Safety PLC
Inst Tools > Blog > Safety Instrumented System (SIS) > SIS System Testing – Safety PLC
Safety Instrumented System (SIS) System testing is an important activity to follow the required Quality control achieved for the safety PLC.
Last updated: May 27, 2022 1:23 pm
Safety Instrumented System (SIS) System testing is an important activity to follow the required Quality control achieved for the system.
SIS System TestingNeed for Safety Instrumented System TestingMethods to Improve SIS System TestingSIS System Testing MethodologiesSIS System Testing DocumentationFault Rectification & Punch ListConclusion
SIS testing ensures that all planned, designed aspects of SIS are covered.
SIS System Testing
Below are the brief tests to be followed:
  • Checking the system behaves as per Safety Requirement Specification (SRS)
  • Diagnosing faults, errors, and unexpected behaviors
  • Rectifying non-conformance (if any) with the design
SIS System Testing - Safety PLC Control System
Testing a virtually error-free system doesn’t consume much time, the project can follow the schedule & avoid delays.
A robust testing plan can help to discover and rectify faults (if any) well before commissioning.
Non-conformance of the SIS system leads to complete re-work of hardware manufacturing, installation, testing, and commissioning.
Engineering efforts will be more and results in higher project expenditure.
Logic solver memory may be a challenge when the new program is created due to non-completion of testing and eventually ending up with major software logic change.
  1. Various SIS tests (viz. Hardware test) need to be integrated with the overall plan.
  2. Development of accurate SRS that includes complete design, and test information.
  3. The project team needs to undergo various checks by different disciplines at the appropriate time as per Safety Requirement Specification (SRS).
  4. Need to implement strong change management for better SIS delivery and plant operation.
  5. Testing procedures to be made clear for Commissioning Startup, Operations, and Maintenance teams so that the schedule can be met without delays.
Plan to be developed with clear scope & objectives for all test needs for SIS system testing.
Below are different tests that need to be performed.
  • Hardware Acceptance
  • Field device operation test
  • Vendor shop QC tests.
  • Factory Acceptance Test (FAT)
  • Software template review test
  • Software Factory Acceptance test / Software Acceptance test
  • Code confirmation tests
  • Different skid packages acceptance test
  • Mechanical completion test at different stages to ensure the construction is done with the best standards.
  • Site inspection, Power up tests
  • System integrated function test
  • Communication protocol test (to Confirm SIS communication with DCS or 3rd party system)
  • System Integrated function test.
  • Site Acceptance Test (SAT)
System testing procedure document to be prepared upfront before the start of the test.
All the above-mentioned test documents are to be signed off by the testing Engineer with a witness Engineer/Operator/Maintenance supervisor/Technician who is involved in these testing.
All individual testing procedures shall have Passed/Not passed/Comments if any.
Maintain final SRS, Cause & Effect Matrix, Logic narratives/drawings, wiring loop drawing for check ahead of tests.
Master test document to be maintained and any update/ changes per comments need to be signed off by respective personnel.
With the above SIS, system testing keeps below records for tracking the punch list and closing out as there could be any fault found during the test.
A few punch list review tracking details are as follows.
  1. Safety functions that have been completed & all open points completed.
  2. System errors diagnosed and updated.
  3. Safety functions tested with different combinations (viz. if 2oo3 trip, check all combinations).
  4. Any software bug identified and corrected.
  5. Communication protocol tests with different systems/vendor packages through PLC, HMI, and OPC were verified & communications data flow was confirmed within the acceptable time limit.
Conclusion
Thus it is important to perform the SIS system testing in order to ensure that no faults exist in hardware, software application program, and communication with the other systems.
Completion of all such tests during the Design finalization & Engineering phase will assure the project’s successful completion per schedule.
  • What is HIPPS?
  • SIS Solenoid Valves
  • SIS Component Selection
  • Automated Block Valves
  • SIS Failures and Reliability
Process Safety and Instrumentation
SIS PFD – Safety Instrumented System
SIS Emergency Block Valves (EBV)
SIS Safety Requirements
SIS Example : Nuclear Reactor Controls
Understanding High Integrity Pressure Protection Systems (HIPPS)
Functional Safety Questions & Answers
Emergency Shutdown Valve : Advantages
SIS Testing and Repair Deferral
What is Proof Testing? – How to do a Proof Test? – Importance, Methods
SIS Instrument Sharing – Transmitters Shared for BPCS and SIS Example
Reliability of a Control System
SIS Design – Safety Instrumented System
Emergency Shutdown Button Installation (ESD)
Emergency ShutDown Valve Working Principle
ESDV : How it Works ?
Difference between SIS, PLC and BPCS Systems
Selecting a SIS or SIL Level
Importance of Safety Integrity Level
Project Management of Safety Instrumented System
Project Management of Safety Instrumented System (SIS)
What is Partial Stroke Test
What is Partial Stroke Test?
Safety Instrumented System Interview Questions Answers
Burner Management System (BMS) Principle
What is Burner Management System (BMS)?
Simple RC Circuit
Impedance in RC Circuits
Characteristics of Transducers Objective Questions
Starting of Polyphase Induction Motors Quiz
Power Systems MCQ Series 11
Applications of Robots
Applications of Robots in Various Fields
Transistor Collector Feedback Bias
How to Use SMD Components in Electronic Circuits
How to Use SMD Components in Electronic Circuits?
LVR Motor Controller Operation
Low Voltage Protection (LVP) and Low Voltage Release (LVR)
