Reading: Shutdown Motors in Timed Operation PLC Program
Inst Tools > Blog > PLC Tutorials > Shutdown Motors in Timed Operation PLC Program
Write a PLC program to start three motors at the same time and shutdown the motors in a timed sequence operation using ladder logic.
Last updated: March 4, 2021 11:27 am
Write a PLC program that when a start push button is pressed all the 3 motors are ON and after 3 seconds the first motor shutdowns automatically, then after 7 seconds the second motor shutdowns automatically, and after 12 seconds the last motor shutdowns automatically. At any time if the stop pushbutton is pressed all the three motors are shutdown.
Shutdown Motors in Timed OperationS_PEXT InstructionPLC Program description
Note the best practice to learn the PLC programming is to start writing the PLC program, take your time before you review the answer.
Inputs and Outputs
I0.0: start push Button (Normally open contact)
I0.1: Stop Push Button (Normally Closed Contact)
Q0.0: Motor 01
Q0.1: Motor 02
Q0.2: Motor 03
T1: Timer 01
T2: Timer 02
T3: Timer 03
S_PEXT Instruction
S_PEXT (Extended Pulse S5 Timer) starts the specified timer if there is a positive edge at the start (S) input. A signal change is always necessary in order to enable a timer.
S_PEXT timer block
The timer runs for the preset time interval specified at input TV even if the signal state at the S input changes to “0” before the time interval has elapsed. The signal state at output Q is “1” as long as the timer is running.
The timer will be restarted (“re-triggered”) with the preset time value if the signal state at input S changes from “0” to “1” while the timer is running.
The timer is reset if the reset (R) input changes from “0” to “1” while the timer is running. The current time and the time base are set to zero.
 Network 1:
  • When the start PB is pressed the “timer 01” is energized and starts to count 3 seconds and runs the “motor 01” for 3 seconds.
  • The PEXT is used because the start signal is a pulse as it is a push-button (PB).
  • When the stop PB is pressed at any time the timer 01 resets and shutdowns the motor 01.
Note: When we press the Start pushbutton for the first time, then all the motors will be turned ON and runs. In the next networks, I am discussing what will happens for the first time when we press the start push-button.
Network 2:
  • When the start PB has pressed the timer 02 is energized and starts to count 7 seconds and runs the “motor 02” for a 7seconds.
  • When the stop PB is pressed at any time the “timer 02” resets and shutdowns the motor 02.
Network 3:
  • When the start PB is pressed the timer 03 is energized and starts to count 12 seconds and runs the “motor 03” for a 12seconds time.
  • When the stop PB is pressed at any time the timer 03 resets and shutdowns the motor 03.
Note: For our simple example, we used motors shutdown time in seconds. In practical industrial applications, it will be in hours, minutes, and seconds depends on our requirements.
Author: Karim Ali Anwar
  • Motor Speed Control
  • Motor Clockwise Operation
  • What is Auto-closing?
  • Siemens Memory Cards
  • Online & Offline Logics
Create User-Defined Data Types and Function Blocks in Studio 5000
Download Free HMI software – CODESYS
PLC Energize or De-energize the Outputs based on Events
Car Wash Program using Functional Block Diagram (PLC)
Advanced PLC Conveyor Control: Forward and Reverse Rotation
Top Automation Vendors from Around the World – An Overview
Siemens PLC Tia Portal – OB100 Start-up Organization Block
PID in Studio 5000
PLC Automatic Pedal Switch for Speed Control
Equivalent Logic Gates using PLC Ladder Diagrams
PLC Tag Naming Conventions
Siemens Communication between PLCs using I-Device
Tutorial: Siemens Communication between PLCs using I-Device
Industrial Gas Detection Systems
PLC based Gas Detection System using Ladder Logic Project
Power Supply Sizing for Industrial Automation Systems
Split Range Control Block Diagram
Split Range Control Application using PLC Ladder Logic
LED Indications on PLC
Getting to Know the LED Indications on GE Make PLC
Motor Clock Wise Operation using PLC
CW and CCW Operation of Motor from Same Push button
PLC Software Redundancy
Software Redundancy in Siemens PLC – Hardware versus Software
Combinational Circuits Objective Questions
Silicon Controlled Rectifier Commutation Quiz
field-mounted thermocouple
Thermocouple Extension Wires
hand-crank megger photo
What is Megger Test?
Patch Panel
Jacket Added Seawater Pipe Spool
Seawater Pipeline Spools from day-1 leaks threaten Plant Shutdown
