Reading: Different Types of Sensors used in Automotive Vehicles
Inst Tools > Blog > Common > Different Types of Sensors used in Automotive Vehicles
In this post, we will see the concept of sensors used in automotive vehicles. Sensors are integral part of automobiles.
Last updated: October 17, 2023 3:09 pm
Common
6 Min Read
In this post, we will see the concept of different types of sensors used in automotive vehicles.
Sensors in VehiclesEngine Speed SensorOxygen SensorRadar SensorMass Air Flow SensorFuel Temperature SensorCoolant Temperature SensorVoltage SensorThrottle Position SensorRain SensorHumidity SensorConclusion
Sensors are a very integral part of industrial automation. Almost every piece of machinery today works on the basis of sensors.
Sensors are a very integral part of automobile vehicles.
Sensors in Vehicles
Almost every function from spark advance, fuel metering, emission control, traction control, transmission shift points, antilock braking, etc. is performed under the surveillance of sensors.
Sensors Used in Automotive Vehicles
Here, we will consider some of the standard sensors used in automobile vehicles:
Engine Speed Sensor
The engine speed sensors are used to detect the speed of the engine motor. It is connected to the crankshaft. The crankshaft’s rotating speed is monitored through this; which ensures that the fuel injection and engine timing is properly controlled.
The speed sensor consists of a disc and magnetic coil. A current and magnetic field is created around the coil as the crank spins; which are then disrupted by the disc. This causes a count of RPM.
Oxygen Sensor
The oxygen sensors are used to monitor the level of oxygen in the exhaust gases of the engine system. It continuously compares the oxygen level of ambient air with that of the levels generated in the engine system.
This shows that whether the engine is running clean air or not. This is a useful property for emission controls.
Radar Sensor
Radar sensors are very precise and of high range detection. This is the reason is why they are mostly used in defense systems and communication systems. The same technique is employed in cars.
Due to higher resolutions and the ability to work even in low light or dark conditions, they are used for anti-collision, parking help, lane changing, etc. that makes the driving system more reliable.
Today’s new generation of driver assistance systems or adaptive cruise control systems uses radar technology for efficient performance.
The mass air flow sensor is located near the air filter box. It is used to monitor the amount of air in the engine system. As the name implies, it calculates the air density in the engine.
This ensures that proper air flow is available in the engine throughout its driving or else the engine will malfunction.
The fuel temperature sensor is used to monitor the temperature of the fuel in the engine. It also consists of a sensor measuring the temperature of the air entering the engine.
The combination of data is computerized properly and used to control the performance of the engine.
In an engine system, warm air means more reliable energy as compared to cold air which does not combust efficiently and takes much more time. The fuel economy is controlled by this sensor working.
The coolant temperature sensor is used to measure the temperature of the coolant, which is an important part of the engine cooling system.
Voltage Sensor
A voltage sensor is an important part of the sensor package and is used to control the car’s speed by measuring the voltage in the car’s electrical system.
As you accelerate the car, the throttle opening and closing play a very important part in it.
The throttle position sensor measures the angle of the throttle body whenever a car accelerates.
Rain Sensor
The rain sensor detects rainfall or in short, continuous water falling on the windscreen. This automatically activates the wipers to clean the screen.
Humidity Sensor
The humidity sensor is used to monitor the humidity and proper air flow inside the car cabin. This ensures that the person sitting inside breathes comfortably.
Excessive humidity also causes mist on the windows and this can be controlled with the help of these sensors.
Conclusion
These are some of the generally used sensors in an automobile system. There are many variants available depending on the make and design. It only strengthens the fact that as in industrial applications, sensors play an important role in our daily life activities and objects surrounding us.
  • Automated Guided Vehicle
  • Wireless Electric Vehicle Charging
  • Voice Activated Automation System
  • Industrial Automation in Mining Industry
  • Augmented Reality in Factory Automation
D’Arsonval Movement
What is a Tactile Sensor? Principle, Advantages, and Applications
Compressor Shutdown Job – Instrumentation Engineer Duties
Free Online Radiation Exposure Calculating Platform
Circular Chart Recorder Calibration Procedure
What is a Voltage Reference? – Electronic Components
Difference between Anode and Cathode
What’s the Best GPS Fleet Tracking Software and Systems?
What is a Legend? – Piping and Instrumentation Diagram
Heat Transfer Loops in HVAC System
6 Pieces of Essential Equipment For PCB Assembly
Top 3 Online Bachelor’s Programs in Electronics Engineering
Aluminum CNC Machining Complete Guide
Aluminum CNC Machining: A Complete Guide You Cannot Miss
Ceramic Bearings
Everything You Need to Know About Ceramic Bearings
Why Using VoIP Systems
Why Using VoIP Systems Can Save You and Your Business Money?
Essential Dorm Room Items Every Student Should Get
The Dorm Room Essentials And Why You Need Them
Flange Types and Definitions
What is PDCA - Industrial Maintenance
What is PDCA? – Industrial Maintenance
Instrumentation loop Diagram
Instrumentation Loop Diagrams
Liquid Level Measurement using Pressure Transmitter
Liquid Level Measurement using Pressure Transmitter Questions
AC Generator Nameplate Ratings
Difference between MCB and RCBO
Difference Between MCB and RCBO
Car Cooling System Automotive Radiator
What is an Automotive Radiator?
Types of Pressure
Basics of Pressure Measurement
BiCMOS Logic Circuits Objective Questions
What is a cable gland?
How Many Types of Cable Glands Are There?
