Reading: Rotary Abutment Flow Meters Working Principle and Animation
Inst Tools > Blog > Animation > Rotary Abutment Flow Meters Working Principle and Animation
Rotary Abutment Flow Meters are another form of positive displacement flow meter. They have a wide viscosity range and maintains accuracy too.
Last updated: October 31, 2023 4:28 pm
Animation Flow Measurement
2 Min Read
Rotary Abutment Flow Meter is another form of the positive displacement flow meter. As there is no metal contact within the chamber they have a long service life, also maintaining accuracy too.
Rotary Abutment Flow MeterAdvantages of Rotary Abutment Flow MeterDisadvantages of Rotary Abutment Flow Meter
They have a wide viscosity range making them suitable for many types of fuels & lubrication fluids. The rotors are connected to timing gears, so each time a rotor turns, the displaced volume is transferred to the register and the controller calculates the flow.
Rotary Abutment Flow Meters Working Animation
Credits: hytekflowmeters.com
There is no metal-to-metal contact between the rotors and housing walls, which prolongs the life of the flow meter.
  • The sweeping action of vanes prevents the buildup of sediment and keeps the compartment clean.
  • Wide choice of construction materials.
  • High accuracy and repeatability.
  • Low-pressure drop over the entire range of flow measuring capabilities.
  • Relatively complex design increases cost.
  • Flow Meter Turndown Ratio
  • Velocity-based Flow Meter
  • Flow Measurement Questions
  • Paddlewheel Flow Meters
  • Disadvantages of Flow Meters
Turbine Flow Meters Troubleshooting
Coriolis Flow Meter Construction
Basics of Venturi Flow Meter
Optical Pyrometer Working Principle Animation
Impact of Flow Meter Accuracy
What is an Averaging Pitot Tube? – Principle, Advantages
Equivalent Logic Gates using PLC Ladder Diagrams
Interferometer Principle
Square-Root in DCS or Flow Transmitter?
Basics of Restriction Orifice (RO) – Types, Applications, Standards
Turbine Flow Meters Animation
Flow Switch : What is it? – Applications
NDIR Gas Analyser Working Principle
What is Gas Meter and Regulating Station?
W Type Transit Time Flow Meter
Transit Time Flow Meter – Types, Advantages, Disadvantages
How to Select a Rotameter? – Parameters and Applications
magnetic-flow-meter-earthing
Stepper Motor Working Principle Animation
Transit Time flow meter Theory
Transit Time Flow Meter Principle
Displacer Level Sensor Working Animation
Coriolis Mass Flow Meter Verification Procedure
Prover Tank Calibration and Mass Flow Meter Verification Procedure
Thermal Dispersion Flow Switch Working Principle
Double-Acting Pneumatic Cylinder Circuit
Pneumatic Cylinder Movement Control with Timer Circuit
Flow Switch Working
Supplied Screen Vibrators Perennial Problems
3 Phase Motor in Star and Delta Connections
How to Connect a 3 Phase Motor in Star and Delta Connections?
P&ID Guidelines for Pumps
Paddlewheel flowmeter principle
What is a Paddle Wheel Flow Meter?
online silica analyzer
Silica Analyzer Problems and Troubleshooting Tips
Symbol of MOS Controlled Thyristor
MCT (MOS Controlled Thyristor) – Symbol, Working, Characteristics, Advantages
