Reading: Rockwell Automation Allen Bradley PLC for Smaller and Medium Projects
Inst Tools > Blog > PLC Tutorials > Rockwell Automation Allen Bradley PLC for Smaller and Medium Projects
In this article, we will discuss the Rockwell Automation Allen Bradley PLC products for smaller and medium projects.
Last updated: September 28, 2022 4:07 pm
7 Min Read
In this post, we will see the overview of Rockwell PLC. This post is divided into two parts. The first part discusses the overview of the PLCs used for smaller and medium applications. The second part discusses an overview of the PLCs used for higher-level applications.
Rockwell Automation Allen Bradley PLCMicro Range PLCsMicro 870 PLCMicro 850 PLCMicro 830 PLCMicro 820 PLCMicrologix 1400 PLCSmall Range PLCsCompact Logix 5480Compact Logix 5380
Allen Bradley PLC Course: Register for Free
Rockwell is a very big brand in industrial automation. It has very products and innovative technologies in industrial automation, residential and small business, low voltage products and systems, solar and energy storage, medium voltage distribution and grid automation, etc. If we consider the industrial automation part, it has a very wide range of PLCs.
In this post, we will have a look at various ranges of Rockwell PLCs. For your information, Allen Bradley is nothing but the automation brand owned by Rockwell Automation. So, Rockwell PLCs are also termed as Allen Bradley PLCs.
This range of PLCs is divided into three parts –
  • Micro,
  • Small and
  • Large
Let us have a look at all of them.
Micro Range PLCs
Micro 870 PLC
This PLC supports up to eight expansion modules with an IO capability of 304 points; including high-speed inputs, PTO, and interrupts.
From a communication point of view, it has an embedded Ethernet port, USB programming port, and two serial ports (RS-232 and RS-485).
Micro 870 Rockwell PLC
Also, it supports external SD cards for program transfer, data log, and recipe management. If you use this PLC in motion applications, it supports up to 2 axes of operation.
The software used for programming is Connected Components Workbench.
Micro 850 PLC
This PLC supports up to four expansion modules with an IO capability of 192 points; including high-speed inputs, PTO, and interrupts. From a communication point of view, it has an embedded Ethernet port, USB programming port, and two serial ports (RS-232 and RS-485).
Micro850 Programmable Logic Controller
Also, it supports an external SD card for program transfer, data log, and recipe management. If you use this PLC in motion applications, it supports up to 3 axes of operation. The software used for programming is Connected Components Workbench.
Micro 830 PLC
This PLC has an IO capability of 88 points; including high-speed inputs, PTO, and interrupts. From a communication point of view, it has a USB programming port and two serial ports (RS-232 and RS-485).
Allen Bradley Micro 830 PLC
Also, it supports external SD cards for program transfer, data log, and recipe management. If you use this PLC in motion applications, it supports up to 3 axes of operation. The software used for programming is Connected Components Workbench.
Micro 820 PLC
This PLC has an IO capability of 36 points; including an embedded 0-10V 4 channel analog input and a 1 channel analog output. From a communication point of view, it has a USB programming port, an embedded Ethernet port, and two serial ports (RS-232 and RS-485).
Micro 820 Allen Bradley PLC
Also, it supports external SD card for program transfer, data log, and recipe management. The software used for programming is Connected Components Workbench.
Micrologix 1400 PLC
This PLC has an embedded IO capability of digital 32 points or digital 32 points with 6 analog points; including six high-speed counters.
You can connect up to seven expansion modules.
MicroLogix 1400 PLC
From a communication point of view, it has a DF1 port, DH-485 port, and also supports Modbus RTU, DNP3, and ASCII protocols. It has an embedded Ethernet port which provides web server capability and email capability.
Also, it supports an external SD cards for program transfer, data log, and recipe management. One standing point of this controller is the LCD display. It allows you to view controller status and IO status.
The software used for programming is RS Logix 500.
Small Range PLCs
Compact Logix 5480
This PLC is a real-time controller with Windows 10 IoT Enterprise running in parallel to the Logix control engine. So, it supports embedded Windows applications like analytics, data gathering, and predictive computations.
CompactLogix 5480 Controller
It has three embedded Ethernet ports which provide high-speed communication and motion control. It has one additional Ethernet port which is dedicated to the commercial OS network interface. It also has two USB ports embedded in it.
The PLC supports up to 31 expansion modules. You can also connect additional Ethernet nodes (expansion buses) which will support more IO modules in them.
The software used for programming is Studio 5000.
Compact Logix 5380
This PLC family has Compact Logix and Compact Guard Logix 5380 controllers. The Guard Logix is a safety PLC that provides safety solutions up to the SIL3 level.
The motion control program supports up to 32 axes.
CompactLogix 5380 Controller
It has one Ethernet port and also includes dual configurable ports where you can assign different IP addresses. The software used for programming is Studio 5000.
This PLC won Oil and Gas Engineering Product of the Year in 2021 for its remarkable contribution to the oil and gas industry.
Apart from Compact Logix 5380, there is also Compact Logic 5370 and works on a similar line to it, with only a few additional functions.
In the next post, we will see PLCs used for higher-level applications.
  • Stop Switch Spurious Trip
  • ControlLogix Architecture
  • Allen Bradley Powerflex VFD
  • VFD Commissioning Procedure
  • Redundant Automation Systems
PLC Program for Water Level Control Logic
Power Supply Sizing for Industrial Automation Systems
Standard Colors in PLC Automation Systems
Free InTouch SCADA Tutorial Course for Beginners
PLC Programming for Pumping and Draining System
Electrical Ladder Diagram Control using Timers Example
Control Two Motors in Sequence after Time Delay – Circuit, Operation
Free Omron PLC Programming Course in HINDI
Batch Mixing with PLC Ladder Logic Program
What is Recipe Management in SCADA?
What is CODESYS? Why Do You Need to Learn it?
Cloud-Based SCADA Projects – Try Free Demo Account
plc-analog-input-card-conversion-formula
Proper Earthing Practices Used for PLC Control Panel
Relay Motor Logic Circuit
Motor Control Circuits
A Typical Sequential Function Chart
What is Sequential Function Chart (SFC?)
PLC Examples for calling functions in SCL
Free Schneider PLC Training - Automation Course
Free Schneider PLC Training – Automation Course
Siemens TIA Portal Free Version Download
Speed Control of Pneumatic Cylinder (Explanation with PLC)
Analyzers Based on Gas Density Questions & Answers
types-of-total-organic-carbon
Basics of Total Organic Carbon (TOC) Analyzers
Career Opportunities and Scope in Industrial Automation
TIA Portal MOVE Instruction
MOVE Instruction in PLC – What You Need to Know?
guided-wave radar Transmitter Setup
Guided-Wave Radar Instruments Diagnostics
Instrumentation Abbreviations
Shutdown Maintenance
The 5 Phases of Conducting Shutdown Maintenance
Calibration & Preventative Maintenance Procedures
Calibration and Preventative Maintenance Procedures
