Reading: Redundant Automation Systems – Need and Advantages
Inst Tools > Blog > Control Systems > Redundant Automation Systems – Need and Advantages
The objective of using redundant automation systems is to reduce the risk of production losses. Let's learn the need and advantages.
Last updated: January 4, 2023 12:54 pm
Hussien Ghareb
Control Systems PLC Tutorials
If you are one of those that are interested in Industrial Automation, then of course one day you heard about the word “Redundancy”.
What is meant by the Redundant Automation System?The Need for RedundancySystem Nodes that Requires RedundancyMain Advantage of a Redundant System
Redundancy in the English language means “the state of being not or no longer needed or useful” but in Industrial Automation systems, it has an important and critical function to execute.
So today are we going to understand the concept of Redundancy and how could this concept help us to build a better Automation solution.
Redundancy is about having backup components in a system that can take over if and when the primary components fail.
Redundant Automation Systems basically consist of two major elements (Master & slave) or we can call them (primary component & secondary component).
These two components are supposed to perform the same function but they have some priorities.
The primary component is responsible for handling the function and once it fails the backup (secondary) component takes its place to handle the same function without any stoppage.
The objective of using redundant automation systems is to reduce the risk of production losses, regardless of whether the losses are caused by an error or as a result of maintenance work.
Advantages of Redundant System
The higher the costs of downtimes, the more worthwhile it is to use a redundant system.
Notice that:
“The generally higher investment costs of redundant systems are quickly returned by the avoidance of production losses.”
Example
A common term in redundancy is “bump”.  A “bump” is an interruption in the process such as an unplanned line stoppage, or machine shutdown. Every industrial process is different in terms of what the consequences of a bump are.
As an example:
If you are dealing with a “Gas Metering Station” that is responsible for the accurate metering of natural gas flow, I suppose that you have already know how this process is critical and should be done as accurately as possible.
So, in case of any miscommunication between the flow computer and the measuring instrument (Meter, Transmitters) that would cost you a lot of money as the flow will not be measured.
Here in such a situation, you have to make a redundant system consisting of two or even three Flow Computers, all of them make the same function (measuring gas flow) so when one of them has a “bump” situation, Automatically the other flow computer will start to handle the process and save the measuring readings and data.
Here are some of the system sections that need to be covered with redundancy:
  • Physical Networks
  • Network Interface Cards (NIC)
  • PLC’s
  • Output control devices
  • OPC Server software
  • Physical servers
  • Power sources/UPS
Achieving redundancy requires a good deal of effort, and it may deter some organizations from putting in the extra work.
But the benefits of redundancy will build trust from the users and make the overall infrastructure more reliable and better than ever. The first benefit that a redundant network offers is uptime or the lack of downtime.
A system that is always up and ready to go is crucial for many (if not all) different industries. The cost of downtime costs the company an average of $5,600 every minute and an average of $300,000 every hour. This number can even be as much as $540,000 per hour.
This isn’t even mentioning the critical operations such as hospitals. System redundancy can prevent downtime that many companies cannot afford.
And on the other hand, we will find that these systems are expensive and it has a kind of complexity but regarding their benefits, for sure the overall system is helpful.
References
  • Automation System S7-400H Fault-tolerant Systems
  • Colocation America
  • Software toolbox
  • Scan Cycle in SIEMENS PLC
  • Cloud-Based SCADA Projects
  • PLC-based Gas Detection System
  • Create New Project in Studio 5000
  • Rockwell Allen Bradley PLC Projects
PLC Motor Operation based on Time Cycle Sequence – Program
Set the S5 Timer Value by a Memory Word
Siemens PLC Interview Questions and Answers
Distributed Control System & Motor Control Center Interface Philosophy
PLC Handbook
Studio 5000: Define Program or Operator Control in Functional Block Diagram
Difference between Signal Cables and Control Cables
Automate Batch Mixing with Repeated Cycles in Omron PLC
One-Shot Rising and Falling Edge Instructions in Rockwell PLC
OMRON PLC Math Instructions: +(400), -(410), *(420), /(430)
Single-acting Pneumatic Cylinder Operation with Limit Switch
PLC Ladder Program for Automatic Car Wash
PLC Ladder Program for Automatic Car Wash using Siemens TIA Portal
Process Control Automation PLC Quiz
LogixPro Simulator Software
Types of PLC
CRA Module in Schneider PLC
CRA Module in Schneider PLC – Remote IO Adapter Module
In this article, you will learn the configuration of PlantPAx library in factory talk studio of Rockwell Automation.
Configuration of PlantPAx Library in Factory Talk Studio
feed flow transmitter
Flowmeter Control Strategy
IEC 60909 and IEC 61363 for Short Circuit
plc-analog-signals-wiring-techniques
PLC Analog Signals Wiring Techniques
Thyristor Chopper Circuit Quiz
DCS Troubleshooting Control Valve Loop
Conveyor Speed Logic using Structured Text in PLC
Level Instruments
Level Instruments General Specifications
HART Communication
HART Communication Protocol Overview
