Reading: Valve Technician Interview Questions
Inst Tools > Blog > Control Valves > Valve Technician Interview Questions
Last updated: December 6, 2019 11:29 am
Control Valves Instrumentation Interview Questions
16 Min Read
Questions & Answers on Valves , Important Interview Questions on Control Valves, Valve Technician Interview Questions, Questions of Valves.
Valve Technician Interview QuestionsTypes of LeakageReasons that Valves LeakStandards for Acceptable Rates of Valve LeakageWhat is a ball valve?What is a check valve?Can butterfly valves be used for flow control or throttling?Where can we use gate valves?What is a globe valve?What valves are stop valves?What valve types are available on the market?What is a Three-Way Valve?Explain the difference between normally closed valve and normally open valve?Should you choose Forged or Cast valves?Difference between a pressure regulator and a flow regulator?What is the function of a directional control valve?What are the benefits of fused epoxy coating?What is the “CV” factor?Why are the seat and disc guide so critical?Where should strainers be located in pipework systems?What is the maximum pressure that I can test my system at?What is the difference between a FODRV and a VODRV?How many diameters are required before and after Commissioning Valves (CVs) for accurate flow measurement?
Types of Leakage
There are two types of leakage from a valve, namely; fugitive emissions from the valve to atmosphere, and leakage through the valve but contained within the piping system.
Fugitive emissions can both be detrimental to the environment and a potential safety hazard. Valves are considered to be the major contributors to fugitive emission losses.
Leakage through the valve can also be a safety hazard, and can be detrimental to the process.
Common causes of valve leakage include:
  • Valve is not fully closed. This can be due to various reasons, including;
  • Valve seat is prevented from closing fully due to dirt, rust, or line debris
  • Insufficient actuator travel
  • The seat is damaged, e.g. scored
  • The seal is damaged
There are many standards for leakage rates e.g. DIN EN 917 covers Thermoplastics valves, BS 6364 covers cryogenic valves, however the three standards used most in the oil and gas, and petrochemical industry are API 598, ANSI FCI 70-2 and MSS-SP-61.
Ball valves, as the name implies, are stop valves that use a ball to stop or start the flow of fluid. The ball performs the same function as the disk in the globe valve.
When the valve handle is operated to open the valve, the ball rotates to a point where the hole through the ball is in line with the valve body inlet and outlet.
When the valve is shut, which requires only a 90 degree rotation of the handwheel for most valves, the ball is rotated so the hole is perpendicular to the flow openings of the valve body, and flow is stopped.
Check valves are used to allow fluid in system in only one direction. They are operated by the flow fluid in piping.
A check valve may be the swing type, lift type, or ball type.
This is generally impractical due to the very unsteady nature of flow through a partially-opened butterfly. Variations of the basic butterfly design do not significantly improve this characteristic.
The butterfly valve has a body, a resilient seat, a butterfly disk, a stem, packing, a notched positioning plate, and a handle.
To open or close a butterfly valve turn the handle only one quarter turn to rotate the disk 90 degrees. Some larger butterfly valves may have a handwheel that operates through a gearing arrangement to operate the valve.
This method is used especially where space limitation prevents the use of a long handle.
Also Read: Basics of Valves Questions & Answers
Gate valves are used when a straight-line flow of fluid and minimum restriction is desired.
Gate valves are so named because the part that either stops or allows flow through the valve acts somewhat like the opening or closing of a gate and is called, appropriately, the gate.
The gate is usually wedge shaped. When the valve is wide open, the gate is fully drawn up into the valve, leaving an opening for flow through the valve the same size as the pipe in which the valve is installed. Therefore, there is little pressure drop or flow restriction through the valve.
A gate valve is usually used as a shut-off valve, gate valves are not suitable for throttling purposes since the control of flow would be difficult due to valve design and since flow of fluid slapping against a partially open gate can cause extensive damage to the valve.
Gate valves are classified as either RISINGSTEM or NONRISINGSTEM valves.
On the nonrising-stem gate valve the stem is threaded on the lower end into the gate. As the hand wheel on the stem is rotated, the gate travels up or down the stem on the threads, while the stem remains vertically stationary.
The rising-stem gate valve has the stem attached to the gate; the gate and stem rise and lower together as the valve is operated.
A Globe Valve is a type of valve for regulating flow in a pipeline, consisting of a movable disk-type element and a stationary ring seat in a globular (spherical) body.
Globe valves are named for their spherical body shape with the two halves of the body being separated by an internal baffle. This has an opening that forms a seat on to which the movable disc shut the valve.
Globe valves are used for applications require throttling and frequent operation.
Stop valves are used to shut off or, in some cases, partially shut off the flow of fluid.
Stop valves are controlled by the movement of the valve stem.
Stop valves can be divided into four general categories: globe, gate, butterfly, and ball valves.
Needle valves may also be considered stop valves.
Although many different types of valves are used to control the flow of fluids, the basic valve types can be divided into two general groups: stop valves and check valves.
Besides the basic types of valves, many special valves, which cannot really be classified as either stop or check valves, are found in the engineering spaces.
Many of these valves serve to control the pressure of fluids and are known as pressure-control valves.
Three-Way valves has three ports. Depending on the particular valve, all three port may be open, two ports may be open, or all ports may be closed.
Normally Closed:
Valves stays closed in de-energized state; opens when energized.
Normally Open:
Valves stays open in de-energized state; closes when energized.
It depends on the application.Many valve applications in pharmaceutical and biotechnology manufacturing require forged valves because of the low ferrite content and better surface finish.
Cast valves can sometimes have surface imperfections where bacteria can grow and cause contamination.
A pressure regulator valve (PRV) controls pressure regardless of variations in flow. The FRC is the exact opposite of a PRV. It will control the flow rate regardless of pressure variations.
A directional control valve is the extend and retract control for your hydraulic cylinders. It provides a flow path from the pump to the cylinders and a return path from the cylinders to the fluid reservoir
This coating is applied under rigorous preparation and application standards. It is non-porous, improving the flow co-efficiency of the valve and effectively sealing the casting from interaction with the controlled liquid.
The coating also protects the valve from environmental attack. The finish prevents mineral buildup and rust, simplifies maintenance, and prolongs the life of the valve.
The pressure loss for fixed orifice items are identified by the “CV” Factor. The symbol “CV” is defined as “a valve constant, characteristic of each type and size of valve”.
Once the CV factor is established for a particular valve, the pressure loss through that valve or fitting can be calculated by simply knowing the specific gravity of the fluid running through the pipe, the quantity of flow (in gallons per minute) and the CV factor of the valve.
They are the two most critical components in the flow path of the controlled liquid and are provided in Stainless Steel as a standard.
This allows the valve to handle those tough applications where excessive velocity, volatile water conditions and even minor cavitation are present.
Strainers are installed to protect items of plant and to help ensure system efficiency by keeping heat emitters (terminal units, i.e. fan coil units etc.) free from particle build-up within them.
When used to protect items of plant (boilers / chillers / pumps etc.) strainers should be installed upstream of the item to ensure that larger particles contained in the flowing water do not enter and damage the item of plant.
Strainers can also be installed at strategic places, i.e. branches or in each terminal sub-circuit, throughout the system to ensure that smaller particles contained within the flowing water do not pass into the terminal units affecting their efficiency.
Pressure testing has implications on all of the individual system components, i.e. pipes, fittings, valves, coil etc., therefore the pressure rating of all the components needs to be considered when deciding on a suitable test pressure.
There are two pressure tests relating to valves:
System Pressure Test – to test integrity of the finished assembled system, i.e. ability of the completed assembly of individual components to withstand pressure.
Valve shut-off Pressure Test – to test the ability of a valve, typically an Isolation Valve, to close against a pressure.
Manufacture valves to allow system pressure testing to be carried out at 1.5 times maximum working pressure of the valve, i.e. for PN16 valves the test pressure can be 16 x 1.5 = 24 bar. Note that all valves must be in an open position.
The shut-off pressure test can be carried out at 1.1 time maximum working pressure.
FODRV is the abbreviated term for Fixed Orifice Double Regulating Valves and VODRV for Variable Orifice Double Regulating Valves.
The term ‘Orifice’ refers to the opening in the valve that the water flows through.
FODRV:
With a FODRV the ‘orifice’ that creates the measured pressure drop, is an actual opening of a fixed size, hence the term ‘Fixed orifice’. Fixed Orifice Valves have a single value for the flow coefficient Kv. For the FODRV this value is usually referred to as Kvs.
VODRV:
With the VODRV the ‘orifice’ that creates the pressure drop is the seat / disc assembly within the valve. As the gap between the seat and disc is different for different handwheel positions, the flow coefficient Kv is changeable depending on the handwheel position, hence the term ‘Variable Orifice’.
Because the FODRV does not have a changeable Kvs value, the accuracy remains at ±5% irrespective of the handwheel position, whereas, for the VODRV, which has a variable Kv value, the accuracy is ±5% when fully open but reduces to approximately ±18% when the valve is closed to its minimum set position, i.e. 25% open (CIBSE recommendation).
Commissioning Engineers find it easier to work with FODRV because design pressure drops can be calculated before attending site, whereas, with the VODRV the pressure drop must be re-calculated during the commissioning process each time the handwheel position is changed.
Best practice is to have 10 clear straight diameters of pipework of the same nominal diameter before (upstream) and 5 clear straight diameters after the CV.
The diameters before the CV are important for flow measurement accuracy and the diameters after the CV maximise system pressure recovery.
When installed with 10 and 5 diameters, other pipework components, i.e. bends/ control valves etc., can be ignored and have no effect on accuracy or system pressure recovery.
Where it is not possible to install with 10 and 5 diameters, they can be decreased to 5 and 3 diameters with only slight reduction in accuracy.
However, where the upstream diameters are decreased to 5 clear straight diameters, it becomes important to consider components that are installed within 5 diameters upstream of the CV.
For example, control valves (with convoluted water passage through them) would have a greater impact on accuracy than a concentric reducer or an elbow which would have a greater impact than a slow bend.
Where the downstream diameters are decreased to 3, almost all the system pressure has been recovered so the change from 5 to 3 has little impact.
Articles You May Like :
Valves Multiple Choice Questions
Control Valves Interview
Objective Questions of Valves
Flow Control Valves Questions
Relief Valve Questions
Common Questions on Oil and Natural Gas Industry
Motor Operated Valve Problems and Troubleshooting
Most Asked Questions on SCADA with Answers
Ball Valve Material Selection
Control Valve Cavitation and Flashing
EPC Questions and Answers
Concept of Steam Conditioning Valves
RTD Questions and Answers
Industrial Networking and Wireless Interview Questions
Power Plant Interview Questions & Answers
Solenoid Valves Types & Functions
Instrument Calibration Questions
Electric Motor Actuator Parts
Metal Seated Ball Valves
Metal Seated Valves and Soft Seated Valves : Differences
Top 80+ Valve Questions and Answers
Air Lock Relay Working Principle
Control Valve Air Lock Relay Working Principle
SCADA Interview Questions
Certified Control Systems Technician (CCST) Sample Questions
control-valves-classification
Types of Control Valves
Control Valve Testing for Noise Measurement
Two Differential Pressure Transmitters
Pressure Level Transmitter Problems
Needle Valve Body Design
What is Needle Valve ?
Hydraulic versus Pneumatic Systems
ultrasound
Ultrasonic Gas Leak Detectors (UGLD)
Lamp Counter Logic
Function Block (FB) for Motor Control Logic
PLC Program for motor operation based on time cycle
PLC Motor Operation based on Time Cycle Sequence – Program
Types of Failures in Control Valves
Pressure Safety Valves Functional Testing
