Reading: PLC Programming: Sorting and Distribution of Boxes by Height
Inst Tools > Blog > PLC Tutorials > PLC Programming: Sorting and Distribution of Boxes by Height
In this PLC programming, we do sorting and distribution of boxes by height into the designated storage bins using sensors and conveyors.
Last updated: June 27, 2023 11:03 pm
6 Min Read
PLC Sorting Boxes by HeightPLC I/O ListProgram DescriptionPLC Ladder Logic
This PLC program distributes the specified number of parts according to their size.
The below simulation shows the working principle of PLC logic for sorting boxes based on their height. Here we have 3 different size boxes like small, medium, and large sizes.
There are three storage bins for each box size. There are three pushers and three conveyors. Each box size has one pusher and one conveyor.
PLC Programming to Sort Boxes Based on Height and Parts Distribution
The robot places the boxes randomly on the conveyor. The sensors are used to detect the box’s size. The conveyors are started and stopped when the respective box size reaches there using the sensors.
The respective pusher is activated and moves the respective box size to the dedicated storage bins.
PLC I/O List
The below table lists the inputs and outputs of this system.
TypeDevice No.Device NameOperation
InputX0Starting pointON when the robot is at starting point.
InputX1UpperON when the part is detected.
InputX2MiddleON when the part is detected.
InputX3LowerON when the part is detected.
InputX4SensorON when the part is detected on the incline.
InputX5SensorON when the part is detected on the incline.
InputX6SensorON when the part is detected on the incline.
InputX7SensorON when the part is detected at the right end.
InputX10Detect partON when the part is detected in front of the pusher.
InputX11Detect partON when the part is detected in front of the pusher.
InputX12Detect partON when the part is detected in front of the pusher.
OutputY0Supply commandOne part is supplied When Y0 is ON. A process cycle begins: Wooden part repeats in order M, S, L, M, M, L, S, S, L, L.
OutputY1Conveyor forwardThe conveyor moves forward when Y1 is ON.
OutputY2Conveyor forwardThe conveyor moves forward when Y2 is ON.
OutputY3Conveyor forwardThe conveyor moves forward when Y3 is ON.
OutputY4Conveyor forwardThe conveyor moves forward when Y4 is ON.
OutputY5PusherExtends when Y5 is ON and retracts when Y5 is OFF. The pusher cannot be stopped in the mid-stroke.
OutputY6PusherExtends when Y6 is ON and retracts when Y6 is OFF. The pusher cannot be stopped in the mid-stroke.
OutputY7PusherExtends when Y7 is ON and retracts when Y7 is OFF. The pusher cannot be stopped in the mid-stroke.
Program Description
Programming a Programmable Logic Controller (PLC) for Box Sorting Based on Height and Component Distribution.
Initiating the robot’s operation involves pressing the pushbutton PB1 (X20) located on the control panel, which activates the Robot Supply Command (Y0).
The Robot Supply Command (Y0) is deactivated upon the robot completing the part movement and returning to its initial position.
The Conveyor Movement Command is controlled by the Switch SW1 (X24) on the control panel. Activating the switch (turning it ON) propels the conveyor’s movement forward while deactivating it (turning it OFF) brings the conveyor to a halt.
Sorting of parts, segregated into large, medium, and small sizes, is executed through the input from the Upper (X1), Middle (X2), and Lower (X3) sensors. Post-sorting, the parts are conveyed to their designated trays.
The presence of a part in the pusher is identified by the activation (turning ON) of the Part Detection Sensors (X10, X11, or X12). Upon part detection, the conveyor is brought to a halt, and the detected part is displaced onto the tray.
Note: The operation of the pusher is governed by the Pusher Actuation Command. Upon receiving an ON signal, the pusher fully extends, while an OFF signal causes the pusher to retract.
Each tray is to contain a specific number of parts, depending on their size. Any parts exceeding these specified numbers bypass the pusher and are ejected from the conveyor at the right end.
The designated number of parts per size is as follows:
  • Large: 3 parts
  • Medium: 2 parts
  • Small: 2 parts
PLC Ladder Logic
PLC Ladder Logic for Boxes Sorting by Height
Programmable Logic Controller for Sorting and Distribution
Source: Mitsubishi Electric
  • SCADA System Architecture
  • Two-Hand Press Safety Circuit
  • Feedback Monitoring in PLC
  • PLC Power Supply and Voltages
  • Automation System Power Supply
Tia Portal – OB20 Time Delay Interrupt Organization Block
ControlLogix Architecture – Rockwell Automation
Use of Isolators and Barriers in Electrical Panel
Batch Mixing with PLC Ladder Logic Program
Siemens PLC Project: Automatic Parking with Vehicle Counter
How to Retrieve PLC Project From Memory Card?
PLC Configuration of Profinet I/O System
How to Choose the Right Industrial Automation Solution?
What is SCADA ? How does SCADA Works ?
Top 100 PLC Objective Questions and Answers
XG5000 Example of Simple Conveyor Control PLC Program
OFF Delay Timer using PLC
Analog Measurement using Ladder Logic
S7 Organizational blocks
Siemens PLC Tia Portal – OB100 Start-up Organization Block
Cars Garage Counter From the Same Door PLC Logic
DCS Vs PLC
DCS versus PLC Architecture
Traffic Barrier Control
PLC Programming for Traffic Barrier Control
Ladder Logic for Flow Meter Totalizer
Allen Bradley Powerflex VFD
Universal Shift Registers Objective Questions
Learn PLC in Hindi
Learn PLC in Hindi
How to Choose HMI
How to Choose a Suitable HMI for Your Application?
magnetic-flow-meter-earthing
Economics of Power Generation Objective Questions
100+ Economics of Power Generation Objective Questions and Answers
Difference Between Single Pair Ethernet and Traditional Ethernet
Overview of Proximity Switches
pid-guidelines-for-pig-receivers
P&ID Guidelines for Pig Receivers
