Reading: PLC Program for Solenoid, Pilot Lamp, and Switch with Alarm
Inst Tools > Blog > PLC Tutorials > PLC Program for Solenoid, Pilot Lamp, and Switch with Alarm
In this article, you will learn the PLC program for solenoid, pilot lamp, and switch with alarm for industrial control applications.
Last updated: April 5, 2024 5:49 am
9 Min Read
PLC Program for SolenoidEssential PLC LessonsInputs and OutputsLadder Logic for Solenoid, Pilot Lamp, SwitchPLC Program ExplainedPLC Simulation Findings
Disclaimer: The PLC program showcased here is for educational purposes only which is for students and technicians to learn foundational concepts of PLC.
Problem Statement
We are using one push button to control the Solenoid, Pilot Lamp, and Alarm.
When the Push Button is pressed and then released, then the Solenoid and the Pilot Lamp will be ON.
When the Push Button is pressed again and then released, then the Solenoid and the Pilot Lamp will be OFF and the Alarm will be ON.
These PLC video lessons are helpful in learning the basics of PLC programming.
PLC Program for Solenoid, Pilot Lamp and Switch
Inputs and Outputs
Digital Inputs:
The digital inputs listed here.
Push Button 1: I0.0
Digital Outputs:
The digital outputs listed here.
Solenoid: Q0.0
Pilot Lamp: Q0.1
Alarm: Q0.2
In this PLC program, we have used Normally-Open Contacts as well as Normally-Closed Contacts and Memory Bits.
Normally Closed Contact is used for Push Button in Rung 2 and for Memory Bit 3 in Rung 0.
In Rung 0:
1) Normally Open Contact is used for Push Button to turn ON the Memory Bit 1.
2) Normally Closed Contact is used for Memory Bit 3 to OFF the Memory Bit 1.
3) Latching is used for Memory Bit 1 so that when the Push Button is turned OFF, Memory Bit 1 still remains ON.
In Rung 1:
1) Normally Open Contact is used for Memory Bit 1  to turn ON the Solenoid and Pilot Lamp.
In Rung 2:
1) Normally Closed Contact is used for Push Button and Normally Open Contact is used for Memory Bit 1 to turn ON Memory Bit 2.
2) As Memory Bit stores the data, Memory Bit 2 is used to store the data that Push Button has been released.
3) Latching is used for Memory Bit 2 so that when the Normally Closed Contact used for the Push Button is in a True state, Memory Bit 2 still remains ON.
In Rung 3:
1) Normally Open Contact is used for Push Button to turn ON the Memory Bit 3.
2) Memory Bit 2  is used to store the data when the Push Button is pressed again.
3)  Memory Bit 3 i.e. latched with Memory Bit 2 is used to turn OFF Memory Bit 1, So that when Memory Bit 3 is turned ON in Rung 3, Normally Closed Contact is used for Memory Bit 3 in Rung0 will be in True state and Memory Bit 1 will turn OFF. Then, In Rung1, Normally Open Contact used for Memory Bit 1 will not pass as it is in a false state And the Solenoid and Pilot Lamp will Turn OFF.
In Rung 4:
1) Normally Open Contact is used for Memory Bit 3 to turn ON Alarm.
2) Latching is used for the Alarm so that when Memory Bit 3 turns OFF, the Alarm still remains ON.
So, When the Push Button is pressed, the signal will pass through the Push Button as Normally Open Contact used for the Push Button is in the True state. In a false state, Normally Closed Contact used for Memory Bit 3 will also pass the signal, and Memory Bit 1 will Turn ON and it will store the data that the Push Button has been Pressed.
In Rung1, the Solenoid and Pilot Lamp will Turn ON as Normally Open Contact used for the Memory Bit is in a True state. When the Push Button is released, Memory Bit 1 in Rung0 still remains ON because Latching is used for Memory Bit 1 in Rung0. Also, the Solenoid and Pilot Lamp remain ON as Memory Bit 1 is still ON.
In Rung2, Memory Bit 2 will Turn ON as the Normally Closed Contact used for the Push Button is in a false state, and the Normally Open Contact used for Memory Bit 1 is in a True state. Memory Bit 2 will store the data that the Push Button has been released. When the Push Button is pressed again, it will Turn ON Memory Bit 3 in Rung0, Rung3, and Rung4 then the Solenoid and Pilot lamp will Turn OFF because Memory Bit 3 in Rung0 will not pass the signal to Memory Bit 1 as Normally Closed Contact used for it is in True state and Memory Bit 1 will Turn OFF.
In Rung1, Normally Open Contact used for Memory Bit 1 is in a false state and will not pass the signal to the Solenoid and Pilot Lamp. In Rung4, the Alarm will Turn ON. When the Push Button is released, the Alarm still remains ON as Latching is used for the Alarm in Rung4.
Now we simulate our PLC program and show the results below. In some cases, we may show only the required part of the logic instead of complete code.
When Push Button 1 is PRESSED
Control a Solenoid with an Arduino (Tutorial)
In Rung0, the signal will pass through the Push Button as Normally Open Contact used for the Push Button is in a True state.
When Push Button  is RELEASED
PLC Actuators and Output Devices Program
When Push Button is PRESSED Again (Second Press)
PLC Logic for Solenoid Valve
Pilot Lamp Ladder Logic
Pressing the Push Button again will Turn ON Memory Bit 3 in Rung0, Rung3, and Rung4 then the Solenoid and Pilot lamp will Turn OFF because Memory Bit 3 in Rung0 will not pass the signal to Memory Bit 1 as Normally Closed Contact used for it is in True state and Memory Bit 1 will Turn OFF.
When Push Button is RELEASED Again (Second Release)
Switch with Alarm PLC Problems
  • PLC Push Button to Turn ON OFF Output
  • PLC Instructions TON, TOF, TP and TONR
  • Automatic Motor START and STOP Circuit
  • PLC Motor Logic with START Pushbuttons
  • What is a Pilot Valve? When do we use it?
Free PLC Training Software Download
PLC Ladder Logic for Opposite Acting Control Valves Application
Various Communication Protocols in PLC
How to Configure PID Controller in Various Schneider PLCs?
How to Automatically Close Pop-up in FactoryTalk View Studio?
#13 PLC Best Practices – Disable Unused Communication Ports
Lamp Control using PLC Logic Condition
Bread Oven Control in Auto and Manual Modes PLC Program
Move Instruction in Tia Portal
Principle of Operation of PLC
Logic for Always ON and Always OFF bit
Always ON and OFF Bit using Ladder Logic and Statement List
PLC Conveyor Forward and Reverse Logic
Advanced PLC Conveyor Control: Forward and Reverse Rotation
Automatic Packing of Bottles
Automatic Packing of Bottles Programming
PLC Programming for Pumping and Draining System
PLC Program for Car Parking
PLC Program for Entry and Exit Control of Car Parking
Mitsubishi PLC Counter Tutorial Using GX-Works2
Networked SCADA Architecture
Siemens TIA Portal program blocks
Tia Portal – Optimized and Standard Data Block Access
Distributed Network Protocol Communication
DNP3 Communication Protocol Overview
How to Check the Continuity of Protective Conductors
How to Check the Continuity of Protective Conductors?
Magnetic Level Indicator
Magnetic Level Indicator Principle, Limitations, Installation and Calibration
Modbus Poll and Modbus Slave
How to Use Modbus Poll and Modbus Slave Software?
Time of Flight Mass Spectrometer
Bubbler Level Measurement System
Bubbler Level Sensor
Self-balancing Pneumatic Instrument Principles - 3
Dynamic Characteristics of Power Diode
Power Diode – Characteristics, Construction, Working, Advantages
