Reading: PLC Program for Entry and Exit Control of Car Parking
Inst Tools > Blog > Guest Articles > PLC Program for Entry and Exit Control of Car Parking
PLC program for car parking entry and exit gates control explained with programming solution and diagram.
Last updated: November 3, 2023 11:44 am
Guest Articles PLC Tutorials
2 Comments
6 Min Read
This is a PLC Program for Entry/Exit control of the basement or underground car parking.
PLC Car ParkingProblem DiagramProblem SolutionList of Inputs and OutputsPLC Ladder Diagram for Entry/Exit control of car parkingProgram DescriptionResult
PLC Car Parking
Problem Description
Due to crowded area we face lots of problems of vehicle parking at basement or underground at shopping mall, hotels, complex etc.
This is happening due to contradiction between the rapidly growing number of vehicles and limited parking spaces in malls, shop and complex in cities results in the phenomenon of “difficult parking and disorderly parking”.
Current parking problem has serious impacts on people’s quality of life and the running of roads.
Problem Diagram
PLC Car Parking Program
Problem Solution
By simple automation we can reduce the car parking problem at basement or underground in shopping mall, hotels, complex etc. The Entry/Exit at basement is a single lane passage and it needs traffic lights to control cars.
Here we consider two lights indication for cars control. Red lights prohibit cars entering or leaving while green lights allow cars entering and leaving.
When car enters at the passage from the entry of the ground floor, both red lights (ground floor and basement) will be ON.
Other car entering and leaving is prohibited during the process till the car passes through the single passage.
When passage is clear both green lights (ground floor and basement) will be ON and allow other cars entering from the ground floor or basement.
Initially we will keep green lights ON and red light OFF
Inputs List
  • Main SWITCH : I0.0
  • Sensor S1 for ground floor Entry/Exit : I0.1
  • Sensor S2 for basement Entry/Exit : I0.2
Outputs List
  • Green light (Entry/Exit ground floor) : Q0.0
  • Green light (Entry/Exit basement) : Q0.1
  • Red light (Entry/Exit ground floor) : Q0.2
  • Red light (Entry/Exit basement) : Q0.3
M memory coil List
  • M10.0 : Will be ON when car passes sensor S1
  • M10.3 : Will be ON when car Passes sensor S2
  • M0.0 : Positive edge of system ON
  • M0.1 & M11.0 : Positive edge of sensor S1
  • M0.3 & M11.1 : Positive edge of sensor S2
  • M11.2 : Negative edge of sensor S2
  • M11.3 : Negative edge of sensor S1
PLC Program Car Parking
PLC Scan Cycle
PLC car parking project
car parking PLC
PLC Sensors detect
car parking control using PLC
PLC based automatic car parking system
automatic car parking project using PLC
Car parking using PLC and SCADA
Program Description
In this application we have used Siemens S7-300 PLC and TIA Portal Software for programming.
Network 1:
As per above explanation in first network when system is ON (I0.0), initially both green lights (ground floor (Q0.0) and basement (Q0.1)) will be ON. SET instruction is executed and it will set both output Q0.0 and Q0.1.
Network 2:
As per above explanation in second network when system is ON (I0.0), initially both red lights (ground floor (Q0.2) and basement (Q0.3)) will be OFF.)
RESET instruction is executed and it will reset both output Q0.2 and Q0.3.
Network 3:
When car enters in the empty passage from the ground floor, sensor S1 (I0.1) will be triggered and with this trigger, memory coil M10.0 will be SET.
Network 4:
When car enters in the empty passage from the basement, sensor S2 (I0.2) will be triggered and with this trigger, memory coil M10.3 will be SET.
Network 5:
Both red lights will be set by either positive trigger of sensor S1 or sensor S2.
Because when car enters in empty passage then both red lights (Q0.2 & Q0.3) will prohibit car entry/exit from both side.
Network 6:
Here we have taken negative trigger of both sensor S1 (I0.1) and S2 (I0.2). so when they triggered red lights (Q0.2 & Q0.3) will be OFF.
When car completely passes empty passage then red lights (Q0.2 & Q0.3) should be OFF.
Network 7:
In this network green lights (Q0.0 & Q0.1) will be ON when red lights are OFF.
Green lights (Q0.0 & Q0.1) allow other car for entry or exit.
Network 8:
If red lights (Q0.2 & Q0.3) are ON at that time green lights (Q0.0 & Q0.1) should be OFF.
So in this network when red lights (Q0.2 & Q0.3) ON at that time reset instruction will be executed and green lights (Q0.0 & Q0.1) will be OFF
Network 9:
If system ON (I0.0) SWITCH is OFF then all memories should be 0.Here we have taken MOVE instruction for moving zero in all memories (MB0, QB0, and MB10).
This Example is for concept explanation only, not all parameters are considered in this example (such as door open/close system, alarms etc.)
Result
PLC Ladder Logic for Car Parking
Note : The above PLC Logic provided for basic idea about application of PLC in Car Parking Control of Entry/Exit Gates. The Logic is limited and not complete application.
Author : Bhavesh
  • PLC Scaling a Sensor
  • Controls Valve using PLC
  • PLC Math instructions
  • Timer Programming Examples
  • Basics of PLC Programming
Mixing Program with Timers and Counters in Omron PLC
Scaling with Parameters (SCP) Instruction in PLC
Siemens PLC programming: BCD, Integer, Double Integer, Real
Pump and Mixer Operations Example: PLC Timer-Based Control
Various Types of Delta PLC used in Industrial Automation
2 Comments
  • rahim says:
    June 21, 2018 at 11:14 am
    Thanks a lot
  • Balaji says:
    June 24, 2018 at 5:40 pm
    Great
What is a Tag? Types of Tags in SCADA
#20 PLC Best Practices – Identify Critical Alerts
Types of CPU Communication Ports in Siemens PLC
DC Injection Braking in VFD
#11 PLC Best Practices – Instrument for Plausibility Checks
How does a Redundant Controller comes in line when the Main Controller fails?
Augmented Reality and Virtual Reality in Industrial Automation
Control Panel
Historical Scada graph
Configuration of InTouch Scada Trends
Tank Level Control Process in PLC
Tank Level Control in PLC
Car Wash Program using Functional Block Diagram (PLC)
PLC Counter Example for Bank
Control Speed of an Induction Motor using Analog Output of PLC
Control Speed of Induction Motor using Analog Output of PLC
Power Supply Sizing for Industrial Automation Systems
Traffic Lights Ladder Diagram using Timers
NO2 Analyzer Questions & Answers
Harmonic Reduction Objective Questions
Calibrate Eddy Current Conductivity Instrument
How to Calibrate the Eddy Current Conductivity Meter?
Formulas to calculate ma from PV
Formulas to calculate mA from PV, LRV and URV
Turbo-Compressor Problem
Turbo-Compressor Problem – Root Cause Analysis
pH Analyzer Calibration and Troubleshooting
Industrial Electronics Objective Questions and Answers
IP Address Change in Simatic
PLC Configuration of Profinet I/O System
