Reading: PLC, DCS, and ESD Marshalling Cabinet Checks
Inst Tools > Blog > Control Systems > PLC, DCS, and ESD Marshalling Cabinet Checks
We discussed the basic steps to be followed during healthiness checks and maintenance of PLC, DCS, and ESD marshalling cabinet.
Last updated: August 10, 2021 10:47 am
Control Systems PLC Tutorials
3 Min Read
DCS and ESD Marshalling Cabinet
  1. Collect the corresponding Work permit.
  2. Note down the cabinet panel tag/reference name which will be on top of each cabinet door (Ex: 10-3-01).
  3. Check the working condition of door locking system by operating twice.
  4. Check once all the cooling fans are in running condition. Fans are located at the top of the panel and fan switch will be at rear side of each panel.
  5. Check the tube light condition by activate door limit switch which will be on top corner of each panel.
  6. Check all the empty slots are properly covered by blanking (dummy) plates. (No slots should be open on the rack)
  7. Measure and notedown the utility supply voltage at which will be available on rear side of panel.
  8. Check the sealing of spare cable entry slots at bottom of the panel.
  9. Check the grounding of the panel, ground bar will be located at bottom of rear side of panel.
  10. Measure the 24V DC supply MCB which will be located at top corner of panel front side.
  11. Check the thermostat set point (25 deg C). Thermostat will be located at rear side of panel right corner.
  12. Check all the fuses are in healthy condition. If a fuse has brunt then RED LED will glow on respective fuse.
  13. Check for any loose connections in the panel.
  14. Clean all the filters of the panel. (Remove the filter from the panel, clean it with vaccum cleaner and again install it)
  15. Check and ensure cables are properly dressed and cable ducts are covered
Repeat the above steps for each marshalling cabinet.
Note: All panels must be closed after PM activity has been done.
Also Read: Yokogawa DCS Checks
Interest to add any further checks? Share with us through below comments section.
If you liked this article, then please subscribe to our YouTube Channel for Instrumentation, Electrical, PLC, and SCADA video tutorials.
You can also follow us on Facebook and Twitter to receive daily updates.
  • DCS Troubleshooting
  • Commissioning of DCS System
  • DCS Control System Spares
  • Yokogawa DCS Architecture
  • DCS System Layout
How to Troubleshoot Siemens PLC Programs?
Boolean Logic to PLC Programming
PUT Command in Siemens PLC – TIA Portal Basics
Motor Control using Modbus Communication and Hardwired Signals
Function Blocks in PLC (FBs) – What You Need To Know?
System Cabinet Health Checks – PLC and DCS Industrial Automation
PLC Program for Continuous Filling Operation
What is Instrument Hook Up Diagram ?
What is Recipe Management in SCADA?
PLC Program for Water filling and Discharging Process
Ladder Logic for Motor Control
PLC Programming for 3 Motors control in Ladder logic
Components of PLC
CODESYS open source PLC software
What is CODESYS? Why Do You Need to Learn it?
Scaling in PLC
PLC Ladder Logic for Sensor Scaling with Offset
PLC Question Bank
PLC Question Bank
Single Phase Preventer Relay
Working Principle of Single Phase Preventer Relay
PLC Programming for Weight-Based Packaging
Conveyor Speed Logic using Structured Text in PLC
Speed Control of Pneumatic Cylinder (Explanation with PLC)
PLC Program for Boolean Expression
Convert 4-20ma current output to foundation fieldbus
Control Valve Preventive Maintenance
Biomedical Instrumentation Questions and Answers
Electronic Pressure Sensor with Bourdon Tube and LVDT
Compressor Did Not Trip
RCA – Compressor Did Not Trip on Suction Pressure Low Low
What is electrical transformer
Basics of Electrical Transformer
