Reading: Phase Controlled Rectifier – Half Controlled Rectifier with R Load
Inst Tools > Blog > Power Electronics > Phase Controlled Rectifier – Half Controlled Rectifier with R Load
A phase controlled rectifier converts AC to DC using thyristors or silicon-controlled rectifiers. Learn Half Controlled Rectifier R, RL, RLE Load.
Last updated: October 18, 2023 12:09 am
Power Electronics
9 Min Read
A phase-controlled rectifier is an electronic circuit that converts alternating current (AC) to direct current (DC) using controlled semiconductor devices, such as thyristors or silicon-controlled rectifiers (SCRs).
Phase Controlled RectifiersHalf Controlled RectifierHalf-controlled Rectifier With R LoadMatlab Simulation ResultsMatlab Simulink Circuit of Half-controlled Rectifier With R LoadSimulink Result
Unlike uncontrolled rectifiers, which conduct throughout the entire AC cycle, phase-controlled rectifiers allow the conduction angle (the portion of the AC cycle during which the rectifier conducts) to be controlled. This provides a way to regulate the output voltage and current.
In a phase-controlled rectifier circuit, the firing angle (also known as the delay angle or conduction angle) determines the portion of the input AC waveform that is rectified and converted to DC.
Controlling the firing angle, the output voltage and current can be adjusted, therefore it is possible to control the power delivered to the load.
Phase-controlled rectifiers are widely used in various applications, including motor drives, power supplies, and voltage regulators.
Here we show the types of phase-controlled rectifiers.
Types of Phase Controlled Rectifiers
Fig.1. Various Types of Phase-Controlled Rectifiers
There are three main types of phase-controlled rectifiers:
  1. Half-Wave Rectifier: In a half-wave rectifier, only one half (either positive or negative) of the input AC waveform is rectified.
  2. Full-Wave Rectifier: In a full-wave rectifier, both halves of the input AC waveform are rectified, resulting in a smoother DC output compared to a half-wave rectifier.
  3. Full-Wave Bridge Rectifier: This is a type of full-wave rectifier configuration that uses a bridge of diodes or SCRs to rectify both halves of the AC waveform. It is the most common type of phase-controlled rectifier due to its efficiency and ability to produce a constant DC output.
Phase-controlled rectifiers are fundamental components in power electronics and are essential for various applications where controlled DC power is required from an AC power source.
A half-controlled rectifier is a type of phase-controlled rectifier circuit where only one of the rectifying diodes is replaced with a controllable semiconductor device, usually a thyristor or silicon-controlled rectifier (SCR).
Fig.2. Types of Half-Controlled Rectifier
In a half-controlled rectifier, the circuit can control the output DC voltage by varying the firing angle, which is the delay between the zero crossing of the input AC voltage and the triggering of the controllable thyristor.
Controlling the firing angle, the portion of the input AC waveform is rectified and converted into DC can be regulated.
A single-phase half-controlled rectifier is similar to an uncontrolled rectifier. The difference between the circuit is the device used between source to load. In a controlled rectifier, Thyristor is used to control the voltage from zero to Maximum. The source voltage is controlled using the thyristor.
In this article, the source voltage Vm sinwt is fed to the Resistive load through the thyristor. The thyristor is a unidirectional device, the device is conducted when the anode is positive with respect to the cathode.
Moreover, the current flow takes place only when the device is triggered. The device can be triggered with firing angle α. Once the device triggered after the delay angle the device is starts conducting.
The output voltage Vo starts to rise from zero to Vmsinα. Since the load used in the article is Resistive load, therefore the io is in phase with Vo.
Single Phase Half Controlled Rectifier
Fig. 3. Single Phase Half Controlled Rectifier
The firing angle of a thyristor, also known as the conduction angle or delay angle, is the angle in electrical degrees between the instant at which the voltage across the thyristor becomes positive and the instant at which the thyristor starts conducting.
In simple terms, it is the angle at which the thyristor is triggered into the on state during each cycle of alternating current (AC) voltage. The thyristor is triggered at every zero crossing of the input source.
When the SCR is turned on, load current flows until it is turned off by voltage reversal at wt= p, 3p, etc. Load current drops to zero at these angles, and the device is shut off shortly after the supply voltage reverse biases the SCR.
The phase relationship between the start of the load current and the supply voltage can be changed by adjusting the firing angle; thus, the term phase control is used for such a way of managing the load currents.
A single-phase half-wave circuit generates only one pulse of load current per source voltage cycle. A single-phase half-wave thyristor circuit is represented by the circuit. The thyristor conducts from wt = α to  p, (2p+α) to 3 p, and so on. Load voltage V0 = 0 during the firing angle delay, whereas V0 = Vs during the conduction angle (p -α).
The average load voltage declines from the maximum to zero as the firing angle increases from zero to p. In Fig.4, the variation of voltage across the thyristor is also depicted as VT.
Fig. 4. Half Controlled Rectifier Output
Thyristor remains on from wt = α to p, (2p + α) to 3p, and so on, with VT = 0 during these periods. It is off from p to (2p + α), to (4p + α ), and so on; throughout these off intervals, VT has the supply voltage Vs waveshape. It is possible to see that VS= Vdc + VT.
The Circuit turn off time tc=p/w
Where w =2pf and f is the supply frequency in Hz.
The average voltage VO across load R for the single-phase half-wave circuit is given by
The maximum value of Vdc is obtained at α = 0o
The RMS Voltage of the single-phase half-controlled rectifier is obtained
Matlab source code for half-controlled rectifier with R load
% Parameters
Vrms  =   230;            % RMS value of input AC voltage (in volts)
Frequency  =  50;       % Frequency of the input AC voltage (in Hz)
R  = 10;                       % Load resistance (in ohms)
T   =  1/Frequency;     % Time period of the input AC voltage (in seconds)
Vm   =  Vrms*sqrt(2);  % Peak value of the input AC voltage (in volts)
alpha   =   30;              % Firing angle (in degrees)
% Time vector
t   =   0:0.0001:T;
% Calculate the firing angle in radians
alpha_rad   =   alpha * pi / 180;
% Calculate the input AC voltage waveform
Vin   =   Vm * sin(2*pi*Frequency*t);
% Half-controlled rectifier operation
Vo   =  zeros(size(t));
Vo(t <= alpha_rad/Frequency)  =  Vm * sqrt(2) * sin(alpha_rad);
Vo(t > alpha_rad/Frequency)   =  Vm * sqrt(2);
% Calculate the output voltage waveform
Vout   =  Vo .* sin(2*pi*Frequency*t);
% Plot the input and output waveforms
% Plotting the waveforms
figure;
subplot(2,1,1);
plot(t, Vin, 'b', t, Vo, 'r');
title('Input and Output Voltages');
xlabel('Time (s)');
ylabel('Voltage (V)');
legend('Input Voltage', 'Output Voltage');
subplot(2,1,2);
plot(t, Io, 'g');
title('Output Current');
xlabel('Time (s)');
ylabel('Current (A)');
Matlab Simulink Circuit of Half-controlled Rectifier With Load
Fig.5. Simulink Circuit of Half-controlled Rectifier With R Load
Simulink Result
Matlab Simulink Response of Half-controlled Rectifier With R Load
Fig.6. Simulink Response of Half-controlled Rectifier With R Load
Reference
  1. “Power Electronics” P. S. Bimbhra, Khanna Publishers, 2012
  2. “Power Electronics: Circuits, Devices and Applications”, M H Rashid, Pearson     Education
  3. “Power Electronics”, M-Scheme, K.V. Kandasamy, 2020.
  4. https://in.mathworks.com/matlabcentral/fileexchange/90681-single-phase-half-wave-controlled-rectifier-with-resistance
  • Thyristors Turn ON Methods
  • Thyristor History, Types, Principle
  • IGBT Characteristics & Advantages
  • Power Electronic Devices Specifications
  • Power Diode Characteristics & Advantages
How to Test TRIAC with Multimeter
What is Power Electronics? Evolution, Block Diagram, Advantages
Turning Off SCR – Commutation
Thyristors – Working, VI Characteristics, Turn ON Methods
IGBT – Symbol, Construction, Working, Characteristics, Advantages
Top 100 Power Electronics Projects for Engineering Students
SCR Triggering Methods
Single-Phase Mid-Point Converter – Bridge Rectifier with Center Tap
Power Transistor – Structure, Biasing, Characteristics, Advantages
Power Electronics – Phase Controlled Half Wave Rectifier RL Load
Crowbar fault protection circuit
How to test SCR using Multimeter
How Snubber Circuit works ?
SCR Full Bridge Converter
Power Electronics – Full-wave Rectifier With R and RL Load
SCR Class B Resonant-Pulse Commutation
Thyristor Commutation Techniques – Types, Working Principles
igbt-symbol
Types of IGBT
Single Phase Half-controlled Rectifier RL Load With FD
Phase-Controlled Half-Wave Rectifier With Freewheeling Diode
Types of Power Electronic Devices
Power Electronic Devices Specification and Classification
R R-C Firing Circuits Disadvantages
Power MOSFET Symbols
Power MOSFET – Symbol, Types, Working, Characteristics, Advantages
Resistance firing of an SCR in a half-wave circuit
Thyristor Triggering Circuits – Types, Explanation, Waveforms (SCR)
Gap Voltage of Bently Nevada Vibration Probe
Electric Circuits Objective Questions – Set 10
igbt-symbol
Types of IGBT
SCADA backup too has been configured
FactoryTalk Studio and SQL Server for Data Logging
Working Principle of Water Chillers
HVAC Water Chillers Principle
Types of Diodes Quiz
Double-Acting Pneumatic Cylinder Circuit
Pneumatic Cylinder Movement Control with Timer Circuit
Basics of Explosion Protection
