Reading: Nuclear Level Detectors Cascade or Master/Slave concept
Inst Tools > Blog > Guest Articles > Nuclear Level Detectors Cascade or Master/Slave concept
Last updated: September 2, 2019 4:38 pm
Guest Articles Level Measurement
A typical Nuclear / Nucleonic source and detector level measurement is shown in Below Fig 1.
Single Source – Multiple DetectorsMultiple Source – Multiple DetectorsWiring of master and Slave detectors
Nuclear Level Measurement
Also see : Nuclear Level Detectors Animation
In certain process applications, the vessel or tank level measurements may vary from 2 mtrs to 30 mtrs or more.  In the Nuclear / Nucleonic Level Instruments, detectors are available with standard lengths varying from 2 meter to 6 Meter. Standard length varies from supplier to supplier from 2 mtrs ~ 6 mtrs.
In the case of a larger length of level measurement, multiple detectors will be required, and the detectors need to be connected in cascade mode to cover complete level measurement length of the vessel. Sometimes the single nuclear source may not be able to cover the complete level measurement length, so multiple nuclear sources may be required. This is determined via Nuclear Source strength calculations.
When multiple detectors are used, the same required to be connected in Master-Slave configurations.
The Master detector aggregates (sums up) the signal received from all slave detectors and the output of the master detector corresponds to the total level measurement range of the vessel. The master output is connected to Control System (e.g. DCS) which may be 4-20 mA or serial signal.  A detector located either at Top or at Bottom can be configured as Master Detector based on manufacturer recommendations.
The example shown in the article has master at the bottom.
In the below configuration, the nuclear source is single and there are two detectors that cover the level measurement range. Hence there is only one master and one slave detector required.
Nuclear Level DetectorsMultiple Source – Multiple Detectors
In the below configuration, two no’s nuclear source and four numbers of detectors are required to cover the whole level measurement range. Hence there will be one master and three slave detectors.
Nuclear Level Measurement Multiple Source and Multiple Detectors Principle
The master detectors have the limitation of maximum no of slave detectors connected (which varies for each supplier); hence we may have to use more than one master detector.
In such cases, both master detectors outputs are connected to a summator device (which may be located at Field or it can be remote) and total output is connected to the DCS system (Below Fig).
Nuclear Level Sensor using Master and Slave
The typical wiring diagram of multiple detectors is shown below. Each detector generally has cascade input, cascade output, cascade ground, and HART output capability. However when detectors are wired in master-slave configurations, then cascade output of slave is connected to cascade input of other slaves.
The master detector 4 -20 mA output is connected to DCS system which will correspond to total level measurement range.
Wiring of Nuclear Level Detectors
In certain cases, the current output (4 ~ 20mA) of each detector is also taken to DCS system and the level measurements are mapped in DCS system to arrive at total level measurement (Below Fig 6).
Nuclear Level Sensors Wiring in Cascade
Also Read : Level Transmitter & Level Gauge Design Tips
Article by :
Nilima singh
Instrumentation and control Engineer
13 year experience in Detail engineering
Worked on various Refinery, Oil & Gas, Petrochemical and chemical projects
Level Measurement Terminology
Magnetostrictive Level Transmitter Working Principle
Guided-wave Radar Level Measurement Animation
Stilling Wells for Level Measurement
Basics of Level Measurement
Non-Contacting Radar Level Transmitter Working Principle
Magnetic Level Gauge Working Principle Animation
PLC Program for Conditional Control Logic
Ultrasonic Level Transmitter Principle, Limitations, Calibration and configuration
Hydrostatic Level Measurement
ElectroMechanical Level Measurement Working Principle
Compressor & Compressor Valves Maintenance
RF-Capacitance Level Switch Principle
Calibration Procedure of displacer type Level transmitter
Calibration of Displacer Level Transmitter
FMCW Radar level transmitter Working Principle
FMCW Radar Level Transmitter Working Principle
DP Transmitter Capillary arrangement
Displacer Level Transmitter Intrenal Diagram
Displacer Level Transmitter Working Principle
Instrumentation Impulse Lines
All About Instrumentation Impulse Lines
potentiometric level measurement principle
Vibrating Fork Level Switch Working Animation
PLC Memory Organization - Data Files and Program Files
PLC Memory Organization – Data Files and Program Files
4-20 mA Conversion Formulas
Standard 4 to 20 mA Conversion Formula
Simatic Prosave HMI
How to Backup and Restore from Simatic Prosave HMI?
Allen-Bradley MicroLogix controller
Programmable Logic Controller (PLC) Questions and Answers – 16
PLC Sequential Lights Control Example
PLC Timer Example: Sequential Control of Three Lights with Reset
Air Circuit Breaker Principle
High Voltage Circuit Breaker Principle
Relay Circuit for Hooter with Reset Button
Relay Latching Circuit using Push Button
