Reading: Microwave Flow Sensor – Working Principle and Applications
Inst Tools > Blog > Animation > Microwave Flow Sensor – Working Principle and Applications
Microwave Flow Sensor is a Non-contact Flow Sensor that emits microwaves of 2.4GHz from the tip of its sensor to detect the flow.
Last updated: November 1, 2023 10:24 am
Animation Flow Measurement
2 Comments
3 Min Read
Microwave Flow Sensor is a Non-contact Flow Sensor that emits microwaves of 2.4GHz from the tip of its sensor.
Microwave Flow SensorApplications of Microwave Flow Sensor
Reflected from the surface of powders and solids traveling in a pipeline, the microwaves get modulated in their frequency on the Doppler effect principle.
The sensor, detecting the frequency difference between transmitted and reflected microwaves, transforms it and generates an equivalent output signal.
It can reliably detect a little flow or motion of the powder or the grain in chutes or pneumatic conveying lines, which has so far been considered to be very difficult.
A microwave-based motion detector detects the Doppler shift of the flowing material.
A complete flow detector consists of a transmitter and transducer.
The transducer has a Gunn diode configured within a waveguide (horn) antenna and functions as both a microwave transmitter and receiver. The transmitter contains the measuring electronics and relay output.
The Gunn diode emits a low-power, continuous signal that is reflected from moving material in the process.
It monitors the movement of bulk materials and can be used to detect and indicate material blockages or feeder shutdowns.
microwave flow sensor Animation
If the reflecting medium is moving, there will be, in accordance with the Doppler effect, a frequency shift between the transmitted and the received signals.
The frequency shift is proportional to the velocity of the process material. The transducer superimposes the transmitted and received signals.
Since the two frequencies differ only slightly, the differential signal produced is low frequency.
This low-frequency signal is delivered to the electronics by capacitive coupling and processed in a low-frequency amplifier.
The monitor’s Solids Flow Detector and Indicator can be used in a variety of applications to detect flow/no-flow conditions of powders and solid materials.
  • Detection of a partial or full plug in a conveying line
  • Detecting the bridging of material in a storage vessel upstream
  • Sensing inadequate or a lack of flow due to upstream equipment failure (conveyor, blower, diverter valve, feeder)
  • Verifying flow conditions Arrow Turning on/off equipment or processes downstream
microwave flow detector applications
  • DP Transmitter Interface Level
  • Types of Vortex Flow Sensors
  • Field Instrumentation Questions
  • 3-15 psi to 4-20mA Conversion
  • Why Turndown Ratio is important?
Basics of Butterfly Valves
Spring Loaded Variable Area Flow Meter Working Principle
How a 4-20mA Transmitter Works?
DP Flow Transmitter Re-Ranging Calculation
Coriolis Flowmeter Advantages and Limitations
Differential Pressure (DP) Flow Meters Range Calculation Methods
2 Comments
  • Narasimha Reddy Y says:
    November 7, 2016 at 3:23 pm
    Dear Sir,
    We are into manufacturing and marketing of flowmeters (www.accurateflowmeters.com). Kindly email the flow measurement articles. You are writing the articles so that even a layman like me can easily understand. But we are not able to download or save them to our computer. Kindly guide us.
  • Dhivyainst says:
    January 20, 2017 at 1:46 pm
    Really super, giving practical exposure
Limit Switch Animation
Online Simulation
Four Way Solenoid Valve Working Principle
Difference between Orifice & Restriction Orifice
Ultrasonic Level Switch Working Principle
Lobed Impeller Flow Meters Working Principle
Impeller Flow Sensor Working Principle and Animation
Target Meter Principle
Target Flow Meter – Working Principle, Advantages, Disadvantages
How a Level Switch Works
DC Circuit
Main differences between Sinking and Sourcing Circuits
Air Filter Regulator Working Principle Animation
multi-variable transmitter
Mass Flow Meters
DP transmitter
Square-root characteristics of Differential Pressure Flow Meters
Switched Mode Power Supply (SMPS)
Proximity Switch Working Animation
Site Commissioning Steps for PLC Programmers
Poorly Built Switchgears
Difference between Feedback, Feedforward, and Cascade Control
Difference between Feedback, Feedforward, and Cascade Control?
Infrared Hydrocarbon Gas Detector Calibration Procedure
full-wave-bridge-rectifier-with-voltage-regulator
Basics of Voltage Regulators
Diode Rectifier
Valve Actuator Passing
Lessons Learned from Actuator Passing Incidents
PLC Motor Logic
