Reading: Magnetic Flow Meter Liner Damaged and Winding Burnt
Inst Tools > Blog > Root Cause Analysis (RCA) > Magnetic Flow Meter Liner Damaged and Winding Burnt
Instrumentation engineering root cause analysis of magnetic flow meter liner damaged and winding burnt problem.
Last updated: September 28, 2022 2:51 pm
S Raghava Chari
6 Min Read
Instrumentation engineering root cause analysis of magnetic flow meter liner damaged and winding burnt.
Magnetic Flow Meter Liner DamagedMagmeter Recovery Benefits
Article Type:Root Cause Analysis (RCA)
Category:Instrumentation
Equipment Type:Instruments
Author:S. Raghava Chari
None could repair winding burnt & Extensively Damaged flow tube liner Magnetic Flow Meter.
Problem: The mag flow meter flow tube (FT) is 800 mm long 1”Sch 40 both ends collared and CS loose-flanged SS pipe spool. 3 mm thick PTFE or similar electricity insulating process compatible lining insulates the flowing liquid from the SS pipe along the FT length.
The manufacturer declined relining the FT and even supplying a replacement lined tube telling no field repair possible. Relining vendors also declined telling the too small bore pipe lining is impractical.
The author lined it himself thus and put the mag meter back online:
  1. Unscrew and save the electrodes and their ceramic bushes, scrape out damaged the liner to bare the metal and sand blast tube bore
  2. Cut a bought out 30-mm dia carbon filled Teflon rod – rod from now on – to length = collar-to-collar FT length L+100 mm
  3. Reduce the rod dia for hand pushing into FT uniformly flame heated to ≈ 200o C
  4. Light-tight vice hold the FT and Insert the rod into the FT both ends projecting equally. Allow to cool to room temperature
  5. Bore the rod 20 mm ID.
  6. Flare the ends using shop made 45o, and 90o 6 mm radius fillet radius flaring tools – see fig. Cut out the excess liner protruding beyond collar OD
  7. Make 10 mm thick x 1” 150 # flange raised face dia CS plate 1; Screw in a ¼” Sch 40 NPT threaded short nipple at the center. Likewise make 1/8” NPT screwed CS plate 2.
  8. Bolt plate 1 to FT left side using CS flange and plate 2 to FT right with proper gaskets
  9. Connect 10 bar steam to plate 1 and leave plate 2 free Maintain 4-hours steam flow to cure the liner to the SS pipe
  10. Remove the curing steam connections
  11. Drill hole in the liner at the FT electrode hole location and insert the saved ceramic bush
  12. Pass a long noose ended twine via the ceramic bush, and pull it out FT left end. Untie the noose, insert it via the electrode hole and tie the electrode. Pull the ceramic bush end string, manipulate the electrode via the ceramic bush with a wooden scale or similar flat wood piece and tighten the electrode nut. Remove the twine. Now top electrode is in position
  13. Insert and tighten bottom electrode to FT the same way
  14. Assemble the coils over the lined FT. Mag Meter is ready for use.
  15. E.g. we want to calibrate the head for 0-300 LPM i.e. 0 to 15.92 m/sec liquid velocity for this head of 20 mm bore. Hence, connect the placed on floor head to a table held receiver instrument of scale 0-300 LPM calibrated for 15.92 m/s velocity
  16. Connect a fire hose to FT left flange (see fig). Hose connect FT right flange to a reference meter e.g. target flow transmitter. Alternatively arrange to collect and weigh water flown during stopwatch-timed period.
  17. At zero flow and making sure of water filled FT, the reason for placing the magmeter on floor and bolting me magmeter to upwards flow pipelines – adjust left potentiometer on the head to make the mag meter receiver read zero. Open the fire hydrant and adjust the flow for say 250 LPM shown by the reference. Adjust the head span potentiometer. Verify the reading near midscale.
  18. Dissemble the set up; return the various components. The mag meter is for plant use.
Assembled Magmeter Field Calibration
See the benefits below.
  • Enabled production reduction within 8-hours and met the committed orders
  • Besides the financial gains, it preserved image as a reliable phosphate fertilizer supplier
  • Saved a head purchase costs
  • Found a way to handle future such problems
Author: S. Raghava Chari
  • Pressure Switch Screwed Cover
  • Doubtful Temperature Readings
  • Level Instruments Stopped Working
  • Thermowell Shank to Flange Leaks
Cooling Tower Fans Frequently Failing
Urea Reactor Top Bolted Plug developed Leaks
Arc Fault Breaker (AFB) Electrical Problem Solved
Compressor Cracked Shaft Spacers
Pitot-tube Replaced with Innovative Segment Orifice Plate
  • Sourabh K says:
    September 29, 2021 at 10:44 am
    Very informative info of mag meters
Control Panel Instruments Problem Threatened Plant Shutdown
Hunting of Control Valves
RCA Related to Trip Throttle Valve (TTV)
Steam Letdown Station Problems and their Solutions
Boiler Feed Water Heater Shell Flange Leaks
Steam Pressure Taps Primary Block Valves Glands and Bonnets Leaks
Instrument Steam Pressure Taps Primary Block Valves Glands and Bonnets Leaks
Jacket Added Seawater Pipe Spool
Seawater Pipeline Spools from day-1 leaks threaten Plant Shutdown
Turbine Flow Meter (TFM) Field Calibration
Turbine Flow Meter (TFM) Field Calibration Uncommon Request
Centrifugal Compressor outage reduced
Centrifugal Compressor Outage Reduced – Root Cause Analysis
Mechanical Temperature Indicators (MTI) Problem
Control Valves Leak Tightness
Control Valves Leak Tightness Restoration Pose Difficulties
Alternate 110 KV Connection to Feeder A
PLC Program for Alarm Indication in Process
Torque Measurement Objective Questions
Anti-static Wrist Straps
Motor Disconnector Switch
What is a Motor Disconnector Switch? – Purpose, Principle, Factors
Damaged Magnetic Flow Meter Flow Tube
None Could Repair Slightly Damaged Magnetic Flow Meter Flow Tube
PLC Handbook
PLC Handbook
Centrifugal Compressor Shaft Vibrations Problem
Measurement and Instrumentation Objective Questions – Part 2
