Reading: Layer-2 and Layer-3 Network Switches
Inst Tools > Blog > Communication > Layer-2 and Layer-3 Network Switches
Two of the most widely used network switches are layer-2 and layer-3 switches. Learn the differences and the advantages.
Last updated: May 5, 2024 8:34 pm
Communication Control Systems
6 Min Read
In networking, switches play a very important role. Because of the large amount of data communication happening between devices nowadays, network switches have always played a role even before too. And as we know, network communication happens on the basis of OSI layer architecture.
What is a Network Switch?What is the Layer-2 switch?What is the Layer-3 switch?Difference between Layer-2 and Layer-3 Network Switches
So, understanding OSI layers is an important study required for determining which type of network switch to use. Two of the most widely used network switches are layer-2 and layer-3 switches. In this post, we will learn the difference between layer-2 and layer-3 network switches.
First of all, before jumping into the topic, let us first understand what a network switch is. Suppose there are two Ethernet devices. Each of the devices has it’s local communication port, and they want to communicate with each other through Ethernet. Just connect a cable directly between the two local ports, and they will start communicating.
But suppose, there are four devices in the network that want to communicate with each other. Now, a device cannot have four local ports in it. And suppose if it has too, then how complicated will you create a network by just directly connecting between devices and making so many loops. For that scenario, a device called a network switch is used.
A network switch has many Ethernet ports on it. So suppose four devices want to communicate, then just connect a single cable from each device to this switch. This means, the switch will have four of its ports occupied through this. Due to this configuration, all the four devices can communicate with each other.
Otherwise, networking would have not been possible. So, a network switch is a device which is used to establish networks between devices by acting as an interface between them.
Now that we have understood what a network switch is, let us come to our topic now. A network is established based on OSI layer architecture. It consists of seven layers starting in ascending order – physical, data link, network, transport, session, presentation, and application.
Each layer has its own function. Now, a layer-2 switch is the one that operates in layer no.2 (data link). In the data link layer, the MAC address of the device is defined. When a device wants to communicate, it will pass the destination MAC address to the layer-2 switch. The switch will browse the network for the destination address and send the data to it.
However, a layer-2 switch cannot communicate with devices of different IP address ranges. This means, that suppose a device has an IP address of 192.168.1.23 and the other has 192.168.2.45. Both are not in their range and have their corresponding subnets.
This means the first device can only communicate with a device having an address from 192.168.1.1 – 255 and the second device can only communicate with a device having an address from 192.168.2.1 – 255. So, a layer-2 switch can establish networks based on the same IP address and identify devices by MAC addresses.
A layer-3 switch is the one that operates in layer no.3 (network). In the network layer, the IP address of the device is defined. When a device wants to communicate, it will pass the destination IP address to the layer-3 switch. The switch will browse the network for the destination address and send the data to it.
This definition shows that the switch can even send data to a device of different IP address range. S, the example discussed above can work in this switch. To do this, you have to define the DNS address in the device and switch. A DNS address will interlink various networks easily. Apart from DNS, it can also interlink different gateway range devices.
  1. The layer-2 switch is cheaper than the layer-3 switch. So, small and medium-sized applications prefer layer-2 switches, and complex networks that require vast amounts of interlinking between various devices use layer-3 switches.
  2. The configuration of layer-2 switch is easier than layer-3 switch.
  3. Layer-3 switches have advanced security features in it as compared to layer-2 switches.
  4. Layer-2 switch works on MAC address, and layer-3 switch works on IP address.
  5. The speed of a layer-2 switch is faster than a layer-3 switch.
  • Cyclic and Acyclic Communication
  • What is Open Systems Interconnection?
  • Network Topologies Selection Factors
  • Data Handling Instructions in PLC Programming
  • Difference between TCP/IP Model and OSI Model
Importance of Grounding Electronic Equipment
What is OPC ?
FF Signal Status
Identify Faults in PID Control Loop
What is ERP in Industrial Automation? – Enterprise Resource Planning
H1 FF Device Configuration and Commissioning
Tuning a Liquid Level Process Control Loop
Latest ProfiBus Questions and Answers
How to tune a PID Controller ?
HART Communication Tutorial Part 2
What is a Transducer ?
What is a Active Barrier ?
Control systems in industrial projects
Interactions With Process Control Systems Philosophy
de-energized-to-safe-mode
Why Grounding
Basics of Grounding
How Engineers Effectively do Problem-solve and Troubleshoot
Control Sytem Open Loop and Closed Loop
Introduction to Control System
Commissioning Checklist for Industrial Automation System
Commissioning Checklists for Industrial Automation Systems
2-wire loop-powered transmitter
Loop Controller HART Signal Noise
Proportional Band example
Why Offset in Proportional Controller ?
Calibration of Pyrometers using Black Body
PID Control Theory
Overview of PID Control terms
Schottky Diode Vs PN junction Diode
Difference between Schottky Diode and PN junction Diode
Transformer Operation Under No-Load
Humidity Calculator
Humidity calculator
Ash Handling System in Thermal Power Plant
Control Systems Questions & Answers
Control Systems Objective Questions & Answers – Set 4
Electrical Machines Short Answers
