Reading: Induction Motor Torque Versus Slip
Inst Tools > Blog > Electrical Theory > Induction Motor Torque Versus Slip
Last updated: August 6, 2018 4:06 pm
Electrical Theory
2 Min Read
The torque of an AC induction motor is dependent upon the strength of the interacting rotor and stator fields and the phase relationship between them.
Torque can be calculated by using below Equation.
T = K Φ IR cos θR
where
Τ = torque (lb-ft)
K = constant
Φ = stator magnetic flux
IR = rotor current (A)
cos θR = power factor of rotor
During normal operation, K, Φ, and cos θR are, for all intents and purposes, constant, so that torque is directly proportional to the rotor current. Rotor current increases in almost direct proportion to slip. The change in torque with respect to slip (Below Figure) shows that, as slip increases from zero to ~10%, the torque increases linearly.
As the load and slip are increased beyond full-load torque, the torque will reach a maximum value at about 25% slip. The maximum value of torque is called the breakdown torque of the motor. If load is increased beyond this point, the motor will stall and come to a rapid stop.
The typical induction motor breakdown torque varies from 200 to 300% of full load torque. Starting torque is the value of torque at 100% slip and is normally 150 to 200% of full-load torque. As the rotor accelerates, torque will increase to breakdown torque and then decrease to the value required to carry the load on the motor at a constant speed, usually between 0-10%.
induction motor torque versus speed
Figure : Torque vs Slip
Impedance in RL Circuits
Batteries Theory
Three Phase Transformer Connections
Compound Generators
DC Motor Speed
High Voltage Circuit Breaker Principle
Battery Terminology
Simplified Formulas for Parallel Circuit Resistance Calculations
Block Diagram
DC Motor Theory
AC Generator Voltage Regulators
Single Phase Power Wiring Schemes
Types of Batteries
Single Phase AC Induction Motors
3-Wire, Three-Phase Delta Wiring System
How to Measure Specific Gravity of Battery
Capacitor and Symbols
Capacitance
Voltage Polarities
Voltage Polarity and Current Direction
DC Machine
DC Generator Internal Losses
circuit breaker principle
What is a circuit breaker ?
3φ AC Power Connections
Three Phase Systems
Power Factor Meter Principle
Induction Motors Faults and Protection
Digital Pressure Gauge Animation
Air Pressure Inside the Tank
Difference Between MPCB and MCCB
Electronics and Communication Engineering Projects
175 Electronics and Communication Engineering Projects
Intelligent Motor Control Center
What is an Intelligent Motor Control Center? – IMCC
Power Systems MCQ Series 17
What is a Servo Valve?
What is a Servo Valve? – Principle and Advantages
How to Prevent Conveyor Problems
Common Conveyor Problems and How to Prevent Them
