Reading: What is Function Module in Siemens PLC?
Inst Tools > Blog > PLC Tutorials > What is Function Module in Siemens PLC?
Function Module in Siemens PLC is used in motion control applications where speed and accuracy are a must for field devices.
Last updated: March 4, 2021 11:18 am
In this article, we will learn about the function module which is used in Siemens PLC.
Why the function module? you may ask, as we have other modules are available to connect field devices.
This is because some devices need special functions like, very fast, and accuracy for some applications, they may not require the main CPU to handle these tasks.
The best suitable example is in motion control application where speed and accuracy are a must.
For example, we have a speed sensor need to connect it with the PLC, but we can’t connect it with regular module because it won’t provide that accuracy and precision.
Here, that’s why we use FM (Function Module) to connect the speed sensors or any other motion control devices to get accurate data.
It works independently of the main CPU. What does that mean you may ask?
FM works exactly the same as what CPU & I/O module work together which results in taking the load from the main CPU.
Like CPU, FM receives a signal, processes the logic, and executes the output.
Now, before the selection of FM, you have to know your requirement like what kind of processor you need, memory space, operating system, etc.
 Function Module
Let’s consider a function module FM456-2 which is an application module used in s7-400 PLC.
This module provides a high-frequency rate.
FM456-2 is used in an application like plastic technology, process system, textile industry, packaging industry, etc.
It can perform tasks like controlling, positioning, counting, data exchange with PG/PC, event-driven programming, communication, etc.
It also uses flash memory to store the program permanently as the main CPU does.
It comes with different memory storage ranging from 4 MB up to 16 MB.
Expansion Socket
To install it first check the power supply and connect other necessary modules using an expansion socket as you can see in the above image.
After adding expansion modules, plug it onto the rack as shown in the below window and screw it up.
A memory card slot is used to store the program and the selector switch is used to change the mode (STOP/RUN).
Module Memory Card Slot
Now, probably you may have one more question come to your mind that, is the programming and its software remain the same?
The answer is yes. It won’t require any additional software for the programming. It looks exactly the same, the only thing changed is the functionality of the module.
Author: Suhel Patel
  • Meter check of a diode
  • PLC Sinking and Sourcing
  • PLC Bottle Filling System
  • Communicate PLC & Excel
  • Point to Point Network Topology
Timer during Motor Direction Change PLC Program
ON Delay Timer using PLC
Rules for Writing SCL Language in Tia Portal
Auto and Manual Liquid Tank System: PLC Program Example
PLC Raw Count Calculation for Pressure Transmitter
  • jitendra meena says:
    July 30, 2020 at 6:09 am
    thank you for this article
How to Detect Speed of Conveyor in PLC?
PLC Digital Signals Wiring Techniques
Timers in PLC Programming – Siemens Tia Portal Tutorials
PID Controller Output Types – PID_PWM and PID_Output
#2 PLC Best Practices – Track Operating Modes
Siemens PLC Mathematics Instructions
How to Read an Electrical Wiring Diagram?
PLC Program for Valves
PLC Pump Permissive Interlocks
Database in Siemens PLC
Steps to Configure TCP/IP Communication in Siemens S7-1200 PLC
PLC Software Redundancy
Software Redundancy in Siemens PLC – Hardware versus Software
PLC Motor Control Circuit
Motor Trip Logic using PLC Programming
Download a Ladder logic program to GE PLC
Gas Turbine Temperature Control using Siemens Tia Portal
How to set password in Siemens HMI
How to Password Protect HMI in Siemens TIA Portal?
LogixPro Simulator Software
Level Transmitter with Zero Suppression
DP Level Transmitters Compensation Techniques
Common Materials used in Instrumentation Cables
MCQ on PLC (Programmable Logic Controller)
Functional Block Diagram PLC Example for Traffic Light System
Programmable Logic Controller Boiler Logic
PLC Ladder Logic for Start-up Control of Boilers
Analog signal with noise
Signal Coupling and Cable Separation
wedge Flow meter
What is a Segmental Wedge Flow Meter?
Magnetic Tape Recorder Principle
What is Magnetic Tape Recorder ?
