Reading: Difference between PLC and Computers
Inst Tools > Blog > PLC Tutorials > Difference between PLC and Computers
In this article, we will discuss the major differences between a programmable logic controller (PLC) and personal computers.
Last updated: October 17, 2023 3:16 pm
PLC and Computer ArchitectureWorking Temperatures and EnvironmentPLC Processor and MemorySoftwareInstallation and MaintenanceCommunicationProgrammable Automation Controller (PAC)
PLC and personal computers (PC) are sharing the same architecture. Input devices of Computers are keyboards and mouse but PLC is having Input ports for making the communication.
The common input devices of a PLC are switches, sensors connected to the respective input modules. The common output devices of a PLC are control valves, VFD drives, Solenoid valves connected to the respective output modules.
We can able to make personal computers (PCs) to work as PLC if we add some modules to execute the pre-written program. Both are having processors for doing their process.
Features of the personal computer require clean space and sometimes air-conditioned room for its lifetime operation but PLC is designed in such a way that it can withstand industrial environments like different ambient temperatures and humidity. It can also withstand electrical noise.
A simple PLC can work in a personal computer environment but personal computers cannot work in a PLC environment (for example hazardous areas).
We cannot find computer’s IO like keyboard, monitor and CD port in PLC. Only processors with memory space are common in both devices.
PLC is equipped with different types of input and output modules and communication ports for making communication with other devices.
Software
Computers with installed software can do the required operation simultaneously in any order rather in PLC the process will be sequential, it should be in the order of how we write the program to execute the application using logic (top-to-bottom.
The control system of PLC is built such that it can be easily installed and maintained.
Indicators of IO’s (inputs and outputs) over the PLC hardware will be helpful in troubleshooting. The input-output (IO) modules can be easily removed and replaced.
Communication
PLC software’s running on a personal computer can make communication with other user interface software.
We can use those software’s like Virtual basic /HMI as the front end for making communication with PLC and operator. PLC programming software’s like RSLOGIX, Simatic Manager, Tia Portal are used for writing logic for PLC.
In Industry, operators can interact with only front-end software but not with PLC programming software, only the programmers or engineers can able to deal with it (example-ladder logic).
Programmable Automation Controller (PAC) introduced in some industry which will be the PLC control with PC based system.
PAC is a combination of PLC’s features and PC functionalities. In an advanced control system with data logging features, signal processing, Motion, and vision control, PAC is recommended.
Author: Hema Sundaresan
  • Main Parts of a PLC
  • Cybersecurity in PLC
  • Yokogawa DCS Tutorial
  • Ladder Logic Simulator
  • Introduction to PLC
PLC Program for Controlling Sequence of Conveyors with Interlock
How to Detect Speed of Conveyor in PLC?
Connecting Faceplate to PLC Project – HMI Tutorial
Communication between InTouch Scada and Allen Bradley PLC
Mixing Program with Timers and Counters in Omron PLC
Proper Earthing Practices Used for PLC Control Panel
Quiz: Identifying I/O Examples in PLC Systems
What are Analog Inputs? – Analog Signals Processing in PLC
Surface Grinding Process using PLC Program
How to Operate a Group of Induction Motors using PLC Logic?
Connecting Blocks in Functional Block Diagram – Studio 5000
Applications of SCADA
TIA Portal MOVE Instruction
MOVE Instruction in PLC – What You Need to Know?
ControlLogix Architecture - Rockwell Automation
ControlLogix Architecture – Rockwell Automation
PLC Instruction List Code
Top 100 PLC Projects List
Difference between PLC and HMI
Free Download PLC Book
Claw Machine PLC Programming
Doll Claw Machine using Omron PLC Programming
PLC Program for Conditional Control Logic
SCR Commutation Objective Questions
List of 100 Industrial Instrumentation Questions
List of 300 Industrial Instrumentation Questions
Flame Detectors Working Principle
C-Type Bourdon Tube
Types of Bourdon Tube
Electromagnetism Objective Questions and Answers
200+ Electromagnetism Objective Questions and Answers
IPv4 vs IPv6 - What’s the Difference Between IP addresses
IPv4 vs IPv6 – What’s the Difference Between IP addresses?
