Reading: Design a Program Using Studio 5000 and FactoryTalk View Studio
Inst Tools > Blog > PLC Tutorials > Design a Program Using Studio 5000 and FactoryTalk View Studio
Learn how to design a sample project involving PLC and HMI programming using Studio 5000 and FactoryTalk View Studio software.
Last updated: May 7, 2024 10:12 am
In Rockwell automation, one of the most used software is Studio 5000 and FactoryTalk View Studio. Many new programmers who want to work on this platform often tend to learn new things on it, due to the vast variety of features it offers.
Also, it is very user friendly and makes programming very quick to understand and design. So, before developing a project, it is necessary that some basic concepts are understood first which can aid it quickly.
In this post, we will learn how to design a sample project using Studio 5000 and FactoryTalk View Studio.
Refer to the first image. The Rockwell PLC software supports the following four languages – ladder logic, structured text, functional block diagram and sequential flow chart. In their language, it is called routine. You can add the routines in the program as highlighted.
You can add as many programs as you want. If you see the flow, a program too is added in a task. Here too, you can add as many tasks as you want.
A task has the properties as shown in the second image, which is common in all the PLC’s. So, the flow goes like – task has a program and program has a routine.
Studio 5000 Design Software
In a routine, once you start developing tags, you will need to define them. Right-click the tag to define a new one and you will find the following properties.
Here, you have to define its data type and other properties. You can then view the tags created in the controller tags section as shown on the left-hand side of the control bar.
Studio 5000 with FactoryTalk View Studio
Then, you need to add the section we created in task configuration through an instruction called JSR (jump to subroutine). It is used for calling the routine you created and executing it during processing runtime.
If a particular routine is not added in JSR, then it will not execute.
PLC and HMI Programming Using Studio 5000
Now, we head on to the graphics part. In Rockwell automation, one thing to remember is that you first need to create a path in software called RSLinx Classic, which communicates between a PLC program and an HMI program. Refer to this article for more details.
Now, we created a path called Test as shown in the figure below, and assigned the corresponding path. This is the path which will communicate between the PLC program and HMI program. It is very necessary to do this, otherwise the tags will not reflect the values in HMI graphics.
Communicate between the PLC program and HMI program
Now, take a screen and place a push button on it as shown in figure below. The button will have the properties as shown. Here, you have to link the tag of your PLC program with the path you defined in FactoryTalk Linx path.
Accordingly, you can design your screens and link the variables of your PLC program. But, remember that the path must be correct.
Sample project PLC and HMI programming using Studio 5000
  • Configure Analog Input Devices in Studio 5000
  • Create Templates in FactoryTalk View Studio
  • PlantPAx Add-On Instructions in Studio 5000
  • Create Faceplate in FactoryTalk View Studio
  • Configuration of Control Valve in Studio 5000
Parallel Tanks Level Control using PLC Ladder Diagram Tutorial
Free Mitsubishi PLC Online Training Course and Tutorials
PLC Counter Instructions
Conveyor Speed Logic using Structured Text in PLC
Controlling of Tank Level Using Proportional Controller in PLC
PLC Motor Logic with START, STOP, TEST Push buttons
How to Troubleshoot a PLC System?
PLC Program for Temperature Control using Thermostat
Flexible Input Output Modules
Sorting & Distribution Line PLC Programming – Advanced Logic
Difference Between CompactLogix and ControlLogix
What is Loop Checking
What is Loop Checking?
Pause the Timer PLC Ladder Logic
Database for each safety module
Global Acknowledgment Instruction in Safety PLC
Micro 870 Rockwell PLC
Rockwell Automation Allen Bradley PLC for Smaller and Medium Projects
Reset Logic for pump Run Hours
PLC Program to Count Running Hours of any Equipment
Programmable Logic Controller Practice Tests
PLC automation timers and counters
Top 100 PLC Projects List
Three Wire RTD Temperature Compensation
Ambient Temperature Effects on RTD
PLC Program for Conveyor Motor
PLC Conveyor Motor Ladder Logic
Electrical & Electronics Measurements Objective Questions – Set 6
SCR Full Bridge Converter
Power Electronics – Full-wave Rectifier With R and RL Load
PLC Totalizer
PLC Program for Flow Totalizer
control-engineering-book
Control Engineering Book for beginners
Frequency Response MCQ
Polar Plots MCQ
Pneumatic Actuators
Self-Actuated Valves, Pneumatic & Hydraulic Actuators
