Reading: How to Create a Project in LabVIEW?
Inst Tools > Blog > Control Systems > How to Create a Project in LabVIEW?
LabVIEW software is commonly used for data acquisition, instrument control, and industrial automation. Learn how to create a new project.
Last updated: August 3, 2020 12:56 am
Control Systems
2 Min Read
In certain applications, it is even used for testing purposes because of its accuracy during the simulation. LabVIEW is so Versatile and powerful It is even used in Data Science Domain.
Creating our first project,
Click on the LabVIEW software.
LabVIEW software
Click on the Create project button. The project dialog box appears(Fig 2).
You can see from the above image that there are many predefined templates available, you can use those templates based on the application you are going to create. For now, click on the blank project and click Finish.
The new project will be created.
Labview Project
You can save the project from the appeared window by clicking on File – Save.
Now the project will be saved, To create a Virtual instrument Right-click My computer and got to New, you can see an Option called VI which stands for Virtual Instruments. Click on that to create a Virtual instrument for your application.
Labview Virtual Instrumentation
After Clicking on VI the Front Panel and the block diagram will appear.
Front Panel is like a Process Visualisation of the application you built, Where you can add Graphs, Waveforms, Displays, and buttons to control.
Block diagram is the Code you develop for the application you build. The programming language of the LabVIEW is called G Code or Graphical code.
Labview Front Panel
Labview Project Block Diagram
Author: Abishek D
  • Delta PLC Simulator
  • OPC in Old PLC Systems
  • What is DDE Protocol?
  • PLC Statement List
  • Project Planning PLC
Background of Modbus – ASCII and RTU Data Frames
Relation Control System
Voice Activated Industrial Automation Systems
Compressor Emergency Shutdown Root Cause Analysis
Using of MCT instead of Cable Glands on the Cabinets
100+ Questions and Answers on Industrial Automation and Control
DeltaV System Configuration Changes and Download
PID Controller Tunning Parameters Simulator
Difference between Feedback, Feedforward, and Cascade Control?
Alarm Management System
What is Alarm Management System ?
Certified Control Systems Technician (CCST) Sample Questions
Opposite Acting Valves
What is Split Range Control Loop ?
Troubleshooting PLC Current Loops
Troubleshooting Current Loops with Voltage Measurement
ON OFF Control Principle
On/off Control Theory
Typical process control loop
How Process Control Loop Works
Explain how this is an example of Ratio Control?
Questions on Ratio Control System
PID Tuner
Free PID Controller Gains Tuning Tool
DeltaV System Configuration Change and Download - 3
Communication between Factory IO and Siemens Tia Portal
Instrumentation Design Details
Accuracy of a Manometer
What Affect the Pressure Measurement Accuracy of a Manometer?
Benefits of SIMOCODE over Intelligent MCC
Fire Alarm System Questions
Interview Questions on Fire Alarm System
To check the characteristic of vibration probe
traffic light plc program
