Reading: Control Valves Leak Tightness Restoration Pose Difficulties
Inst Tools > Blog > Root Cause Analysis (RCA) > Control Valves Leak Tightness Restoration Pose Difficulties
Instrumentation engineering root cause analysis (RCA) of control valves leak tightness restoration pose difficulties in the plant.
Last updated: September 28, 2022 3:02 pm
S Raghava Chari
2 Min Read
Control Valves Leak Tightness ProblemAuthor solutionBenefits of this solution
Article Type:Root Cause Analysis (RCA)
Category:Instrumentation
Equipment Type:Control Valves
Author:S. Raghava Chari
Restoring many control valves leak tightness was a lengthy and efforts intensive lapping task, yet results were not reliable.
Author solution
Extending the lens ring gasket’s line contact idea the author got the plugs’ seating areas machined to 100o and seats’ to 90o and advised the crew to set control valves (CVs’) actuators exert 0.9 Kg thrust / mm seat dia.
The valves were leak-tight and they remained leak-tight a lot longer than lapped valves.
Few minutes of machining achieve leak tightness and it stays leak-tight for years.
Author: S. Raghava Chari
  • Passing Control Valves
  • Errors and Faults in Siemens PLC
  • Repeat Failures of Letdown Valves
  • Pressure Taps Block Valves Leaks
  • Drifting Values of Transmitter
Critical High KiloWatt Motor Winding Burnout Threats
NH3 Plant Turbo-compressor Sudden Rise in Temperature
CO2 Stripper Collapsed Internals Revamp
Antifriction bearings (AFB) Problems and Delays Plant Restarts
Failed Letdown Valve Shuts down a Urea Plant Several Hours
Frequent Feeder-A Lightning Arrester (LA) Bursts – Root Cause Analysis
Amine Pump Trip – Root Cause Analysis
11 kV, 3.3 kV, and 400 V systems insulation resistance (IR) Problems
Compressor Anti-Surge Control near-miss incident
RCA Related to Trip Throttle Valve (TTV)
CO2 Stripper Old Differential Pressure Transmitter Stopped Working
Leaky Boiler Drum Level Switch Stops NH3 Plant Commissioning
Control Valve Plug Stem and Gland Leaks
Repeat Control Valve Plug Stem and Gland Leaks
Innovative Segment Orifice
Stuck Segment Orifice Dimensions Calculations
Ball Valve root cause
Ammonia Feed Ball Valve to Ship Tank Closed
Demister Pads Problem
Problems with Demister Pads – Root Cause Analysis (RCA)
Packing Compressing Die Set
Carbamate Plunger Pump Packing Problems Eliminated
Questions and Answers on Motors and Generators
HT Motor Problem appears after Disassembly and Reassembly
Erratic H2 Flow Rotameter
Pipe Elbow Sudden Burst
A Pipe Elbow Sudden Burst Fatalities and Wrecked Panel Instrumentation
Types of Allen Bradley PLC
Data Types in PLC
Data Types in PLC – Bit, Byte, Integer, Real, String
Installation of a Control Valve
How to Install a Control Valve?
What is Motor Jogging ?
Transistor Stabilisation
Main Functions of a Multimeter
Interesting Multimeter Functions (And What They Really Do)
Circuit Control Devices Multiple Choice Questions
Circuit Control Devices Multiple Choice Questions & Answers
Cybersecurity in PLC
