Reading: Conductivity Analyzer Common Problems and Troubleshooting Tips
Inst Tools > Blog > Analyzers > Conductivity Analyzer Common Problems and Troubleshooting Tips
Many times conductivity analyzer malfunctions and learn troubleshooting tips to solve the common problems with solutions.
Last updated: August 1, 2022 8:52 am
Analyzers
Conductivity measurement is used in various plants for measuring the conductivity of various fluids.
Many times Conductivity analyzer malfunctions and troubleshooting the issue becomes necessary. Let us learn the troubleshooting guidelines for the Conductivity analyzer to solve the common problems.
toroidal conductivity probe principle
Follow the below-mentioned steps for troubleshooting the Conductivity analyzer.
  1. The first step is to check whether the Conductivity analyzer is in power ON condition or not. If the display is found in off condition, then check the voltage supply to the conductivity transmitter. If voltage is not present, then check the fuse/barrier in marshalling cabinet. If the fuse is blown, then replace the blown fuse with a fuse of the same rating. If the fuse is ok, then check all the intermediate cable connection tightness. If found ok, then check the cable healthiness. Replace the cable pair if the cable is not ok.
  2. If the voltage is ok, then the power card might be having the issue. Replace the power card with the same type of power card if the power card is removable. If the power card is not replaceable, then replace the conductivity transmitter.
  3. Now check the process sample coming to the conductivity analyzer. Verify the drain tube. A steady and bubble-free sample should be coming out of the sample tube. If no sample is coming, then check the isolation valve. The isolation valve might be in close condition. Open the isolation valve after verifying the tubing condition.
  4. Check the sample flow coming out through the drain line. The sample flow should be laminar. There should be no bubbles coming out with the sample fluid. Adjust the flow as per the requirement of the conductivity sensor. Sample flow can be confirmed from the vendor manual of the conductivity sensor.
  5. Remove the conductivity sensor and check the physical condition of the conductivity sensor. There should be no deposition on the conductivity sensor. If any foreign deposition is found, then clean the conductivity sensor. Use lint-free paper or smooth cloth so the sensor does not get damaged.
  6. Check the condition of the flow cell also in which the conductivity analyzer is installed. If found any issue like blockage of external material deposition, then attend to the issue.
  7. If still reading is not satisfactory, then check the conductivity analyzer’s value in the atmosphere. The value should be zero and stable. If the value is not zero then clean the conductivity sensor again. If the conductivity value is not coming to zero, then do zero calibration.
  8. Now check the value of the conductivity analyzer in some standard solution. If the conductivity analyzer is not showing proper value then do span calibration.
  9. If the Conductivity analyzer is not showing proper value, then check the inbuilt RTD’s healthiness. Wiring details are to be confirmed as per the vendor manual. If RTD is not responding properly, then put the temperature in manual mode and set the process fluid’s temperature. You can expect some error in measurement with manual mode. If the process temperature is quickly changing, then do not put the temperature in manual mode. Replace the conductivity sensor.
  10. Check the value of the cell constant of the conductivity sensor. The incorrect cell constant can also give incorrect readings.
  11. If the value in the field display and the control system do not match, then check both configured ranges. Ranges should be as per the datasheet or any other approved document and must be the same.
  12. If output values are different than the display values in the field, then replace the communication card, if replaceable. If the communication card is not replaceable, then replace the conductivity transmitter. Communication card failure is also possible and in many cases, this is the reason for the mismatch between the field and system values.
  13. If the reading is fluctuating more, then increase the time constant by a few seconds.
Dispersive Spectroscopy
Turbidity Sensor Calibration Procedure
H2S Measurement Using Lead Acetate Principle
Two Electrode Conductivity Probes Principle
Mass Spectrometer Working Principle
pH Monitoring System Triggers an Alarm
Basics of Suspended Particulate Matter (SPM) Analyzers
TOC Analyzer Working Principle
Questions and Answers on Gas
Flame Ionization Detector (FID) Principle
Electrodeless Conductivity Probes Principle
Total Organic Carbon Analyzers Questions and Answers
Conductivity Transmitter Calibration Procedure
Humidity calculator
Thermal Conductivity Detector (TCD)
Thermal Conductivity Detector (TCD) Principle
what-is-gas-metering-system
What is Gas Metering System?
Sling Psychrometer Principle
Oxygen Analyzer Principle
Oxygen Analyzer Working Principle
NDIR GAS ANALYSER WORKING PRINCIPLE ANIMATION
NDIR Gas Analyser Working Principle
online silica analyzer
Silica Analyzer Problems and Troubleshooting Tips
Gas Analyzers Interview Questions
Gas Analyzers Interview Questions and Answers
Chlorine dioxide measurement principle
Chlorine dioxide Analyzer Principle
valve plug and seat damage
Control Valve Erosion Problems
Square root extractor Parts
What is a Square Root Extractor? – DP Flow Measurement
pressure switch control two lamps wiring
Draw Wiring of a Pressure Switch to control two lamps
3-port-2-position-direct-acting-solenoid-valve
3 Port 2 Position Direct Acting Solenoid Valve Working Principle
Control Valve Packing
MCCB (Molded Case Circuit Breaker)
Industrial Circuit Breakers – Most Common Types – Principle
Furnace Draft Control System
Ladder Diagram circuit
PLC Practice Questions
