Reading: Centrifugal Compressor Outage Reduced – Root Cause Analysis
Inst Tools > Blog > Root Cause Analysis (RCA) > Centrifugal Compressor Outage Reduced – Root Cause Analysis
In this article, the author discussed the problem with the centrifugal compressor and how he reduced the outage time.
Last updated: September 28, 2022 2:51 pm
S Raghava Chari
8 Min Read
15 MW Centrifugal Compressor 3-monthly 10-days outage reduced to 1½ days
Centrifugal Compressor Outage ReducedWhy the ORBRS Change Takes 10 days?The Author’s 1½ – Shutdown MethodJob done in < 36 hoursThe New Method’s BenefitsThis Case Study Take outs
Synthesis Gas (75% H2 + 25% N2 gas mix) spill from a broken instrument process lead ignited into a huge fireball near the Synthesis Gas Compressor (K-601) third or High Pressure barrel (HPB).
The plant’s 2 professional fire fighters and volunteer trained fire fighters heroically fought and put out the fire. The HP barrel (HPB) discharge head (DH) leaked two months after plant restart and increased progressively.
Centrifugal Compressor outage reduced
The crew installed steam ring diluted the synthesis gas (75% H2, 25% N2) leaks to prevent fire repeat; on the environs combustibles content reaching 90% of limit, the lab crew monitored the combustibles content 2-hourly instead of 8‑hrly.
The operation engineer started the SD preparations and the rotating machine crew changed the HPB DH O‑ring backup ring set (ORBRS).
Thus, the HPB DH ORBRS set changed, a ten days SD task repeated at 3-monthly intervals. Besides, huge maintenance efforts, costs, the 40*650 = 26000 Tons yearly ammonia production loss, and the front end 40 days, 30% load operation and venting the produced Reformed Gas wastefully crippled the company financially.
Front end SDs and restarts stress the equipment thermally and reduce their lives by years. Hence, plants continue operating the front end at as low load as practical – 30% in this plant’s case – during ammonia plant SDs.
The Rotating Machine Crew’s (RMC) below given ORBRS procedure is the reason for 10-days SD:
  1. The RMC somehow wrongly believed no room to shift the DH towards the IP barrel; hence, they chose to position the IP barrel ½ meter away from the 30 T weight 3rd barrel, as the only rentable very old and crane stretching to its limit could just lift the 20 T weight IP barrel (IPB).
  2. IPB shifting involves:
  3. Unbolt the IPB foundation bolts
  4. Dissemble 10” suction and discharge 1500 # RTJ flanges – a heavy task
  5. Cut few ¾” and 1” gas and oil lines to move the IPB
  6. Uncouple IPB from left LPB and right HPB i.e., two couplings dissemble and to heavy machines alignments to the IPB
  7. Lift and position the IPB ½ m away using the crane
  8. Unlock HPB split rings, and pull the DH using the chain pulley block arranged before the SD
  9. Change the Discharge Head ORBRS
  10. Assemble back the DH
  11. Position the IPB using the crane
  12. Align IPB to HPB and LPB
These numerous heavy jobs led to them each time 10-days SD.
The author then the instrument engineer felt uneasy of an instrument lead starting these high-cost tasks and 40-days yearly on-stream days loss.
Hence, he wanted to help reduce the shutdown (SD) days; by eye judgment, he was certain that the 600 mm long spacer couplings between machines provide enough room to move the DH towards the IPB left in position.
Hence, he took few measurements during the RMCs tea breaks to avoid the feeling of interfering in others’ work. It convinced him that ORBRS change with IPB in-situ in 1½-2 days SD was possible, without hiring the heavy crane.
He talked to the RMC leader about this and offered to work with him during the next ORBRS change. The unbelievable 8½ days of time-saving each time and so many other benefits seemed too good to be true to the mindset RMC.
They ridiculed the author; and influenced the electrical graduate maintenance manager not to approve trying the new method. Hence, the 10‑days routine continued for 3 more years!
The author became Maintenance Manager three years later. The rotating machine crew under his guidance and using the author’s procedure changed the ORBRS in < 36 hours, as under.
The author accepted the RMC leader request to position the crane as insurance, in case reverting to the old method was necessary to respect their views and to gain their whole hearted cooperation while doing the job by his method.
  1. The RMC dissembled the IPB to HPB 600 mm long spacer coupling
  2. As usual they  removed the DH securing split rings
  3. They pulled the DH towards the IPB using the before SD arranged chain pulley block; the DH came clear out of the HPB
  4. The crew replaced the ORBRS and boxed the HPB
  5. They did the task in 1½ days
The new procedure benefits are:
No IPB shift and hence,
  • No poor condition crane positioning in the pipe rack obstructing difficult to maneuver area
  • The absence of managers’ and crews’ extreme stress from the IPB lift start to its placing back in position, because of the crane’s very old condition and the crane driver and owner confidence lack
  • No high pressure large sized suction and discharge flanges breaking, making and new gaskets use
  • No anxieties of likely flange leaks, likely fires and making joints again and new gaskets use costs
  • No difficult complex and time taking IPB to HPB and IPB to LPB thermal growth compensating alignment
  • No 10-days wasteful and exorbitant crane rent payment for just few hours use
  • No living with the hazardous leaks until the crane availability
  • Most important: 4*8½=34 days less plant outage yearly, 85% less wasteful RFG venting during the SD and its enormous financial savings
  • Last but not the least 17% yearly higher ammonia, urea and NPK fertilizers production year after year
  • No wasteful RFG wasteful venting during the 40-days ammonia plant SDs
  • The money value of all these would be close to ¼ to 3/8 billion rupees annually.
Below are these Case Study Take outs:
  1. Consider alternative methods when the developed procedure involves expensive resources use and very high total plant downtimes
  2. Don’t reject other disciplines persons suggestions; for that matter from anybody right away; consider these showing genuine interest, mindset and prejudice free and encourage them; in case their suggestions posed few practical difficulties discuss and iron out; even mock trials are worthwhile
Author: S. Raghava Chari
  • CO2 Stripper Collapsed Internals
  • Roof Hot Spots eliminated forever
  • Absorber Corroded Wall Thickness
  • Rotary Drier Shell to Split Gear drive
  • RFG main Hot Spots threaten Outage
Control Panel Instruments Problem Threatened Plant Shutdown
CO2 Stripper Collapsed Internals Revamp
Industrial Light Fittings and Street Light Poles Corrosion Problems
Recurring Short Circuit Flash Overs Safety Hazards & Damages
Thermowell Shank to Flange Repeat Weld Leaks
Amine Pump Trip – Root Cause Analysis
Phosphate Dozing System Problems
Poorly Engineered, built & often Failing Plant Air Compressor Drives
How Kalrez O-rings Seal So effectively So Long?
Target Flow Transmitters Failed the Very Midnight
Flange Joint Errors shutdowns root cause analyzed and eliminated
Rotary Drier Shell to Split Gear drive eliminates too frequent drive failures
Many Bucket Elevator Wrecks rob crew morale
Finned Heater Leaks Sealed
Finned Tube Steam Leaks – Root Cause Analysis
Welding Machine Fail in Dusty and Corrosive Areas
Ball Valve root cause
Ammonia Feed Ball Valve to Ship Tank Closed
Control Valves Leak Tightness
Control Valves Leak Tightness Restoration Pose Difficulties
Root Cause Analysis on Hunting of Control Valves
11 kV, 3.3 kV, and 400 V systems insulation resistance (IR) Problems
CO2 Stripper Old Differential Pressure Transmitter Stopped Working
Demister Pads Problem
Problems with Demister Pads – Root Cause Analysis (RCA)
Thermocouples Calibration Errors
Thermocouples Sources of Error
Factors for Setting Alarm Levels on Toxic Gas Detectors
The Control Valve Stroke Test Procedure
Current and Voltage analogy
Current and Voltage Principle Animation
What is a Non-Linear Device
What is a Non-Linear Device? Example – Advantages
Step-by-step import export in FactoryTalk View
FactoryTalk View Studio – Import and Export Tutorial
SIS Bypass and Impairment - Safety Instrumented System
SIS Bypass and Impairment – Safety Instrumented System
Zero Suppression in level Measurement
Zero Suppression and Zero Elevation Calculations
