Electrical engineering root cause analysis (RCA) related to Alternate 110 KV connection to Feeder A.
| Category: | Electrical |
| Equipment Type: | Bus ducts, Switchgear, Transformers, |
Alternate 110 KV Connection Problem
The State Electricity Board (SEB) had tapped both Feeder-A and Feeder-B from a certain thermal station bus (TSB). This resulted in no power supply to the plant during TSB Maintenance Shutdowns.
The plant had paid a huge sum to provide an alternate connection to Feeder‑A to avoid total electrical outage to the plant. Years rolled on. However, the project remained in the paper only!
The job done finally
During the national internal emergency, the author agreed to loan materials to the board for their rush work, only after completing the plant’s above long overdue project. They did the job this time!
Alternative 110 KV Supply Benefits
Thanks to this, plant gets uninterrupted power even during the TSB maintenance.
Author: S. Raghava Chari
- Insulation Resistance (IR) Problems
- Failing Weigh Feeders and Drives
- Transformers Coolers Problems
- Motor Rampant Winding Burnout
- Frequent Lightning Arrester Bursts
