Reading: How to Check Address Overlapping in Tia Portal?
Inst Tools > Blog > PLC Tutorials > How to Check Address Overlapping in Tia Portal?
While adding a new I/Os and during rewiring a tag we require to check our address using the overlapping tool in Siemens Tia Portal.
Last updated: March 4, 2021 11:05 am
In this article, we will learn about checking address overlapping using Siemens TIA PORTAL.
Siemens provides many handy tools to overcome problems during the programming phase.
During start-up, while adding a new I/Os and during rewiring a tag we require to check our addresses which we have used. If we re-used an address which already in use then you can check the address overlapping within the software.
Let’s take a small example to learn more about the address overlapping.
Open TIA PORTAL. Enter in the programming environment.
I have added a simple instruction to show you an overlapping of the addresses.
In the below window you can see that in the 1st network I have used I0.0 and in the second network I have used IW0 in the MOVE instruction.
So, IW0 (16-bit) also contains the I0.0. Here, we have an address overlapping. But as you can see in the programming everything seems fine and there is no error at all.
Now, think that we are working on the big project and we commit the same mistake, but after writing bunch of the programming and due to in the programming environment it won’t show us that error, how can you find out that every address you have used is unique and not used again in the program?
To save tons of the time and to find out address overlapping we have a tool named assignment list.
From the assignment list, you can see all the addresses which we have used in the programming.
Now, you find out where the tool is.
You can find the tool by doing a right-click on the programming block where you can see the tool assignment list.
Assignment List Siemens
The following window will open up.
Assignment List of PLC
You can see that I have used address from the byte 0 (I0.0 and I0.1) and in the same line, you can find the word address too. which I have used in MOVE instruction.
The same way you can see on the right-hand side window, which contains the address of the memory bit. You can see that that address also overlapped.
This is how you can check the address overlapping using an assignment list tool.
TIA showing word and bit overlapping
You can also filter the item you want to see in the current window.
Do click on the yellow icon as shown in the below window. Pop-up will open up.
Here, you can check and uncheck the addresses that you want to see.
Overlapping memory areas in TIA
Author: Suhel Patel
  • Check Block Consistency Tools
  • PLC Program using Pushbutton
  • Rewire Tool in Simatic Manager
  • Troubleshoot Siemens PLC
  • Forcing and Modifying PLC
InTouch SCADA Login Password Security
Delta PLC Counter with Comparison
DC Injection Braking in VFD
System Cabinet Health Checks – PLC and DCS Industrial Automation
Oil and Water Separation Process using PLC Programming
Sheets, Tags, Elements in Functional Block Diagram of Studio 5000
Yokogawa DCS Tutorials – Configuration of Analog Input (Transmitter)
Advanced Skills Required for a PLC Programmer to Get a Job
Allen Bradley PLC ControlLogix Hardware
Tutorial: Siemens Communication between PLCs using I-Device
PID Simulator Download
PLC Program to Heat and Bend Glass Tubes
Example of Controlling the PLC Output using Push Buttons
LES and GRT Blocks in PLC Programming
Allen Bradley Math Functions
PLC Program for Conveyor System
PLC Conveyor Ladder Logic Program
Sharing data between two PLC systems
Distributed IO Sharing Between PLC Systems – Technical Insights
Tanks Draining Control in PLC using Functional Block Diagram
Thin Client in SCADA
What is Thin Client in SCADA? – Purpose, Advantages
What is Loop Checking
What is Loop Checking?
One-Shot Rising and Falling Edge Instructions in Rockwell PLC
Tagging Philosophy for Junction Box
Tagging Philosophy for Junction Box, Cable, and Cable Drum
Strip-Chart-Recorder-Working-Principle
Strip Chart Recorder Working Principle
quantum computer
Vacuum Technology is Enabling New Era of Ultra-Powerful Computers: Quantum Computing
Arc Fault Breaker (AFB) Electrical Problem Solved
HVAC System
What is HVAC System?
Simple RC Circuit
Impedance in RC Circuits
Dry Leg
Calculate 0%, 50%, and 100% Calibration Points for ΔP transmitter
Pressure Gauge Datasheet Preparation
How to Prepare Pressure Gauge Datasheet ?
