Reading: What is a 4-way Solenoid Valve?
Inst Tools > Blog > Control Valves > What is a 4-way Solenoid Valve?
Last updated: May 23, 2020 5:01 pm
Control Valves Solenoid Valve
When a pneumatic actuator requires air pressure applied to two different ports in order to move two different directions (such as the case for cylinders lacking a return spring), the solenoid valve supplying air to that actuator must have four ports: one for air supply (P), one for exhaust (E), and two for the cylinder ports (typically labeled A and B).
The following diagram shows a 4-way solenoid valve connected to the piston actuator of a larger (process) ball valve:
4 way Solenoid Valve Principle
The same diagram could be drawn using the “triangle” solenoid valve symbols rather than the “block” symbols more common to fluid power diagrams:
4 way Solenoid Valve Operation
Here, the letters “D” and “E” specify which directions air is allowed to flow when the solenoid is de-energized and energized, respectively.
In both of the examples shown above, the solenoid valve forces the piston-actuated valve stem to move down (shut off) when the solenoid is de-energized.
When the solenoid is energized, air is directed to the bottom of the piston (with the top of the piston becoming vented to atmosphere), causing the piston-actuated valve stem to move up (open wide).
An interior view of a standard spool-type 4-way valve of the kind commonly used for directional hydraulic controls is shown here, along with its accompanying schematic symbol:
4 way solenoid valve working principle
Note that the actuator (e.g. hand lever, solenoid armature, etc.) has been omitted from this illustration for simplicity. Only the spool and valve body are shown.
In hydraulics, it is common to use the letter “T” to represent the tank or reservoir return connection rather than the letter “E” for exhaust, which is why the supply and vent lines on this valve are labeled “P” and “T”, respectively.
A variation on this theme uses a shorter spool allowing the two control ports to freely pass fluid in the “normal” position:
4 way solenoid valve cut-away illustration
Such a 4-way valve is useful for applications where the final control element (motor, cylinder) must be free to move rather than be locked in place with the valve in the middle position.
If no center “off” position is needed, the lands may be shortened in such a way that they cannot fully cover the “P,” “1,” and “2” ports simultaneously, making the valve useful only in its two extreme positions:
4 way solenoid valve schematic
Not all 4-way valves use the spool-type design. However, the spool valve enjoys the advantage of having pressure balance on its one moving part.
If you examine these cut-away illustrations closely, you will see that the two lands present equal surface areas to the two pressures (pump and tank, “P” and “T”) in perfect vertical symmetry, such that any forces acting on the two lands from fluid pressure do so in opposite directions.
This means there will be no net hydraulic force acting on the spool to interfere with its positioning, thus making it very easy to position by hand lever, solenoid, piston, etc.
A photograph of a Parker brand 4-way pneumatic solenoid valve appears here:
Four Way Solenoid Valve Images
This particular solenoid valve is spring-centered, with one solenoid coil at each end to provide actuation in two different directions. The middle position is one where all ports are blocked, providing a “locked” control position for the pneumatic actuating element fed air by this solenoid valve.
Credits : by Tony R. Kuphaldt – under the terms and conditions of the Creative Commons Attribution 4.0 License
Pressure Relief Valve Principle
Reversing Control Valve Actuator Fail Safe Mode
What is Travel Stop in Control Valve?
How to Troubleshoot Control Valve? – Problems and Solutions
SIS Final Control Elements
Complementary Control Valve Sequence
  • Naseer mGulzar says:
    May 11, 2018 at 4:03 pm
    This is very very knowledgeable
    I appreciate writer
    You are able to honour
What is a Pilot Valve? When do we use a Pilot Valve?
Troubleshooting Common Control Valve Problems
How-to do Control Valve Calibration?
What is a Boiler Pressure Relief Valve?
Incident Investigation: Motor Operated Valve Lesson
Free Control Valves Course
What is a Pneumatic Actuator ?
Difference between Quick Opening, Linear & Equal Percentage Control Valve characteristics
Control Valve Cv Formula
Control Valve Cv calculation
cavitation-control valve trim
What is Control Valve Cavitation ?
Control Valve Selection Guide
Control Valve Positioner Working Principle
Objective Questions on Valves
Hydraulic Actuators
Working Principle of Hydraulic Actuators
Solenoid-Valve-Manual-Reset-function
Solenoid Valve with Manual Reset Working Principle
Ball Valve Pictures
How Ball Valves Work ?
Measurement Unit Conversions
Closed-tank-DP-Level-Transmitter-with-wet-leg-Zero-elevation-Calibration
Closed tank DP Level Transmitter with wet leg Zero elevation Calibration
Installation of Proximitor
Determine Lifting of Shaft using Proximity Sensor
Problem with Pirani Gauge
Convert-Linear-%-to-Square-root-%
Formula for Linear % to Square root % conversion
Percentage-to-Current-Conversion
Formula to Calculate 4-20ma from Percentage
WHILE DO Statement in SCL Language
PLC Program Example on Multiple LEDs using Set Coil
