Reading: Working Principle of Flow Switch with Animation
Inst Tools > Blog > Animation > Working Principle of Flow Switch with Animation
Flow Switch operating principle is based on a free-floating magnetic piston that responds only to the motion of fluids within the pipeline.
Last updated: October 31, 2023 12:28 pm
Animation Flow Measurement How It Works Switches
7 Comments
2 Min Read
The Flow Switch operating principle is based on a free-floating magnetic piston that responds only to the motion of fluids within the pipeline, not to static or system pressures.
In the presence of fluid flow, controlled movement of the piston actuates an external hermetically sealed reed switch. This switch can be used to actuate audible or visual alarms, as well as relays, or other controls.
The piston’s movement by the fluid flow can be seen in the animation
Flow Switch Animation
Flow Switch Working Principle Animation
flow switches are used to determine if the flow rate is above or below a certain flow rate. This value (the set point) can be fixed or adjustable. When the set point is reached, the response can be the actuation of an electric circuit.
When the flow switch is actuated, it will stay in that condition until the flow rate moves back from the set point by some amount.
  • Animation of Level Switch
  • Piston Type Pressure Gauge
  • How to Select Rotameter?
  • Paddle Wheel Meter Theory
  • What is a Restriction Orifice?
Why Flow is Directly Proportional to the Square Root of DP?
Label the Electrical Circuit Schematic
How does an Orifice Measures Flow?
Dall Tube Flow Meter – Principle, Advantages, Disadvantages
Differential Pressure Switch Working Principle
How to Select a Rotameter? – Parameters and Applications
7 Comments
  • Josh Koikkara says:
    September 24, 2015 at 1:36 pm
    Sir, using flow switch can we measure flow pressure?
    • S Bharadwaj Reddy says:
      September 24, 2015 at 1:51 pm
      Not Possible. Mainly Flow switch used to identify the presence of flow in the pipe.
  • kumar says:
    September 24, 2015 at 11:43 pm
    Thanks for sharing the animations.
  • Ganesh says:
    February 28, 2016 at 5:43 pm
    Thank u …
  • Kamleshwar Rao says:
    March 22, 2016 at 1:24 pm
    How can we use the flow switch mechanism with L&T MU-G10 starter panel to stop the motor on dry run i.e. when there is no flow of water, inorder to stop the motor from dry running.
  • Vignesh says:
    July 23, 2016 at 5:42 am
    Easy to understand with your animation. Keep it up.
  • ajay singh tomar says:
    December 21, 2016 at 12:47 am
    What is the diff b/n rising and falling setpoint.
What is Integral Flow Orifice Assembly?
Pull Cord Switch Working Principle
How Limit Switch Works ?
Overview of Proximity Switches
Displacer Level Switch Working Principle
Rotameter Working Principle and Animation
Resistance Temperature Detectors Working Principle
Pneumatic Actuators Types Animation
Types of Pneumatic Actuators Animation
Variable Area Flow Meters
All About Variable Area Flow Meters
Coriolis Mass Flowmeter Principle
Coriolis Mass Flow Sensor Theory
Hydrostatic Level Measurement
Turbine Flow Meters Working Animation
Turbine Flow Meters Animation
Comparison of Venturi and Orifice flow meterComparison of Venturi and Orifice flow meter
positive displacement flow meter pictures
What is a Positive Displacement Flow Meter?
Impulse line - Purpose & Tapping Point Location
Impulse Line – Purpose & Tapping Point Location
Air Pressure Regulator cut-away diagram
Air Pressure Regulator Questions
Code Simulation of Safety Circuit
Feedback Monitoring in Safety PLC
Siemens PLC Force LED
Forcing and Modifying PLC Logic
FIFO in STL Language in Siemens PLC
How to Code a FIFO Queue in STL Language in Siemens PLC?
pH Analyzer Calibration and Troubleshooting
Cyclic Interrupts TIA Portal
Configuring and Usage of Cyclic Interrupts TIA Portal (OB 30+)
