  • Ask
  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: Within Few Weeks Failing Acid Dozing Pumps
  • PLC Tutorials
  • Control Systems
  • Ask
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > Root Cause Analysis (RCA) > Within Few Weeks Failing Acid Dozing Pumps
A plunger pump dozing sulfuric acid to a urea plant’s water treatment ion-exchange vessel stopped pumping after first week end.
Last updated: September 28, 2022 3:19 pm
S Raghava Chari
3 Min Read
Root Cause Analysis (RCA) related to the newly installed acid dozing pumps in a urea plant.
Acid Dozing PumpsAuthor SolutionProblem Identified and solution foundPump rush restoration Benefits
Article Type:Root Cause Analysis (RCA)
Category:Mechanical
Equipment Type:Miscellaneous Rotating Machine Problems
Author:S. Raghava Chari
Acid Dozing Pumps
A 15 KW plunger pump dozing sulfuric acid to a Saudi Arabian urea plant’s water treatment ion-exchange vessel stopped pumping after first week end.
The exasperated and desperate field crew left with no spare parts sought Author SOS assistance.
Author Solution
The author unfamiliar with the pump studied the instruction manual and sketched shown in below figure to show essentials.
Plunger Pump
The basics are
A motor driving a crank mechanism reciprocates the oil plunger pump (OPP), creates negative oil pressure in the forward stroke, the rubber diaphragm convex left, draw the acid in the pump chamber.
Plunger return stroke pressures the oil and the acid flows to the process opening the discharge valve. The suction valve closes and prevent acid flow back to the storage tank.
brittle, hard, inflexible and cracked diaphragm showed its incompatibility to either sulfuric acid and or oil.
As no spare diaphragm was available, the author got the pump assembled back substituting between two 1.5 mm thick Teflon sheet discs rubber diaphragm cut from 4.5 mm thick conveyor belt – the thinnest available.
Below given are the benefits of the rush innovative pump restoration:
  1. The assembled pump never failed and averted total ammonia and urea plant shut down
  2. On the vendor provided flimsy diaphragm lost a week only
  3. Both side Teflon sheet protected much stronger conveyor belt cut diaphragm is probably the reason
The acid delivery plunger pump became ‘fit & forget’.
Author: S. Raghava Chari
  • Turbo-Compressor Problem
  • Compressor Anti-Surge Control
  • Plant Air Compressors Problems
  • Plant Turbo-compressor Problem
  • Failing Plant Air Compressor Drives
Control Valves Leak Tightness Restoration Pose Difficulties
Condensate Pump Frequent Wrecks Threatens Long Plant Outages
Flange Joint Errors shutdowns root cause analyzed and eliminated
CO2 Stripper Collapsed Internals Revamp
Seal Pressure Instruments Root Cause Analysis
208kSubscribersSubscribe
Recent Comments
Related Articles
4 way solenoid valve root cause
Safety Liquid Ammonia Disconnect threatens NH3 Vapor Spill
Cooling Water Circulating Pump Low throughput
Cooling Water Circulating Pump Low throughput Resolved
Vac Residue Tank Electrical Heating Element
Poor Electrical Heating Element Lives – Problem Solved
Thermocouple Extension Lead Minimizer Circuit
Thermocouple Wires and Extension Lead Issues
Malfunctioning Inlet Check Valves
CO2 Stripper Old Differential Pressure Transmitter Stopped Working
CO2 Absorber Graphics in DCS
CO2 Absorber Corroded Wall Thickness & Weld Building
More Articles
List of Documents Required for Testing and Calibration Laboratory
List of Documents Required for Testing and Calibration Laboratories
Top PLC Manufacturers
PLC Brands Software Information
Two Wire RTD Lead Wire Resistance Error
Temperature Error of 2-Wire, 3-Wire & 4-Wire RTD
Reasons to Calibrate Flowmeters
Reasons to Calibrate Different Types of Flow Meters
Programmable Logic Controller (PLC) Questions and Answers – 7
Vortex Flow GIF
Working Principle of Vortex Flow Meter
Quiz on Electrical Drawings and Symbols
264 Quiz on Electrical Drawings and Symbols
Hydrocarbons Questions & Answers
