Reading: Will PLCs become obsolete?
Inst Tools > Blog > PLC Tutorials > Will PLCs become obsolete?
Last updated: March 4, 2021 12:06 pm
4 Comments
3 Min Read
Will PLCs become obsolete, or phase out few years down the line?
Recently you must be hearing a lot about Industry 4.0. The use of technologies such as Artificial Intelligence, Machine learning, IoT, etc. is massively trending these days.
Some engineers in the Industrial automation field say or predict that the above-mentioned technologies might replace PLCs in the near future. Therefore I want to share my take on this with you folks.
I will explain my opinion with a simple example. Suppose I want to turn on any motor. To make motor ON, I need some physical switch so that I can energize the control coil of contactor which will ultimately make motor ON. And here PLC comes into the picture. It acts as a switch (in simple terms) and passes power to the control coil of contactor whenever we want.
In a broader sense PLC is a collection of multiple switches (memory switches, or physical switches in the form of digital outputs) and it has a number of additional features such as computing, sensing and generating digital and analog signals, etc.
The PLC is also a computer, but it is of a different kind as compared to a normal PC or laptop. The hardware of PLC is designed taking into account the requirements of industrial process control applications.
The AI, ML, and IoT technologies may take care of computation and decision making part of process control. But for actual physical execution, a particular kind of hardware is required. And this special kind of hardware requirement is very well taken care of by PLC like controllers.
Without this very kind of hardware, the execution of process control applications is not possible. AI, ML, and IoT like technologies are just advancing the way things used to work, making them more smart, efficient, reliable, and ultimately easy to use. But they cannot completely replace the old PLC like technologies.
Therefore, in my opinion, PLCs are not going to become obsolete in the future.
Author: Pratap Shinde
Share your thoughts on this topic through the below comments section.
  • PLC Tutorials and Guide
  • Quiz Questions for Instrumentation
  • Tips for Instrument Engineers
  • Open Platform Communication
  • OPC in Old PLC Systems
Drilling Process using PLC Program
How to Use Encode and Decode Instructions in PLC ?
Your First Steps Through STL Language
How to Connect PLC with SCADA System via OPC UA?
Why is RTO used in the Place of TON Timer?
How to Solve Electrical Ground Loop Problems?
4 Comments
  • RR says:
    May 25, 2020 at 12:48 am
    Dear Pratap Shinde
    This is very nice learning your’s brilliant explanation of PLC.
    The Client’s Field process has to be made User Friendly using all the Cascaded Connections & Designs i.e., from Client’s Field to Vendor’s PLC, DCS, RTU to SCADA to HMI,MMI to IoT, Neural Networks etcs.
    So its about making the whole Factory Unit in a Software in Server & Standby
    The technologies will Integrate.
    Regards
  • Sandeep says:
    May 25, 2020 at 8:41 am
    What about softcontroller PLCs…wherein the CPU is our computer cpu which acts as a PLC which will trigger digital outputs from the PC…So, then..PLC have no requirements there.
  • vivian (Vance) Newman says:
    May 26, 2020 at 4:18 am
    You are on the correct track Sandeep. That is the future. Some suppliers are already employing this.
  • Pradeep says:
    May 26, 2020 at 8:20 am
    PLCs will be there until industrial automation exists. Small PLC cost is very low compare to a PC. And also PC can work in s shop floor area as they are rugged. This AI, machine learning, Iot will be integrated as part of PLC but they cant wotk standalone.
How to do Simulation in Schneider PLC?
Basic Concepts of the Safety Relay
Write a PLC Program for Selector Machine using Structured Text
What is 21 CFR in SCADA and HMI Systems?
How to Connect a Solenoid Valve with PLC?
Static and Temp Variables in PLC
PLC Totalizer
PLC Program for Flow Totalizer
User Defined Function Blocks in PLC
What are User Defined Function Blocks in PLC?
PLC Instructions
Program Flow Control Instructions in PLC Programming
Mixing Tank Relay Circuit
PLC Program for Mixing Tank
PLC Ladder Logic Door Open and Closing System
Which Language is Best for PLC Programming?
PLC Multiple Choice Questions
Instrumentation During the Detail Design Phase
PLC Program to control level of parallel tanks
Parallel Tanks Level Control using PLC Ladder Diagram Tutorial
scada hmi
Functions of SCADA
Free Download PLC Simulator using Excel
What is Gas Leak Detection System
What is Gas Leak Detection System ?
level control system
Practical Process Control System Questions & Answers – 11
Choke Valve Hydro Test Setup
Choke Valve Hydro Testing Procedure
Metal Foil Strain Gauge Principle
MOS Digital Integrated Circuits Objective Questions
DP Transmitter Level Measurement for Closed Tank Wet leg Method
DP Transmitter Dry Leg & Wet Leg Calculations
