Reading: Voltage Polarity and Current Direction
Inst Tools > Blog > Electrical Theory > Voltage Polarity and Current Direction
Last updated: July 23, 2018 2:55 pm
Electrical Theory
2 Min Read
Before understanding the laws associated with complex DC circuit analysis, the importance of voltage polarity and current direction must be understood. This article will introduce the polarities and current direction associated with DC circuits.
Conventional and Electron Flow
The direction of electron flow is from a point of negative potential to a point of positive potential. The direction of positive charges, or holes, is in the opposite direction of electron flow. This flow of positive charges is known as conventional flow.
All of the electrical effects of electron flow from negative to positive, or from a high potential to a lower potential, are the same as those that would be created by flow of positive charges in the opposite direction; therefore, it is important to realize that both conventions are in use, and they are essentially equivalent. In this manual, the electron flow convention is used.
Polarities
All voltages and currents have polarity as well as magnitude. In a series circuit, there is only one current, and its polarity is from the negative battery terminal through the rest of the circuit to the positive battery terminal. Voltage drops across loads also have polarities.
The easiest way to find these polarities is to use the direction of the electron current as a basis. Then, where the electron current enters the load, the voltage is negative (Figure 31). This holds true regardless of the number or type of loads in the circuit. The drop across the load is opposite to that of the source. The voltage drops oppose the source voltage and reduce it for the other loads. This is because each load uses energy, leaving less energy for other loads.
Voltage Polarities
Figure 31 Voltage Polarities
Transformer Current Ratio
DC Machines Terminology
Series-Wound DC Generators
Block Diagram
Resistivity
AC Induction Motor Slip
  • m.seibel says:
    May 6, 2021 at 1:19 am
    This would be more to the point in answering a simple query.
    ‘The direction of electron flow is from negative potential to positive potential.
    The direction of conventional flow is positive potential to negative potential’.
    Conventional and Electron Flow (present post)
What is Synchroscope ?
AC Generation
DC Motor Torque
Applying Kirchhoff’s Voltage Law
Ampere Hour Meter
Synchronous Motors
Parallel Circuit Current Calculations
Voltage and Current Phase Relationships in an Inductive Circuit
Types of Fuses
Electrical System Components and Protection Devices
Shorted Parallel Circuit
Parallel Short Circuit Faults
Inductor Principle
Inductor
Electric Short Circuit
Series Short Circuit Faults
Types of Batteries
Types of Batteries
Inductors in parallel
Series and Parallel Inductors
Shunt-Wound DC Motor
Shunt-Wound Motor Operation
Potential Difference Across a Conductor Causes a Current to Flow
Conductor, Insulator, Resistor and Current Flow
Basics of Actuators
Basics of Actuators
Automatic Motor Forward and Reverse Control using Timer
11 kV, 3.3 kV, and 400 V systems insulation resistance (IR) Problems
Why Are Neutral and Earth Separated
Why Are Neutral and Earth Separated?
Distribution transformer
Different Types of Transformers
Control Valve Testing for Noise Measurement
Proof Testing of Safety Instrumented Systems
Motor Stop Interlock for Changing the Direction PLC Program
