Instrumentation engineering root cause analysis of turbine flow meter (TFM) field calibration in a urea plant.
| Category: | Instrumentation |
| Equipment Type: | Sensors |
Turbine Flow Meter (TFM) Problem
The US Process Licensor (UPL) insisted to calibrate the liquid NH3 flow through the turbine flow meter (TFM) before the urea plant guarantee test.
He turned a deaf ear to the author’s explanation that field calibration is rare and impractical; users trust the manufacturer calibration, which is stable over long periods.
Also Read: Turbine Flow Meter Calibration Procedure
Author solution
He connected a fire hydrant with a fire hose to the turbine flow meter (TFM) inlet, collected the TFM exiting the water in a chassis-mounted tanker that haul 25000 kg Phosphoric acid from the port to the plant (below figure), and weighed the empty and water-filled tanker.
The instrument crew set the TFM read-out counter’s scalar switches each count for 50 Kg Water flows the least the readout permits to maximize reading accuracy.
The TFM integrator read flow quantities at 33%, 66%, and 100% of max TFM flow rates differed from weighed quantities by 0.1% only against the
The turbine flow meters (TFM’s) guaranteed 0.25% uncertainties. The instrument crew calibrated and found the road weigh scale that weighed the tanker was 0.02% accurate against the guaranteed 0.046% i.e. around 6 times more accurate than the TM guaranteed accuracies.
Benefits Realized
Realized benefits are:
- The satisfied process licensor completed the guarantee test,
- The guarantee test identified 5% higher than guaranteed specific ammonia consumption per ton of urea.
- The licensor root cause analyzed and corrected the deficiencies
- The repeat guarantee test shown ammonia specific consumption was acceptable
- The vendor got his final payment and left
- The correct ammonia specific consumptions benefit the plant too forever.
Author: S. Raghava Chari
- Level Transmitters Zero Drifts
- Pitot-tube Replaced with Orifice
- Mechanical Temperature Indicator
- Pressure Transmitter Stopped Working
- Seal Pressure Instruments Problems
