  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: Thermal Mass Flow Meter – Principle, Advantages, Applications
  • PLC Tutorials
  • Control Systems
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > Flow Measurement > Thermal Mass Flow Meter – Principle, Advantages, Applications
Thermal mass flow meter principle is rate of heat absorbed by a fluid flowing in a pipe or duct is directly proportional to its mass flow.
Last updated: October 31, 2023 12:40 pm
Flow Measurement How It Works
3 Comments
3 Min Read
Thermal mass flow meters employ the thermal dispersion principle whereby the rate of heat absorbed by a fluid flowing in a pipe or duct is directly proportional to its mass flow.
Thermal Mass Flow MeterAdvantages of Thermal Mass Flow MeterLimitations of Thermal Mass Flow MeterApplications of Thermal Flow Meter
In a typical thermal flow meter gas flowing over a source of heat absorbs the heat and cools the source.
As flow increases, more heat is absorbed by the gas. The amount of heat dissipated from the heat source is proportional to the gas mass flow and its thermal properties.
Therefore, measurement of the heat transfer supplies data from which a mass flow rate may be calculated.
Thermal Flow meter Technology
Thermal mass flow meters are designed to accurately monitor and measure the mass flow (as opposed to measuring volumetric flow) of clean gases, a parameter that is not temperature-dependent.
Therefore, the thermal mass flow meter does not require a correction for changes in gas temperature, pressure, viscosity, and density.
Thermal Mass Flow meter Principle
  • Measure gas mass flow rate directly
  • Suitable for applications where temperature and pressures fluctuate
  • Highly accurate and repeatable measurements with a typical accuracy of ± 1% FS
  • Able to measure accurately low gas flow rates or low gas velocities
  • Excellent turndown ratio, typically 50:1
  • No moving parts
  • Gas mass meter use is limited to clean, non-abrasive fluids
  • The presence of moisture or droplets can lead to measurement inaccuracy
  • Thermal properties must be known: variation from calibrated values can cause inaccuracies
  • Relatively high initial cost
Thermal mass flow meters are suitable for a variety of processes requiring mass flow measurement and are frequently used for the regulation of low gas flows.
Some common gas flow applications for thermal mass flow meters include:
  • Compressed air flow and distribution
  • Natural gas consumption eg for burner and boiler feed control
  • Monitoring and control of stack or flue gas (where composition known)
  • Landfill gas recovery
  • Flare gas measurement
  • Gas flow mixing & blending
  • Gas leak testing and detection
  • Magnetic Meter Operation
  • Ultrasonic Doppler Flow Meter
  • Wedge Flow Meter Theory
  • Mass Flow Meter Animation
  • Flow Meter Verification
Recommended Articles
Dead Weight Tester Working Animation
Linear to Square Root Extraction
Vortex Flow meter Animation
Orifice Plate Turndown ratio
Flow Meter K-factor and Calculations
Ultrasonic Flow Meters Working Principle
3 Comments
  • kingsley says:
    August 12, 2016 at 8:36 am
    Thanks sir,
    you articles are very helpfull,
    please can you send me proper way of calibrating a thermal mass flow meter
    i have fox thermal instrument inc model FT3, PLEASE I NEED TO CALIBRATE THIS
    need your help to guide me thanks.
  • Vinod Pandey says:
    February 20, 2017 at 3:16 pm
    Thankyou sir for knowledge sharing material is very helpful.
  • Reagan Nyero says:
    September 13, 2022 at 11:02 am
    Good knowledge it’s really helpful
208kSubscribersSubscribe
Recent Comments
Related Articles
Variable Area Flow Meters
All About Variable Area Flow Meters
Vortex Flow Meter Animation
Beam-Detectors-Working-Principle-2
Beam Detectors Working Principle Animation
Troubleshooting Ultrasonic Flow Meter Common Problems
What is an Orifice Flange ?
What is an Orifice Flange? – Purpose and Applications
Piston Type Flow Meter Principle
Types of Variable Area Flow Meters
Flow Switch Working
Flow Switch : What is it? – Applications
Orifice Flow Measurement Formula
Basics of Flow Measurement
More Articles
Pole Placement by State Feedback
Difference Between LED and LDR
Allen Bradley SLC 500 PLC Programming
SCADA Graphics
What is SCADA ? How does SCADA Works ?
Control Valve in PlantPAx Project
Configuration of Control Valve in Studio 5000
Transistor Voltage Divider Bias
Single-Phase Full Wave AC-DC Converter Objective Questions
