Reading: Solving Control Valve Hunting: Instrument Troubleshooting
Inst Tools > Blog > Control Valves > Solving Control Valve Hunting: Instrument Troubleshooting
Expert guide on Instrument Troubleshooting and Solving Control Valve Hunting for efficient and reliable plant operations.
Last updated: January 22, 2024 10:58 am
vicky
Control Valves Root Cause Analysis (RCA)
6 Min Read
This article is a unique one that will tell us the importance of small bolts which can have a large effect on the plant operation and sometimes more adverse effects.
Solving Control Valve HuntingWhat is the issue with the Control Valve Positioner?Reason for Moisture inside the Valve PositionerRoot Cause AnalysisHow to avoid these problems?
First, we will know what happened, then why it happened, and then the reason behind it and how this type of issue can be avoided.
Solving Critical Control Valve Hunting
One critical control valve was not operating properly as per the command and had the issue of hunting. Due to this, the operation of the plant was disturbed.
So, the operation department asked the Instrumentation team to check the control valve. The instrumentation team immediately attended to the issue. They replaced the control valve’s positioner. Did auto-calibration and handed over the control valve to the operations department after checking the stroke of the control valve.
To know why it happened, we will see the steps that the Instrumentation team took to identify and resolve the problem.
Below are the steps that were taken by the Instrumentation team:
  1. Checked the instrument air supply pressure. Instrument air supply pressure was found ok as per the tag plate on the control valve.
  2. Checked instrument air leakage in the tube. No leakage in the instrument air tube was found.
  3. Checked for air leakage on the body of the actuator. No leakage was found.
  4. Opened the positioner to check the supply voltage and also the connection. When the cover was opened, moisture was found inside the positioner.
So, this moisture ingress inside the positioner was the reason behind the control valve hunting. This moisture caused damage to the internal components of the positioner.
So, the Instrumentation team replaced the positioner immediately. Then auto calibration of the valve was performed and then this valve was handed to the operations team after stroke checking.
Moisture inside instruments is a rare issue that we encounter in monsoon season or if the instrument is installed in places where water is present continuously (like an instrument installed in a cooling tower area). We should take steps to protect the instrument from moisture.
The steps are:
1) Proper application of aluminum tape
2) Proper application of silastic
3) Using canopies to cover the instrument properly
4) Covering instrument with plastic cover if needed
5) Plugging spare cable entries with blind plugs
Root Cause Analysis
Now, let us see how moisture went inside this control valve positioner.
While opening the positioner’s cover, the Instrumentation team found properly applied silastic on it. But one observation was that while opening the bolts of the positioner’s cover, 1 bolt out of the 4 bolts was missing.
Because of this missing bolt, a minor gap had formed because the other 3 bolts were pulling the cover inside while on 4th side, nothing was pulling it inside. Although proper silastic was present, but this silastic was old and it was applied 3-4 years back. Due to the aging effect, a minor gap might have formed and this gave a path for the moisture to go inside.
You might think the culprit is the bolt itself. But there are many reasons behind this. Now, we will see various points which should be taken care of.
By the below-mentioned points, this kind of issue and many others can be eliminated.
  1. During LLF, round identify missing parts. This includes bolts, silastic, monsoon tape, loose covers, and missing canopies.
  2. During the PM (Preventive Maintenance) Job, the cover of each instrument should be opened. This will let us know the internal condition of the instrument. While refixing the cover, apply some grease on bolts or threads whichever is applicable. This will also help to increase the life span of bolts and threads which reduces due to aging effect. Sometimes the bolts break while opening because they are corroded. So, opening bolts in every PM Job will eliminate this corrosion up to an extent because they will be lubricated every time. Another plus point is that silastic or monsoon tape will be reapplied.
  3. If due to any reason, such type of condition exists like a bolt is not available at the time of installing the instrument, do remember it or write in pending jobs and attend to it as soon as possible.
  • Control Valve Maintenance
  • Controller Bumpless Transfer Issues
  • Motor Operated Valve Problems
  • Junction Box Internal Corrosion
  • Valve Failure in Plant Start-Up
  • BP Refinery Explosion at Texas City
Too Low Efficiency Torque Converter Elimination Attempt
Advantages and Disadvantages of Valve Actuators
Current to Pressure (I/P) Converter Principle
Control Valves Mechanical Friction Problems
Seal Level Differential Pressure Transmitter Problems
Instrumentation Inspection Report
  • smit says:
    January 30, 2024 at 7:39 pm
    very good article. it is according to industrial real life problem.
What is an Altitude Valve?
Root Cause Analysis for Tank Overflow due to Valve Problem
What is an Actuator? – Different Types of Actuators
What is a Hydraulic Valve? and their Types
30 Electrical Engineering Problems – Root Cause Analysis
Types of Valve Leakage Tests
Poor Power Factor Boosted – Industrial Electrical Problems
Rotary Drier Shell to Split Gear drive eliminates too frequent drive failures
Boiler Feed Water Heater Shell Flange Leaks
Malfunctioning Inlet Check Valves
Triple-offset Butterfly Valves
Butterfly Valves – Concentric, Double-offset, and Triple-offset
Procedure for the Repair of Control Valve
Basic Steps and Procedure for the Repair of Control Valve
Innovative Segment Orifice
Stuck Segment Orifice Dimensions Calculations
What is Travel Stop in Control Valve
What is Travel Stop in Control Valve?
Piston No-Diaphragm Seal Instrument
Seal Pressure Instruments Root Cause Analysis
SMART Control Valve Positioner
Electronic Valve positioners
Process Automation
What is Process Automation? – Simple Automation Example
Voltage Divider Rule
PLC program for VFD Drive Multiple Speeds
Drive Multiple Speeds with Different Reference using PLC
Quiz on Alternators, Motors, and Transformers
200+ Quiz on Alternators, Motors, and Transformers
What is an Electromechanical Relay
Difference Between Solid State Relay and Electromechanical Relay
Nuclear Plant Sensors and Detectors Quiz
3-15 psi to 4-20mA Conversion
Example of 3-15 psi to 4-20mA Conversion
Turbine Flowmeter Parts
What is a Turbine Flow Meter?
