Reading: SCADA Communication and Protocols
Inst Tools > Blog > PLC Tutorials > SCADA Communication and Protocols
Last updated: March 4, 2021 3:39 pm
8 Min Read
SCADA software is the most important aspect which runs on the hardware. Earlier SCADA was mostly hardware and less on software. Presently, SCADA is 85% software and 15 % hardware. SCADA software can be divided into two types, proprietary or open.
ISO ModelDNP3 ProtocolImportant Features of DNP3IEC60870 ProtocolHDLCModbus
The important SCADA protocols can be classified into the following
  • DNP3 (Distributed Network Protocol)
  • IEC (International Electro Technical Commission) 60870
ISO Model
The working these protocols are based on the ISO or open systems interconnection model (OSI) are shown below.
SCADA Protocol
The OSI Reference model has seven layers, the details of which are given below. The different layers are categorized based on the functions they perform
OSI Reference model
DNP3 Protocol
DNP3 stands for distributed network protocol and it consist of a set of communication protocols used between components which are used in process automation systems like electric utility, chemical process plants, etc.
The purpose of DNP3 is to accomplish communication between various types of monitoring, data acquisition systems and control equipment. This protocol forms an integral part in SCADA systems while interconnecting the RTUs and IEDs named as the Inter –Control Center Communications (ICCP) protocol. ICCP is a part of IEC 60870 and is widely used in inter- master station communications.
IEC 60870 was primarily design to allow important reliable communication between in electric utility automation systems under situations of information distortion and transmission. Security of these protocols is an important aspect to be considered.
DNP3 protocols were not designed to be secure from hackers and threats. There was a need to introduce security authentication to the DNP3 protocol. Presently it is in complaint with IEC 62315-5 and is regarded as a a set of best practices for implementing SCADA-RTU master station communications.
1. DNP3 protocol is characterised by important features that makes it inter-operable with related protocols like MODBUS, etc. This makes it more efficient and efficient for communicating between components in SCADA systems.
2. DNP3, with reference to the widely used OSI model for communicating networks, corresponds to layer 2, which provides multiplexing of various features like error checking, link control, data fragmentation, etc.
3. DNP3 provides a transport function (layer 4) and Application layer (Layer 7) corresponding to SCADA applications.
4. DNP3 has improved bandwidth efficiency which is accomplished through event oriented data reporting.
5. DNP3 has good ability to handle error detection.
The DNP Protocol performs time synchronization with RTU, where time stamped variants of all data point objects are reconstructed through a sequence of events.
The DNP3 protocol has the added advantage of supporting RTUs of different nature and complexity through four levels of subsets of the protocols for RTU compliance. However this protocol tends to become more complex with increased number of RTUs and interconnection.
IEC60870 Protocol
IEC standard 60870 is widely used for controlling electric power transmission grids and other process plants. This standard can be used for interoperating various equipment from different suppliers through standardized protocols.
IEC standard 60870 has six parts, defining general information related to the standard, operating conditions, electrical interfaces, performance requirements, and data transmission protocols.
IEC 60870 provides a communication profile for tele-control messages between two directly connected systems. This protocols provides tele-control and tele-protection of electric power systems through associated tele-communication.
IEC 60870-5 has five parts:
IEC 60870-5-1: Transmission Frame Formats
IEC 60870-5-2: Data Link Transmission Services
IEC 60870-5-3; General Structure of Application Data
IEC 60870-5-4; Definition and Coding of Information Elements
IEC 60870-5-5; Basic Application Functions
The two widely used protocols for SCADA Applications are
  • HDLC (High Level Data Link Control)
  • MODBUS
HDLC
HDLC (High Level Data Link Control) is a bit oriented code transparent synchronous data link layer protocol developed by ISO. HDLC provides connection – oriented and connection – less service.
Though HDLC can be used for point to point multi point connections, but is preferable to use one to one connections, known as asynchronous balanced mode (ABM). It forms the basis for all modern protocols.
Modbus
MODBUS is a serial communications protocol originally published by MODICON in 1979 for use with its programmable logic controllers. MODBUS protocol is simple and robust which has become a widely used standard communication protocol for connecting industrial electronic devices.
The advantages of MODBUS protocol from an industry point of view are
1. Industry centric.
2. Open Source
3. Easy to use and deploy
4. Vendor independent
MODBUS allows communication between several devices connected to the network through RTUs in SCADA. In this protocol, the master may initiate a MODBUS command to activate the connected element / device.
The command contains the MODBUS address of the device. Only the indented device will act on receiving the command though other devices receive them. The MODBUS command ensures that the command is received unchanged through an inbuilt checking information.
No standard way exists for a node to find the description of a data object, there is no way for a field device to “report by exception” Modbus is restricted to addressing 247 devices on one data link, which limits the number of field devices that may be connected to a master station Modbus transmissions must be contiguous which limits the types of remote communications devices to those that can buffer data to avoid gaps in the transmission. Modbus protocol provides no security against unauthorized commands or interception of data.
Companies develop proprietary software to communicate to their hardware. These systems are sold as ‘turn key’ solutions. The main problem with this system is the overwhelming reliance on the supplier of the system.
Open software systems have gained popularity because of the inter-operability they bring to the system. Interoperability is the ability to mix different manufacturers’ equipment on the same system.
The widely used open software for SCADA systems are Citect and Wonderware.
Key features of SCADA Software are
  • User interfaces
  • Graphics displays
  • Alarms
  • Trends
  • RTU (and PLC) interface
  • Scalability
  • Access to data
  • Database
  • Networking
  • Fault tolerance and redundancy
  • Client/server distributed processing
  • What is IEC 61508?
  • Modbus versus DNP3 Protocols
  • OSI Layers of Communication
  • Networking Interview Questions
  • Basics of SCADA Hardware
PLC Ladder Program for Automatic Car Wash using Siemens TIA Portal
Types of PLC Memory
PLC Project Examples for EcoStruxure Machine Expert
#5 PLC Best Practices – Cryptographic and Checksum Integrity Checks
PLC Ladder Logic for Opposite Acting Control Valves Application
Create User-Defined Data Types and Function Blocks in Studio 5000
PLC Program to Heat and Bend Glass Tubes
Drive Multiple Speeds with Different Reference using PLC
Coil Type Timers in Siemens PLC Programming
Siemens TIA Portal Free Version Download
Two Hand Press Safety Control Circuit
PLC Pump Control: 10 seconds ON & 20 seconds OFF
How to Use Symbol Factory Software for Graphic Design in HMI or SCADA?
Controlling of Tank Level Using Proportional Controller in PLC
PLC Program three-phase electric motor
Identify the Problem in the PLC Program
PLC Handbook
PLC Handbook
Simulation in Machine Expert HVAC
How to do Simulation in Schneider PLC?
Siemens PCS 7
What is PCS 7?
How to Create DFB in Schneider PLC? – Derived Function Block
Sorting and Counting Products on Conveyors by Color
PLC Programming for Multi-Color Sorting Conveyor System
Industrial PLC Communication Network
Basics of Industrial Communication Networks
Circuit Diagram of Displacement Transducer
What is a Displacement Transducer? – Types and Advantages
Thyristors Quiz
Single-Phase Half Wave AC-DC Converter Objective Questions
DC Circuit Node Equations
DC Circuit Analysis Node Equations
Electric Circuits Objective Questions – Set 14
Structured Text Selector Machine Logic
Write a PLC Program for Selector Machine using Structured Text
Top 30 Interview Questions on Pressure Measuring Devices
Basic Transistor Amplifier Circuit Principle
