Reading: What is Resources Tab in the Siemens PLC?
Inst Tools > Blog > PLC Tutorials > What is Resources Tab in the Siemens PLC?
Resources Tab as the name indicate it contains all the information related to the ladder logic program of Siemens PLC
Last updated: March 4, 2021 11:14 am
3 Min Read
In this article, we will learn about the information you can get from the resources tab of the Siemens PLC.
Resources as the name indicate it contains all the information related to the PLC program.
Let’s take a software tour and find out where the resources tab is and what it contains.
Here, I will show you in the both TIA PORTAL and the Simatic manager.
Resources Tab in Siemens PLC
Let’s first open TIA PORTAL. Enter into the programming environment.
On the left side select the CPU and do right-click on it. From the list choose “call structure”.
Call structure in Siemens PLC
The following window will appear. On the right side in the corner, you can see the “resources” tab.
Click on it.
As you can see in the below window in the resources tab you can have detailed information of the used and unused I/Os, CPU memory, and memory space consumed by programming and data blocks.
Resources of PLC
In the CPU memory, you can see the amount of the used and remaining memory. The same way you can access all the information about the programming and data blocks.
In the input and output section, you can see the information on the number of inputs and outputs you have configured for the project.
You can also see the used input and output section. This is a piece of really very helpful information to have as an automation engineer.
This can be helpful while implementing a new control system or installing a new machine.
To access the same information using Simatic manager first open it. Go to the programming environment.
However, in Simatic manager, it won’t have a specific tab to check resources but you can see memory space as shown in the below window.
Click on “module information”.
PLC Module Information
The following window will appear. Click on the memory section and you have information about memory space used by the program.
In this tab, you have access to lots of information about the PLC program.
PLC Load Memory
Author: Suhel Patel
  • What is HART- IP?
  • Non-mechanical Memory
  • Compare Two PLC Projects
  • HART Communication
  • Delete Siemens CPU Memory
How a PLC do the Scaling for a Sensor ?
PLC Program using START and STOP Buttons
PLC Program to Simulate Gate Array Logic
Check Block Consistency Tools in Simatic Manager
Identify the Problem in the PLC Program
Create a Function (FC) for a Valve Logic in Siemens PLC
Comparison of Proportional Integral Derivative Controllers (PID)
Allen Bradley RSLogix 500 PLC Programming
PLC to Start or Stop 3 Machines using 1 Switch Program
PLC Ladder Logic for Start-up Control of Boilers
Connecting Blocks in Functional Block Diagram – Studio 5000
Basic Pumping System Application Used in Industrial Automation
running two single-phase induction motors sequentially
Control Two Motors in Sequence after Time Delay – Circuit, Operation
Loop Diagram
Omron PLC real-time clock street lighting program
Automatic Highway Lights Program using RTC in Omron PLC
Move function block
Move Instruction in Tia Portal
PLC Program for Automatic Parameter initialization
PLC Program for Automatic Parameter Initialization When Power UP
Learn SCL programming from scratch
How to Start Writing SCL Language in Siemens Tia Portal?
Classic Control Circuits
Can a PLC Function Without an HMI or SCADA
Can a PLC Function Without an HMI or SCADA?
strain gauge changes as it stretches and shrinks
Why Strain Gauge Resistance Changes as it Stretches and Shrinks?
Hydrogen Sulfide Accident
The Aghorn Hydrogen Sulfide Accident – H2S Gas
PLC Timer Program
PLC Timer Instructions
Variable Area Flow Meters
Variable Area Flow Meters – Principle, Advantages, Disadvantages
Thyristor Gating Circuits Objective Questions
Optocoupler Principle
Optocouplers Working Principle
Siemens S7-200 PLC
Programmable Logic Controller (PLC) Questions and Answers – 13
